Question about Kenmore Refrigerators
The ice cubes and water stink. I don't think our refrigerator has a filter either. It is a Kenmore model# 363.9522750
  • 254 Answers
Check to see how your water storage tank looks, it is located in the back wall of fresh food section behind the crispers. It may need to be changed, if it looks clean you may need to install an inline water filter in the supply line to the refrigerator.
Posted on Oct 07, 2010
Ice stinks in bottom freezer ice maker
is it the ice that stinks or is it something that's in the ice maker that is causing the smell.
Nov 06, 2016 | Kenmore Refrigerators
Low water pressure & ice maker problem
Hi! you don't say how old the refrigerator is, but if it has a water filter, the problem may be that the water filter needs replacement. If there is a water filter, it may be inside the refrigerator side, usually up top towards the back.
If you see a filter, you can buy a replacement at Sears. While your there, check out their water filter subscription. They'll send a water filter to your house on schedule, so you can replace it when needed.
Oct 28, 2013 | Kenmore Refrigerators
Ice maker won't make ice after changing water filter
Have you tried adding a bit of water to the ice mold? Is their an ice cube stuck in the ice mold? If you have an ice cube stuck in there just heat the im with a hair dryer till the cube clears and fingers go around. Listen to see if you hear water going into the mold.
Oct 08, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Small ice cubes
The water is not reaching the ice maker in a sufficient quantity. If you have a water filter, change it. Thank you.
Sep 17, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
ICE CUBE MAKER SMELLY ICE CUBES
your model will have a filter for it. it is located usually on the fridge side torwarss the top back of the fridge. it sounds like you need to replace the filter. it needs to be replaced every 4 monthes or so to keep the water clean. also you may put some water in a cup from the tap/faucet and make sure it is not the water it's self. if it is you may want to think about also having a water filtration system installed in your home.
Jan 07, 2009 | Refrigerators
Dispenser problem
nope. if your ice maker is making ice, then there is no problem with your water filter.
i'm thinking you have a problem with the micro switch that is being triggered when you press the dispenser. or the board where it is attached to choose from water to crushed or cube...
either one of those but definitely not the water filter.
tnx 4 using fixya,
drcool
Oct 31, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Hello margrek
Welcome,
YOU SAID, YOU HAVE KENMORE ELITE BOTTOM FREEZER WITH ICE MAKER THE ICE CUBES SMELL HORRIBLE ALWAYS, I EVEN TOSS THEM OUT EVERY FEW DAYS, STILL SAME PROBLEM
Ice has bad odor and taste.
1• Ice has picked up odor or
flavor from strong food stored
in refrigerator or freezer.
2• Water running to ice maker
has poor taste or odor.
3• Ice not used frequently enough.
4• Cover foods tightly. Discard stale ice. Ice maker will
produce fresh supply.
5• Add filter to water supply line. Consult a water purifying
company.
7• Discard stale ice.
Huuum
Please remember to leave a rating!
Oct 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Bad water & ice cube taste
then change your filter. the new filter could be different with the old filter. check the new filter, see if there is odor removal and taste removal with it.
if not then get the filter with carbon filter, odor and taste removal.
then with a new filter, run about 5 gallons of water before using the water for drinking.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker quit making ice
your refrig has a built in bypass in the filter housing so yes it will work with out a filter in place. if you have not replaced your filter in the last 6 months that is likely the problem. Hollow cubes are usually a sign of not enough water getting into the icemaker then it cycles too fast and harvests hollow cubes.
when the hollow cubes fall into your bucket they bust and put water in with your cubes freezing them together. so by solving your water supply problem you'll solve most of your icemaking issues..
Dec 19, 2007 | Kenmore 64802 Top Freezer Refrigerator
No water and ice cubes
Check the water valves in back of frig. and see if working.. make sure you got a water supply valves may be plugged
Oct 05, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
60 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
