Question about Marantz Audio Players & Recorders
Marantz tuner no power - Marantz Audio Players & Recorders
  • 1 more comment
  • mcmullon May 29, 2008
    it is marantz st 26L tuner and is completely dead no hum or sisplay
    it is a marantz st 26L tuner
  • ABRsvcs May 11, 2010
    Can you post the model number please?
    Thanks,
    Dan
I had the same problem.
Just resolder the primary winding of the transformer on the PCB.
Works fine again
Posted on Jul 30, 2008
How can I connect an equalizer to my Marantz sr-66 ?
Does it have a loop through connection that is before the amplifier section of the tuner? If not I'm not sure you can. If so then you need to connect the equalizer in this section of the tuner.
The owners manual should be able to tell you more than I can find on Google
Oct 07, 2014 | Marantz Sr-66 Audio Video Surround...
Marantz tuner 120 stereo light will not come on,
Probably it is suffered by over aging. You need a skilled repairman.
Oct 01, 2014 | Marantz Audio Players & Recorders
How do I connect my marantz pm8200 to TV
You can connect TV RCA outputs to any line input e.g. tape, tuner, CD etc on the Marantz. If your TV doesn't have separate RCA outputs use a 'scart to RCA audio outputs' adaptor... TVs have a standard line output level compatible with most if not all hi-fi.
Aug 12, 2014 | Marantz Audio Players & Recorders
Marantz Legacy Series - no sound is getting to speakers from tuner or cassette.
It seams like the amplifer is not working and you are right but it certanly needs to be measured first.
Nov 28, 2013 | Marantz Tr 2242 Sb Legacy Series Pll...
My antenna jack on a marantz sr5500 broke. how do i replace it and where can i find one
If you still have the connector and if your Tuners board is not broken, you can solder it back on if you are careful. If not replace the whole tuner.
Part# 90M-AV000350R
Jun 21, 2012 | Marantz SR5500 Receiver
Tuner will not change chanels line inside broken
Tuner strings are available online, there are several vintage suppliers
Mar 06, 2012 | Marantz 105 Tuner
Marantz SR870 tuner not working
Make sure your FM antena connection is good. A receiver will not pick up an FM signal without an antena. Even a small piece of wire will work to test. If the Tuner section is bad, an external tuner can always be connected to an Aux input. Due to cost, it may not be cost effective to repair this unit.
Hope this helps.
Oct 08, 2009 | Marantz Audio Players & Recorders
Tuner problem
The numbers you list are Marantz numbers. Given this unit's age, there is a possibility that these are germanium transistors which are no longer available. I will look up your specific model's service manual, but it would help to know the location of the transtors in question here.
Keep us posted and look back in a few days.
Dan
Apr 02, 2009 | Marantz Audio Players & Recorders
Stereo connection
Hi spanky
Sorry for the delays in getting back to you. Been busy here this week.
OK. to connect the 2275 to the 1152,there are 2 ways of going about this.
You can plug the pre- out of the 2275 to the power amp-in of the 1152. In doing this you are using the power amp section of the 1152 and the preamp functions of the 2275. Your other gear like CD player, tape deck and so on also plug into the 2275.
the other(better) way is to plug the pre-out of the 2275 into the tuner inputs of the 1152, leaving the volume at about 40% on the 2275 and use the 1152 as an integrated amp. This means you are using the 2275 as a tuner only. When you do this, you will need to use an RCA lead to jumper the pre-out/poweramp-in connections on the back of the 1152, and the 2275 ... L to L and R to R respectively.
I am still wondering why you want to use 2 integrated amps (each having a preamp and a poweramp section) The only real benefit the 2275 brings to your system will be tuner functions. You could just get a tuner and run the 1152 to be an ideal rig.
Let me know what your ideal setup you are wishing to build would have. Speakers, other gear like CD, tape deck, etc.
regards
robotek
Jul 23, 2008 | Audio Players & Recorders
108 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
