Question about AT&T Sony Ericsson W580i Cell Phone - White
Backlight on faceplate buttons won't turn off
Had my phone for about a week, and the other day the backlight for the face plate buttons will not turn off when the phone is locked and in standby mode.  I have tried turning the lighting effects off in the settings mode but the faceplate backlight buttons still remain on??
You should try to get some of that air in a can. slide the phone open and spray it in there. There might be dirt in the phone causing it to stick.
Posted on Jul 06, 2008
Faceplate display only functions when you touch a knob or button
THE FACEPLATE HAS LIKE SOME PINS WHERE IT MAKES CONTACT THE FACE PLATE WITH THE STEREO BODY WITH A COTTON AND SOME ALCOHOL CLEAN THE CONECTOR THE ONES THAT ARE IN THE STEREO BODY AND THE FACE PLATE BUT WHEN YOU MAKE IT MAKE SURE THE CAR OR FACE ITS TURN OFF
Nov 02, 2013 | Alpine CDA-9831 CD Player
Backlight not lighting
Yeah - I know the problem though my "kid" is 51!
Select Menu > Settings > Display settings and then:
Backlight time—to set whether the backlights are switched
on for 15 seconds (Normal), for 30 seconds (Extended), or
not at all (Off). Even if Off is selected, the backlight stays on
for 15 seconds when the phone is switched on.
It's the last line that worries me, though: if your "kid" has caused the backlight to FAIL, then you're faced with no backlight, or a repair/replacement bill!
Kids, eh? Who'd have'em?!?!?!?
Apr 29, 2009 | Nokia 2310 Cellular Phone
Buttons on face plate dont work
May not be a solution to this problem in particular but get on ebay and find a new flex cable for like 6 dollars. The flex cables in slider phones break down or come loose easily. Usually this causes your screen to turn white. In your case the buttons have stopped working. It may be another problem altogether. So try replacing it, its cheaper than buying a new phone or taking it to a shop. Hope it helps!
Jan 30, 2009 | Samsung SGH-d807 Cellular Phone
Panasonic C9700U Turns On, Works but NO BACKLIGHT
It sounds like the mini-bulbs burnt out. Any good repair shop will have them in stock and it shouldn't cost too much. We charge around $35-$55 to do it.
Aug 05, 2008 | Panasonic CQ-C9700U CD Player
No backlight
A couple things to try:
1st check the backlight settings
Turn on Backlighting and Control Brightness To use your device in dark environments, enable the automatic backlighting feature:
  1. From the Jump screen, press MENU t02003-15.gif then select Settings > Battery & Display.
  2. In the second group box, select the Turn on backlight when using device check box.
  3. Highlight, then select the Brightness slider to open it for editing. Roll the TRACKBALL right to increase brightness; roll the TRACKBALL left to decrease brightness. After you've made the adjustment, press the TRACKBALL to exit edit mode. t02007-55.jpg
  4. Select the length of time you want backlighting to stay on from the Turn off after pop-up menu.
  5. To use the device's light meter while the backlight is on, select the Use ambient light sensor check box.
  6. Press JUMP t02003-14.gif to return to the Jump screen and save your setting.
Now, when you press any button or key, or flip open the screen, backlighting will turn on for the set amount of time. Note that as long as you press a key or button before the set time elapses, the backlight will stay on.
Tips:
  • Even if you have not selected automatic backlighting, you can turn on backlighting at any time by pressing MENU t02003-15.gif + JUMP t02003-14.gif . The backlight will remain on for the time specified in the Backlight Turn off after pop-up menu.
  • When in key guard mode, you can turn on the backlight by pressing the RIGHT SHOULDER t02003-66.gif button.
If it still does not work, then you can try resetting the flex cable to the lcd.
Reseat the SidekickFlex cable
If that doesn't fix it then a new lcd assy will take care of the issue. they run about 45 dollars on ebay.
Sidekick LCD screens
Apr 26, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Face plate replacement
You can't find faceplates for card decks since that will defy the safety feature.
Mar 19, 2008 | JVC KD-AVX33 Car Video Player
Backlight display not working
Hey Dannes1956,
The Motorola V3m has a light sensor, which is visible just above the right soft key -- the key above the CLR button. This light sensor turns the backlight on when you press a key in the dark and disables the keypad backlight when you are in a well-lit area.
Your phone sounds like it's operating normally. I believe they disabled the option to activate or deactivate that feature.
Hope this helps,
cHiPz.
Mar 17, 2008 | Motorola Mobility RAZR V3
Will power up,will hide, will open on igntion start
yup.. needs a new face plate ribbon cable.. just like mine :-(
Sep 24, 2007 | Kenwood KDC-716S CD Player
AT&T Sony Ericsson W580i Cell Phone - White Logo
62 people viewed this question
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
