Question about Paradyne (6211-A2-200) Router
Hey i cannot get to login to my paradyne 6381 dsl modem the page isnt even comming up
    Novelist:
  • 143 Answers
Check if your computer is getting a valid address from your modem. if so, try to ping the modem's address and check if you'll have replies. if it'll reply, try to disable any antivirus software and firewall installed on the computer or try to use another browser. if not, check i the computer is properly connected to the modem, try to use another port or another known working cable. also try to use another computer for isolation.
hope this'll help you with your concern.
Posted on May 30, 2008
My modems LAN light is blinking and I can't get Internet, I've tried unplugging it, but the problem still exists, please help
There will be 4 lights...
Power
Dsl
Internet
Ethernet
Power light indicates power supply is good...
Ethernet light indicates connection between modem and computer is good...
DSL light indicates connection between modem and telphone line is good... Also DSL light should be steady and it should not flash...
If it flashes then it says there is a lot of noise in telephone line...
Internet light says whether the internet status is connected or not...Internet light can flash depending upon the internet activity...
Feb 03, 2011 | Paradyne 6381 ADSL2+/ReachDSL Router...
My company provided me wired internet using Paradyne 6381 wired modem. it works fine. I have D Link 2640 T wirelss modem + router available with me. Please advise me how do I connect available D link 2640...
Since your D-Link 2640 is a modem + router it may not work the way you intend.
You need just a wireless router without modem.
Run a small Ethernet patch cable from your Paradyne modem into the WAN port on your router, you can plug your existing Ethernet cable into one of the other LAN ports on the router, then access the router setup using the computer connected to the Ethernet cable using a browser and putting the router's IP address into the address line of your browser. It will most likely be 192.168.0.1 or 192.168.1.1.
Once you have configured the Wi-Fi router you will have your wireless network. Full instructions should come with the router.
Routers are available for as little as $29.95 but expect to pay closer to $79.95 for satisfactory speed and capability.
Oct 23, 2017 | Paradyne ADSL/R 6381 Router (6381-a2-200)
I need the download device driver for 6381
you will find the drivers that you are looking for on this web page:
http://www.zhone.com/support/downloads/drivers/
they should be the 2nd or 3rd from the bottom
Oct 15, 2010 | Paradyne ADSL/R 6381 Router (6381-a2-200)
What is the ip address of paradyne 6381 a3 300 router
To configure your router, open your web browser. Type the default IP address (http://192.168.1.1) into the Location field of your browser and press the Enter key. A Login screen will appear. Use the below to log into your router.
The default IP address is 192.168.1.1
The default user name is Admin
The default password is Admin
Both are case-sensitive.
Jan 08, 2010 | Paradyne ADSL/R 6381 Router (6381-a2-200)
What is the IP address, Username and Password for the 6381-A2-200? Thanks for your help!!
The IP number is: 192.168.1.1.
The login info is UserID: Admin (case sensitive)
The password is Admin (case sensitive)
Also here is a link to the users manual:
http://www.zhone.com/support/manuals/docs/62/6210-A2-GB21-10.pdf
Good luck and if you found my solution to be helpful please rate it.
Apr 02, 2009 | Paradyne ADSL/R 6381 Router (6381-a2-200)
Default login information on a 6381-a3-200
first write 192.168.1.1 on address bar a login window will apear write user name and password admin
Jul 25, 2008 | Zhone Paradyne 6388-A1-200 Router
How to know the username password
connect your computer to it
go to start->run and type "cmd", press enter
type "ipconfig"
look for "default gateway..." and note the ip address(ie http://192.168.1.1)
go to your browser and type
http://192.168.1.1:8080
if that doesn't work..type
http://192.168.1.1
you can always call your isp technical support and ask them for it.
Feb 23, 2008 | Computers & Internet
Trying to set up pptp on a Paradyne 6381
I have modems 6381-A2-200, sw ver.03.00.10. This model does not support pptp-connection.
Dec 06, 2007 | Paradyne 6381 ADSL2+/ReachDSL Router...
Paradyne (6211-A2-200) Router Logo
143 people viewed this question
Top Paradyne Computers & Internet Experts
Michael Galve
Michael Galve
Are you a Paradyne Computer and Internet Expert? Answer questions, earn points and help others
