Question about Whirlpool LHW0050PQ Front Load Washer
HOW TO INSTALL A BELT ON WHIRPOOL WASHING MACHINE LHW0050PQ?
  • soulsurfer1 Oct 07, 2010
    I alredy take off teh back part, but I dont know how to reach the puller.
  • Whirlpool Master
  • 8,220 Answers
Take the back off and the belt can easily be installed HOWEVER if the tub bearing is shot the belt will not stay on.
Posted on Oct 07, 2010
  • msholly322
    msholly322 Jul 20, 2012
    what do i need to do to keep the belt stay on? i replaced the belt and when i turned the belt wont stay on
Whirpool front load washer model LHW0050PQ4 makes sputtering sound during spin cycle
Power plug off the wall first. Check out the pump which comes after the filter, something shd be clogging there; it shd move freely.
Remove back of machine to see if anything is touching the wheel belt or pulley.
Pl click helped, if helped.
Apr 09, 2013 | Whirlpool LHW0050PQ Front Load Washer
How to put belt back on whirpool ultra care II washing machine
There's a very good video provided by PartsSelect which shows the process for replacing the drive belt on a Whirlpool Washer. Video link is below. Best of luck!
Greg
Sep 12, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
My whirlpool lhw0050pq will fill with water then do nothing. if i shut off the machine then turn it back on selecting the spin cycle it will drain the water but thats it???
If the drum is not moving at all it sounds very much like the belt is broken or the motor is malfunctioning.
Belt first.
Belts are not expensive- sorry I do not know how much yours would cost- and are easy to be changed by a competent person:-
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
If it turns out to be the motor, it is false economy to just have the brushes changed although financially very attractive. Experience of others is that the brushes may only last months unless, that is, the motor is totally refurbished at the same time. It depends on how old the motor is and how much wear the commutator has had. New motors are not cheap, though. It's your choice!
Hopefully it's the belt!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
May 07, 2011 | Whirlpool LHW0050PQ Front Load Washer
Whirpool Washing Machine Front Loader. The
you can get your bearings by way of removing back cover first.
Aug 09, 2009 | Washing Machines
Strange noise upon initial start-up
try these
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
Jun 01, 2009 | Whirlpool LHW0050PQ Front Load Washer
Reset Whirlpool washer LHW0050PQ
Usually the computer resets if you unplug the machine for 5 minutes.
Nov 20, 2008 | Whirlpool LHW0050PQ Front Load Washer
Washin Machine Spinning Problem
The main tub bearing is stuffed, thus the noise. The spindle becomes loose and the belt rides off. Bearings can be replaced.
Hope that helps.
Sep 07, 2008 | Hoover AL130 Front Load Washer
My washing machine do not spin
Do you have a direct drive or belt drive washer?
Oct 26, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool LHW0050PQ Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
