Question about Toys
We are trying to locate the New Bright battery charger 19.2 volts model number AA87200078. Plus the re-chargable battery # NB50708E. We have twin boys and have to replace both sets. Are you able to assist. Many thanks. Bob Mason rsmason@snsngrem.co.uk
  • 60 Answers
SOURCE: CANT LOCATE CORRECT CHARGER
For those batteries, you need the proper charger. Call peg perego directly, you will need the standard 12v charger. You can also find them at a variety of places online.
Posted on Mar 11, 2009
  • 61 Answers
SOURCE: WE NEED TO PURCHASE A REPLACEMENT CHARGER
You should be able to find a replacement charger at www.batteriesplus.com
Posted on Mar 23, 2009
bilink
  • 128 Answers
SOURCE: new bright 19.2v nicd battery problem
Don't throw away any NiCd power tool battery, Firestorm or Versapakbattery that does not hold a charge or does not give you the power youneed, you can get new life from your battery or device that containsNiCd batteries. icad batteries often die in such a way that they won't take a chargeand have zero voltage. This usually means they are shorted out bycrystal dendrite growth. You Can fix these shorted crystal dendrites by"Revitalization through Vaporization of Dendrites (RVD) Process".
You can get this guide from here
Posted on Jul 14, 2009
I have purchased 2 remote controlled toy cars from Costco over the years. These New Bright batteris and charges last only a few charges, and then they go bad. I am disappointed. I will go to Walmart and buy a new battery and see if it works better, if not, i will return to Walmart.
Posted on Dec 01, 2009
mcdevito75
  • 1970 Answers
SOURCE: Where can i get a new battery/charger 9.6v for my
mcdevito75 here, You should be able to contact New Bright on line or with the paper work that came with the Land Rover.
Posted on Jul 05, 2010
Testimonial: "very helpful thanks"
Battery charge light flashing amber
Ok, lets start slowly, do you have both a new battery and a new battery charger? If both attempt to use your old battery with the new charger. Also could be a bad charger or a shorted out battery...
Good Luck
Feb 13, 2013 | HP Compaq nx9600 Notebook
Hi, i have svoa labtop and now my charger adapter got burnt due to electrict short. Now my charger is not working and i cannot use it.
OK. But I don't understand what the problem is.
AC adapter (Charger) is burnt out, by a new one.
Look at the old 'charger'.
Look at the label.
Input: 100 ~ 240VAC/50 ~60HZ.
100 to 240 Volts AC, at 50 to 60 Hertz. (Cycles per Second)
Output:
This is what you need to know.
What is the output voltage of the original charger?
Example;
Output: 19VDC @ 4.63A
19 Volts DC at 4.63 Amps. (Amperes)
Your charger MUST put out 19 Volts. (For the example)
It WILL be DC electricity, so don't worry about that. (Direct Current)
[Your 'charger' is more than that. More than a charger for the laptop battery.
It is also a Converter. It converts the 100 to 240 Volts of Alternating Current, (AC), into a low DC Voltage.
Plus it charges the Battery, WHEN needed ]
Post back in a Comment as to what the exact query is.
Regards,
joecoolvette
Jan 25, 2013 | Computers & Internet
Need a battery charger for the 21.6 volt battery
It will work if it is of the same charger/receiver style. The only issue is that you will only be charging to 19 volts and not 21.6, I would estimate by doing some simple math that you would lose about 6-8% of the batteries capacity but you would be able to use it.
Jun 05, 2012 | kawasaki 21.6 volt Cordless Drill Driver 2...
I have a pd360 Type 2 3.6 Volt Pivot screw driver and I don't know how to charge it? I've misplaced my paper work for the tool. Can you help me?
Usually, the battery is removed from the tool and inserted into the charger base. Hopefully, the charger has not disappeared also. Good luck!
Oct 16, 2010 | Black & Decker Garden
I work at a homeless clinic. We had a Jazzy 1170 donated and we charged the battery for about 7 hours. When we tried it out it moved very slowly. Nothing was registering on the amp meter on the back. ...
Yes you probably need new batteries. If you have access to a digital voltmeter set it to 200 volts DC and plug the leads into the charger port located under the front of the joystick. Plug it into the 2 outter holes. Without the charger plugged in you are reading the battery voltage it should read 24- 27 volts. Now plug in the on-board charger and the voltage should go up to 27-30 volts. If you don't get at least 24 volts w/o the charger plugged in then the batteries are bad. If you don't read 27-30 volts with the charger plugged in then the charger is bad and unfortunately both might need to be replaced. Hope this helps
Sep 14, 2010 | Pride Mobility Products Jazzy 1170 XL Plus
Versapak battery will not hold charge
If it is an old battery (3 plus years) it probably needs to be replaced. The other failure point is the charger. That can be checked with a volt meter. should be about 4 volts for each battery in the system. 1 battery 4 v, 2 batteries 8 v. Depending on the system it maybe either ac or dc. Try both with your volt metter.
Amazon seems to have the least expensive replacements.
Search for Black & Decker VP143 Versapak Gold Twin Pack.
Jun 19, 2010 | Black & Decker 3.6 Volt VersaPak® Battery...
Hello, I have put batteries in both phones and set them on the chargers However, as soon as I take it off the charger, it goes dead. Why is that?
Those batteries are not chargable. I think you need AAA NiMH rechargeable standard batteries. You can get them at Walmart, Radio Shack and many other stores. If you have the owners manual for the phones it will have information about the batteries.
Jan 01, 2010 | Doro 730r+1 Twin Cordless Phone
I need to get a cordless battery charger (old style, not lithium, will do) AND TWO old style batteries for my 18V Plus 1 RYOBI cordless recip saw. AND I need to get the manual. HELP! Sue Sweeney
Have you tried Ryobitools.com they have accessories and also a dealer locator that you can find them. If no luck let me know and give me the model number and I will try and track some down for you
Apr 20, 2009 | Coleman Cable Coleman 18 Volt Combo Drill...
Lithium ion battery won't charge
known issue, battery needs to be 'shocked" back to life. Here's the fix:
"Hi,I just found a soultion on another website and it appears to have worked for me.Apparently the battery loses it memory when fully discharged,to fix this take a 9v battery and place the terminals + to + and - to - with the camera battery for 30 seconds or so then put the battery back in the camera and charge as normal.I just did this and it seems to be charging and the red light is solid.hope this helps."
Nov 04, 2007 | Casio Exilim Zoom EX-Z700 Digital Camera
Toys Logo
98 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
