Question about Acer eMachines eM2501162 Netbook
When I turn it on it says I need a system password
  • 393 Answers
Enter 3 time wrong password if system give u a 5 digits code then send me that code ill send u password thanks
Posted on Oct 08, 2010
System=intel Celeron D W3507 When I turn it on it goes straight to a black screen asking for a system password I've tried every password I know but I can't get in please help
If you don't see windows, then it's a BIOS password, and you would know if you set one. Unplug it and hit the power button, then touch metal, and pull the battery out for ten minutes. After you put the battery back in the motherboard, and plug it in you need to hit delete at start and enter the BIOS to set the time and date, then move over to exit and save changes.
Mar 30, 2013 | Computers & Internet
Need layout of the C521 motherboard where is the BIOS password reset
Hello Brenda,
Click the link below to download the Dimension C521 Service Manual.
C521 Service Manual Clearing Password Settings
  1. Turn off the computer.
  2. Disconnect any telephone or telecommunication lines from the computer.
  3. Disconnect the computer and all attached devices from their electrical outlets, and then press the power button to ground the system board.
    To guard against electrical shock, always unplug the computer from the electrical outlet before removing the cover.
  4. Remove the computer cover.
  5. Locate the 2-pin password jumper (PSWD) on the system board and attach it to pins 1 and 2 to clear the password.
    When the computer ships from the factory, the jumper plug is attached to pin 1.
  6. Replace the computer cover.
  7. Connect the computer and monitor to electrical outlets and then turn them on.
  8. After the Microsoft Windows desktop appears on the computer, shut it down.
  9. Turn off the monitor and disconnect it from the electrical outlet.
  10. Disconnect the computer power cable from the electrical outlet, then press the power button to ground the system board.
  11. Remove the computer cover.
  12. Locate the 2-pin password jumper (PSWD) on the system board and attach it to pin 1 to re-enable the password feature.
  13. Replace the computer cover.
  14. Connect the computer and devices to electrical outlets and then turn them on.
    Thank You,
    Dell-Jesse L
    Dell Social Media and Communities
    Follow Dell on Twitter @dellcares
Mar 28, 2013 | Dell Dimension C521 PC Desktop
How can I reset my system password?
Disabling a Forgotten Password
If you forget the system password, you will be unable to operate the system until disabling the password. Disabling the password involves going inside the computer and changing a jumper setting (twice) on the system board.
To disable a forgotten password, perform the following steps:
  1. Turn off the system and remove the cover.
  2. Move the jumper plug on jumper A to pins 2 and 3 to disable the password(s).
  3. Turn on the computer. Powering up the system with jumper A set to the disabled position erases existing password(s). Before assigning a new system password, you must reset jumper A to the enabled position.
  4. Turn off the computer.
  5. Place a jumper plug on pins 1 and 2 of jumper A to enable the password features.
Dec 28, 2012 | Dell Latitude E4300 Notebook
Help to restore the computer to normal (Bios Password)
RTM - Read The Manual
I found the info below in your manual online. You will need to reset the jumper on the motherboard to remove the password.
Admin Password (Not Set default)
Displays the current status of your system setup
programs password security feature and allows you to
verify and assign a new admin password. The Admin
Password may be disabled by a jumper on the system
board.
Get online and got to www.google.com In the google search box type: "Dell Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Look for Manuals and search them for Passwords.
Clearing Forgotten Passwords (the manual shows a picture of this)
1 Remove the computer cover.
2 Locate the 2-pin password jumper (PSWD) on the system board. By
default, Pin1 and Pin2 should be connected. You will need to remove the
jumper and boot the system, as follows.
3 Remove the jumper.
4 Replace the computer cover.
5 Connect your computer and monitor to electrical outlets, and turn them on.
6 After the Microsoft Windows desktop appears on your computer, shut down your computer.
7 Turn off the monitor and disconnect it from the electrical outlet.
8 Disconnect the computer power cable from the electrical outlet, and press the power button to ground the system board.
9 Open the computer cover.
10 Locate the 2-pin password jumper (PSWD) on the system board and
attach the jumper to reenable the password feature.
11 Replace the computer cover.
NOTICE To connect a network cable, first plug the cable into the network wall jack and then plug it into the computer.
12 Connect your computer and devices to electrical outlets, and turn them on.
NOTE This procedure enables the password feature. When you enter system setup (see "Entering System Setup" on page 79), both system and administrator password options appear as Not Set meaning that the password feature is enabled but no password is assigned.
13 Assign a new system and or administrator password. Replace the computer cover.
NOTICE To connect a network cable, first plug the cable into the network device and then plug it into the computer.
14 Connect your computer and devices to electrical outlets, and turn them on.
Apr 23, 2012 | Dell OptiPlex 330 Desktop Desktop Computer...
I don't know how to make my console safety off because i have forget it's password.
Here's what you need to do:
Turn on your xbox, go to System Settings. From there go to Console Settings. A window should appear that asks you for your password. If you don't know your password, then make up something. It will tell you your password is incorrect, click Reset Password".
You'll need to type in: YrYa
If this fails, then you need to follow these steps to reset your factory settings.
Turn off your xbox. Take your hard drive out (the bulge on the side of your 360. It says HDD on it.) by pressing the gray button, and sliding the piece out. Turn on your xbox, go to System Settings - Console Settings - System Info.
Press these buttons IN ORDER:
LT RT X Y LB RB Y (using the left joystick) go right ONCE A
After all of this is completed, a window should appear asking you if you would like to reset your system settings, press yes!
After all of this is completed, you'll need to turn your xbox off, put the hard drive back in, and turn it back on.
I JUST had this problem, and this is what tech told me to do... and it worked.
Good luck! Down with passwords!
Mar 05, 2011 | Microsoft Xbox 360 Elite Console
Xbox360 password recovery or reset
Nov 25, 2009 | Microsoft Xbox 360 Console
I forgot the power on password
Is this a BIOS password? In other words, are you asked for a password immediately upon turning on the computer? If yes, then it depends on the make/model of the laptop whether you can fix this yourself. In any case, you would need to call Compaq tech support.
Nov 21, 2009 | HP Compaq dc5100 PC Desktop
I need the administrater password to my dell inspiron 1525
You said that whe you first turn ON it is a BIOS password, not a wondows password?
Sep 20, 2009 | Dell Inspiron 1501 Notebook
I need to remove the administrators password for Dell Inspiron B130 service tag ends in 595B
Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabled
Go to: http://dell-inspiron-b130-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
May 28, 2009 | Dell Inspiron B130 Notebook
I am having the same problem as this soloution right here my toshiba turns on and the i get a black screen with a password to enter but dont no it need help please and thank you martialway@yahoo.com
i think that's a hard drive password screen or a bios password screen. you might need to call the manufacturer of the system, they have a password that can remove that password from the system.
May 06, 2009 | Toshiba Satellite A135-S2276 Notebook
Acer eMachines eM2501162 Netbook Logo
53 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
