Question about Kitchen Ranges
My culligan water softner beeps with the message of "missed rinse" what does this mean and how can i fix it?
  • 10 Answers
SOURCE: my culligan mark 89 water softner the salt bin
Try cleaning the filter screen under the metal cover plate. Also check your water supply pressure. Some softeners won't run properly on low pressure.c8a54da.jpg
Posted on Oct 24, 2009
ftw1952
  • 10319 Answers
SOURCE: will not stop regenerating water keeps running
Check the units drain filter. If clogged up it will make this unit run constantly
Posted on Jan 24, 2010
h2oservices
  • 306 Answers
SOURCE: my Culligan water softner is leaking from the
It depends on how old it is. Older Culligan systems(pre 1999) have separate inlet and outlet on tank and have washers that fit inside the "FEET" that slide onto tank. Newer style systems have center opening tanks with o-rings that seat on tank. You need to see what model it is. Bypass the system, run through a manual regeneration to relieve pressure, then you can change the washer or o-ring. They are only available at Culligan.
RJ
Posted on May 11, 2011
h2oservices
  • 306 Answers
SOURCE: Looking for ''Culligan soft-minder meter'' (part# 01-0073-47)
It could be the meter assembly itself. This is the old style with the clear meter dial on the timer mechanism. There were several issues with this meter assembly. You can take the valve off and take it to your Culligan dealer for a "bench test". Also check the meter cable in back of meter assembly. It may have come apart. These parts are only available from Culligan.
RJ
Posted on Jun 04, 2011
h2oservices
  • 306 Answers
SOURCE: my culligan water softner just keeps running
It is most likely running to drain. This is an indication that the seal pack is seized up, generally from a bent piston. You need to by-pass the softener and call Culligan for service. If you are handy there is a retro-fit kit available from Culligan to remedy this problem. It takes about 1/2 hr to install.
RJ
Water softner medalist serie salt is not going thrue
What do you mean by salt is not going through?
Mar 14, 2013 | Washing Machines
My Culligan water softner is leaking from the coonection where the tank and the control head meet how can i fix this problem?
RJ
Mar 24, 2011 | Culligan 34" Whole House Water Filter...
My Culligan MC450S water softner has a blank flashing display. Water seems to be constantly running through the softner and pressing any display panel buttons has no effect.
This system should be under warranty still. If it is running to drain constantly bypass the system and call Culligan for service. Unplug it for 2 minutes and it may reset.
RJ
Jan 08, 2011 | Culligan Sales #SY-750S Under Sink Water...
I have culligan house water softner. after i changed my hot water heater my softner stopped working. I dont have a manual to check. any suggestions?
Unless the softener was bypassed when the water heater went in, installing a water heater has no bearing on the softener working or not. Is it unplugged?
RJ
Aug 27, 2010 | Culligan 34" Whole House Water Filter...
We have a summer cabin up in Minnesota on a lake on the Measbi Iron Range and the iron content of our water as it comes out of the tap is 240 times greater than the EPA allowable maximum. If we install a...
Water softners will remove approx. 90% of the iron from the water...if this is acceptable then you are okay with the Culligan...if not then you will also have to install an iron removal system in addition to the softner.
Also check around with your local plumbers, as many will install a water softner at a gereatly reduced cost from what the franchises will charge you...and they have just as good a systems and often do a much better installation job.
heatman101
Aug 13, 2010 | Plumbing
My water softener is inoperative and is displaying ''E1'' in the status window.
Two possible ways to resolve this:
1. (the easiest to try first) - Unplug the unit from the electrical supply for 20-30 minutes and then restore power. This may clear the error code.
2. The error normally means that the motor has encountered some form of resistance - i.e. a blockage of debris in the piston seal inside the valave or possibly it could be due to a microswitch not activating correctly which could cause the piston to stop in an incorrect position. This would normally be a job for the service team; however if you are feeling that you want to tackle this yourself you could refer to the diagram in the user manual to disassemble the unit and investigate further. In all liklihood a clean may well fix the issue
If this helps, please leave feedback
Feb 07, 2010 | Culligan Sediment Water Filter
My culligan water softner just keeps running .
RJ
Jan 31, 2010 | Culligan Under Sink Water Filter
Will not stop regenerating water keeps running
Jan 24, 2010 | Culligan Sediment Water Filter Heavy Duty
Softner model hi flo 2 water volume about half
The flow packs are not opening properly. There may a restriction in the lines feeding the flow packs or the springs/ diaphrams may be bad. I suggest replacing both flow packs and making sure all lines feeding flow packs are free of oxidized iron and debris.
RJ
Jul 01, 2009 | Culligan Sediment Water Filter
MISSED RINSE on culligan softner
the unit number one needs to be reprogrammed by a professional only it is tricky and ck the motor in the unit this controls the valves turning and water direction control.
Apr 29, 2009 | Culligan Sediment Water Filter
Kitchen Ranges Logo
151 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
