Question about John Deere A,b,g,gm,gp Tractor Carburetor Choke Shaft
John deere b won't idle with out the choke being 1/2 on
  • 77 Answers
SOURCE: 1981 John Deere 317 carburetor screws for the
When it comes to carb adjustmant,my recomandation is for you to seek a professional to do it for you. You can fight with it for a while and not get it,small engine mechanics that do it all the time could have your problem fixed rather quickly and wouldnt charge you much,but thats up to you.
Posted on Aug 09, 2009
wireguy212
  • 1627 Answers
SOURCE: 2305 john deere, idle runs slow in full idle.
Look at the fuel filter bowl on the rear of the engine right hand side to see if you can see a red ring raised up slightly from the bottom of the bowl.If you can see the ring then there is water in the fuel[or ice by now]You will need to take of the filter and get the water out of the filter bowl by taking it indoors to thaw.Before removing the filter bowl,turn off the fuel,petcock is just above and to the rear of the filter.Once the water is out you then need to clean the bowl out and re-install with a new filter.Pick up a product called "diesel melt" at the dealership and add it to your fuel for the rest of the cold season{follow the instruction on the bottle}.If this is not the case then the linkage on the injection pump may need to be adjusted to get the rpm up to no more than 2450 rpm..
Posted on Jan 11, 2010
  • 52 Answers
SOURCE: John Deere 445 Garden Tractor, starts immediately,
could be bad gas, but it sounds like a choke problem. did it sit over the winter with less than a half tank of gas in it. try putting some rubbing alcohol in the fuel or draining the tank and disconnecting the gas line so you can drain the gas out of the carb. also check the gap of the spark plug and make sure that is correct. when was the last time there was fresh oil put in. also check the air filter, it could be full of dirt.
Posted on Apr 18, 2010
Testimonial: "Thanks for the ideas. I will try your suggestions. Tractor used for snow blowing during the winter and gas did not stay in it long. Good ideas!"
  • 146 Answers
SOURCE: my john deere rideing mower idles up and down at
The motor has a governor that controls its speed, and if one of the pivoting parts or linkages is sticking this would happen. Look for the throttle linkage on the engine carburetor (move your throttle up and down, watch what moves). The governor will be a second linkage attached to the throttle arm. Squirt some WD-40 on any rotating parts and make sure a foreign object isn't stuck in there. It could also be the part of the governor that's internal to the engine -- harder to get at, but not expensive to fix.
Posted on Jul 04, 2010
wireguy212
  • 1627 Answers
SOURCE: problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Posted on Jul 29, 2010
John deere ride on problems
Black smoke indicates rich mixture. Dirty air filter. choke stuck on. loose main jet in carby. just a few possibilities.
Dec 31, 2012 | Oregon Scientific Oregon Gator Mulcher 3N1...
My John Deere x300 won't start. The battery is charged and I can smell gas as the engin turns over. It
I am not familiar with this particular model but from the smell of raw gas I check the air filter and choke first to see that you are not flooding it. You could also take out the spark plug to see whether it is wet with gas.
Aug 07, 2011 | John Deere Garden
I have a john deere 285 lawn tractor that smokes and cuts out at high throttle. It will idle though. The fuel pump will squirt accross the garage so its fine. I have taken the carberator off and...
It sounds like it is too rich in fuel at full throttle.
Try removing the air filter and running the engine.
What happens?
Ensure that the choke is fully open.
Gary
Feb 16, 2011 | John Deere Garden
Hello my name is John. I have a 345 John Deere lawn tractor. The problem is that it starts idles rough won't idle up and does not run strong enough to move the mower. It just chugs and puffs white smoke...
345's have a habit of the choke sticking at the carb.Another problem they have is the fuel pump diaphram will crack and allow your engine to fill up with fuel,to much fuel in crankcase will end up past the rings when not running and smoke pretty bad when fired up.
Jun 20, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Apr 18, 2010 | John Deere 420,1020,2010,2020,2510,2520...
1981 John Deere 317 carburetor screws for the idle, and choke are not set correctly. Will not start.
Aug 02, 2009 | John Deere 3010,3020 Tractor Basic...
John Deere A,b,g,gm,gp Tractor Carburetor Choke Shaft Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
