Question about U-Line 15WC Wine Cooler
Thermostat not working How to replace? - U-Line 15WC Wine Cooler
    Genius:
  • 1,478 Answers
Unplug the wine cooler before removing any panels or screws. If the plug is hidden behind cabinets or in another hard-to-reach location, you can flip the breaker switch that controls the power to the kitchen. Locate the thermostat on your wine cooler.
Use needle-nose pliers to remove the wires from the ends of the thermostat's terminals. Grip the wires close to the end and gently tug until the slip-on connectors pull away from the terminal. Do not pull from the middle of the wires because they are thin and can break easily. Remove any screws or clamps holding the thermostat in place. Set the new thermostat in place and reconnect any clips, clamps or screws. Replace any inside panels, screws or clips that you removed. Plug the wine cooler cord back into the electrical outlet or flip the breaker back on, and wait for the unit to cool down.
Take care.
Posted on Oct 07, 2010
How do I replace thermostat?
    1. Maintenance and How-to: Thermostat Replacement ...
      https://www.youtube.com/watch?v=RIC6Z4D6Q3E
    Feedback
  1. How to Replace Your Vehicle's Thermostat - For Dummies
    www.dummies.com/how.../how-to-replace-your-vehicles-thermostat.htm...
    Just be sure that you do this when your engine is completely cooled. Locate yourthermostat if you haven't already done so. Place a bucket under where you're going to be working. Remove the clamp. Pull off the hose. Remove the bolts that hold thethermostat housing in place and lift out the old thermostat.
    How to replace a car thermostat ' How a Car Works
Dec 12, 2015 | Cars & Trucks
How to wire six wire to three wire termenal
I'm pretty sure this thermostat uses digital communications with a dometic control board. In other words, there are no contacts in the digital thermostat to turn something on and off. Even if you ran a 12VDC wire to the thermostat for power, it won't work to replace a "real" thermostat. I bought one to replace my old analog thermostat and it's not going to work for me.
Oct 10, 2015 | Dometic 3313192.000 White Single Zone LCD...
Just replaced both elements to my reliance electric heater..heats fine but after 1 shower i have to reset red button and repeat process daily Whats up? thanks
Replace thermostats.
One of the thermostats is sticking causing overheating that trips ECO reset located on upper thermostat. There is no good way to test thermostats since testing means turning the temperature setting which temporarily unsticks bad thermostat so it looks like it works ok, so replace both thermostats.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Sep 17, 2012 | RELIANCE ELECTRIC WATER HEATER
Themostat is bad
If water heater thermostat is bad, buy a generic thermostat at hardware store and install it according to instructions shown on link below:
I usually replace both upper and lower thermostats for about $28.
Lowes sells thermostats and elements.
If your water heater is a single-element/ single-thermostat, you can buy any thermostat with red reset button.
Technically a single-element thermostat has 1 less screw, but either thermostat will work.
If your water heater is 120V or 240V, the same thermostat will work of either voltage.
This is true because the thermostat is a simple bi-metal heat-reading device that does not operate on electric current.
That being said, you might want to test parts before replacing anything, in case problem is element.
To do comprehensive electric water heater troubleshoot:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Image below shows generic thermostat with reset button. Each of these will work for single-element or dual-element tanks with either 120V or 240V. Wires connect just as they did on old thermostat. Tighten wires very tight. Press in reset button to make sure ECO is set. Put insulation and cover back over thermostat when finished.
Dec 22, 2010 | RELIANCE ELECTRIC WATER HEATER
Water was much hotter this morning, actually steaming when faucet turned to max. I checked thermostat & reset button, seemed to be normal. I shut off power and pushed reset button, waiting for it to...
I would try it again and if water temp is still to high then I would adjust thermostat down to say 120 degrees and see what that does.If problem continues I would replace thermostat. Thank you
Dec 20, 2010 | Reliance & 50gal Electric Water Heater
When it works on hi cool after sometime the blower stop but compressor still working .my aircon is window type.
Replace the thermostat. The thermostat is shutting down the blower and not shutting down the compressor. Also replace the relay on the compressor as this should be replace when the thermostat is replaced to make sure both are in working order
Apr 18, 2009 | Heating & Cooling
Honeywell T882 Chronotherm Clock Thermostat needs replacement
The two wires from the transformer are to run the clock in the old thermostat. If you connect the two other wires to any heating thermostat, it will work. Don't forget to disconnect the transformer wires. Hope this helps
Nov 10, 2008 | Honeywell Electronic Programmable...
Dryer no Heat. New Thermostat Burnt Out.
sounds like you are replacing the hi limit thermostat try replacing it with the cycling thermostat as well
Jan 20, 2008 | Whirlpool LEQ8000JQ Electric Dryer
Honeywell T86A3006 24V Class 2 Round thermostat 8020
The honeywell tradeline thermostat would work as a direct replacement (no mercury in the new ones), however if your using just heaters and no cooling system off of it, you could Heat only thermostat from honeywell that would replace your unit as well. Both at available at Ace Hardware with the heat only unity being roughly 7 dollars cheaper.
Jan 14, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
U-Line 15WC Wine Cooler Logo
643 people viewed this question
Top U-Line Furniture Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you an U-Line Furniture Expert? Answer questions, earn points and help others
