Question about Hotpoint HTM17BBSSA Top Freezer Refrigerator
The freezer is making an intermittent wheezing/knocking sound. Both the freezer and refrigerator are cold.
fridgetech
  • 473 Answers
SOURCE: Refrigerator Not Making Ice, Frost in Freezer and Refrigerator Not Cold
It has a defrost problem.  Most likely cause would be the defrost thermostat which clips onto the evaporator behind the back panel in the freezer.  Next most common would be the defrost timer.  Third would be the defrost heater.  Let me know if you want to try to test these parts.  If so I will need the entire model # from the sticker in the fridge or on older models on a plate at the bottom front below the door.
Posted on Oct 10, 2007
CRTN
  • 716 Answers
SOURCE: GE Side by Side GSS22JERFWW not keeping cold
often there is a cover in the rear of the freezer with some screws remove these and put low temp grease on the fan. The Problem Is %100 The Fan So If You Look Up Your Fridge On Google It Will Tell You Where The Fan Is.
Posted on Jan 05, 2009
kram26
  • 544 Answers
SOURCE: my refrigerator is warm the freezer is a little cold but not freezing or making any ice cubes
you can try this suggestion,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks
Posted on May 23, 2009
  • 89 Answers
SOURCE: brand new french door maytag refrigerator makes a loud knocking sound off and on all day. Is that normal ?
im sorry to tell you, but the sound is probobly normal.
fridges these days make some weird noises.
they started making noises when they changed the gas to R34a.
you may be able to get a noise ruduction kit for your model. they are not too fun to install
Posted on Jun 07, 2009
woodchuck789
  • 4059 Answers
SOURCE: Refrigerator knocking noise
If it seems to be coming from underneath the unit it could be the compressor. Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} That's usually mounts inside the compressor. Usually when the compressor cuts off. It could still last awhile so if you can put up with the noise just wait for it to quit before replacing the compressor or getting a new fridge.
Any other noise would be from a fan. One in the freezer behind the back panel and one under the unit where the compressor is.
Posted on Dec 29, 2009
Samsung wheezing/ Gasping sound.
It is likely just refrigerant coursing through the coils, or maybe the water valve when it opens to fill the ice maker... Is it constant, or does it come and go at intervals?
May 27, 2016 | Samsung RF4287HABP 28 cu. ft. 4-door...
LG fridge making loud noise
Bonjour,
jeepers are we talking about a wheeze, a clunk, a whirr, a buzz, a rattle, a hum, random modulated or cyclic, low or high frequency, persistent or intermittent? Or could you just be hearing fan noise.
If it sounds like tin pieces clinking against something metallic. The fan blades may be striking ice or frost or the shroud.
Could be a bad or worn fan motor bearing, or a defrost problem causing frost build up.
Just a FYI
Some LG models have been reported online as having many many operating issues.
Hope this helps
Jul 11, 2012 | LG Refrigerators
Knocking noise
Sometimes when it's to close to the wall it will make noises try pulling it out a bit.
Apr 25, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Model #106.74254400 Refrigerator is 6yrs old, suddenly started making an intermittent knocking sound (about once an hour and lasts from 5-7 seconds). Refrigerator seems to still be working fine
I'm sorry I don't have a solution but I'm hoping you might have come up with a solution because I'm having the same problem. mail:durwoodandlinda@comcast.net
Mar 14, 2010 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Our Jenn-Air French Door bottom freezer refrigerator is making a noise like it's breathing while sleeping. Kind of a wheezing noise. Do you know what this might be and what to do about it? I think it...
This might be a normal noise. when they switched to 134a refrigerant, they had to develop a new oil. This new oil comes over or circulates more easily then the old oil. The oil and refrigerant flow through a capillary tube under 180 psi to the evaporator where it expands. the noises from this process can sound like tapping, chirping, clicking, squealing or wheezing. A hot day, a dirty condenser or when the unit comes out of defrost will make the noises more noticeable.
Aug 27, 2009 | Jenn-Air JFC2089HP Bottom Freezer French...
Brand new french door maytag refrigerator makes a loud knocking sound off and on all day. Is that normal ?
May 31, 2009 | Maytag MFD2560HES Bottom Freezer French...
GE refrigerator motor wheezing
check behind panle where the fan is may be ice defrost the problem area
Dec 01, 2008 | LG LRBN20510WW Bottom Freezer Refrigerator
Hotpoint HTM17BBSSA Top Freezer Refrigerator Logo
110 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
