Jenn-Air WW27430P Stainless Steel Electric Double Oven Logo
Posted on Oct 07, 2010
Dim control panel Jenn-air wall oven ww27430p
5 Related Answers
Anonymous
  • 213 Answers
  • Posted on Nov 27, 2007
SOURCE: Electrical Jenn Air Oven control panel ..
theres no fuse. the display needs to be replaced. this is a common problem on maytag and jenn-air ovens
Anonymous
  • Posted on Sep 20, 2009
SOURCE: Display on my Jenn-Air electric wall oven is very dim
I replace the C3 Capacitor on the display circuit board of a Jenn Air model #JJW9627AAW - double oven from Sears after the display got too dimm. This cost me $1.50 total verses the $200 parts cost only.
Thanks for the tip man!
dltatsjc
Dennis Thatcher
  • 54 Answers
  • Posted on Oct 12, 2009
SOURCE: Jenn-Air JJW8530 LCD panel does not light up
BrianGem posted a great solution back in May of '08, I just completed that fix on my own Jenn air, took me about 30 minutes once I got the correct capacitor.
The display board apparently has a weak spot in the
design, most likely heat related, (probably low priced components from offshore sources)
Fix: Replace heat damaged capacitor labeled C3 on display board, Hard part will be obtaining the 35Volt 68uF capacitor, I'm lucky enough to have a Brother in the electronics design field who found me a couple of high reliability caps designed for hot applications, He does not recommend changing sizes without design review for fear of overloading another component, however several other posts have indicated that a 35V 100mF cap has worked fine for them.
TURN OFF POWER TO OVEN PRIOR TO STARTING ANY REPAIRS.
My control panel was attached to the oven with 4 screws accessed from above the top oven door, the panel slid up about 1/2 " and lifted off, Unplug the ribbon cables and the panel can be removed to a convenient work surface. The display board itself is mounted with 4 screws and connected with a wide flat ribbon cable, the suspect capacitor is surface mounted to the reverse side of the board, two plastic clips need to be released (gently) and the ribbon cable unplugged. Capacitor is likely discolored or leaking, Using as small a soldering iron as you can find De-solder it and replace with new, match polarity marks and don’t use any more solder than needed.
If you run into trouble drop me an e-mail to [email protected] and I’ll try to help.
Good luck.
Thanks for this site..
Link to Photo sequence of capacitor replacement (Captions still will not link):
http://picasaweb.google.com/dltatsjc/Photos?authkey=Gv1sRgCJPKv9CRgsXxNA
Anonymous
  • Posted on Dec 25, 2009
SOURCE: Jenn-Air wall oven control panel not working
my jenn air wall oven controls are not working how do i fix it
Anonymous
  • 19 Answers
  • Posted on Feb 04, 2010
SOURCE: Jenn-air expressions wall oven clock went dim, now out completely
If you haven't already, replace the capacitors on the clock module. I had the same problem with a similar oven. See this link for more info:
http://www.badcaps.net/forum/showthread.php?t=7902
Jenn-Air model WW27430P. After heating to set temperature and baking for 8 to 10 minutes, why does it shut off?
It's faulty and in some sort of self protect mode. You need a service call or you can try some of the fixes here.
FIXED - WW2780 Jenn-air oven keeps shutting off ...
www.applianceblog.com > mainforums > threads > ww...
Feb 15, 2012 - Hi.... I have a Jenn-air oven model WW2780 that keeps shutting off after being turned on, almost always during the preheat. From what I have ... Missing: WW27430P ‎' Must include: WW27430P
Jenn Air Range Stove Oven - Oven Won't Turn Off - Repair ...
www.repairclinic.com > RepairHelp > Jenn-Air-Oven-...
Here are the most common reasons your Jenn Air oven won't turn off - and the ... Enter model number to search for the required part specific to your product.
HOW-TO: Jenn-Air Oven WW27430P Door won't close
www.appliancepartspros.com > repair-help > ww27430...
Door won't close is the most common symptom for Jenn-Air WW27430P. ... I have a Jennair jjw9630cas double wall oven, and after a few years I noticed that the light would not go out, first in the bottom ... Door pulls shut and li8ght stays off.
HOW-TO: Jenn-Air Oven WW27430P Won't start or doesn't start
How to Replace Oven Temperature Sensor Kit for Jenn-Air WW27430P Won't start # ... Jenn Air stove JDS9860CDB00 error code 1d11 oven not shutting off. ... Very easy on this and other models with this sensor-- just two screws holding it in ... Rating: 5 · ‎123 reviews
Nov 17, 2020 • Ovens
How much to have electronic control board replaced on Frigidaire stove? The readings are too dim. Can we fix it ourselves?
Capacitor C3 a 68uf 35v could be faulty. Check this link out if you wish to attempt a repair - http://www.badcaps.net/forum/showthread.php?t=7902
Range has a very dim display
I have a Jenn-Air double wall oven with a very dim display light. Replaced c3 capacitor 68uf 35w - with a 100uf 50w cost $1.60 closes size available at Radio Shack and works good as new. Requires soldering onto the circuit board. I price a replacement part for $276.00.
Control panel light is extremely dim
Should be C3 Capacitor on control panel board replace capacitor from Digi-key Corporation get panel out and see what C3 capacitor says what voltage and uf and temp celcius and order from them solder it takes two -10 minutes..
7helpful
2answers
Oven digital lighted display is dim
You need to replace the C3 capacitor on the control board
http://fixitnow.com/wp/2009/01/28/cheap-fix-for-a-dim-display-on-an-oven-control-panel/
You can replace only the C3 - it is 68uF / 35V and you can go to Radio Shack and get their part # 272-1028 - 100uF/35V one. It takes all but 10 minutes to re-solder the new one in place
1helpful
My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
2helpful
2answers
mY 27" WALL jENN air blows cold air out the vents when on cleaning cycle. The red buttons aren't lighted. The door locks, otherwise it bakes fine. I wonder if it is really cleaning?
1helpful
Display panel
Dim display indicates a "failing" electronic oven control. It will continue to get dimmer and dimmer until it fails completely. You need to replace the "clock" (sometimes called the ERC <---Electronic Oven Control)
This is a tricky repair. Be sure you have the power off (at the breaker box) before attempting this.
Tracy
Top Jenn-Air Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
