Question about Holmes Products Holmes Patton High-Velocity Fan - Gray
Needc to replace three speed switch for portable house fan.
  • 447 Answers
Try contacting the company that built it, on line. There are shops around that repair items like yours. Try an electronics store, ie- Radio Shack
Posted on Oct 08, 2010
The fan operates correctly, but I cannot get the lights to work. There are 4 candelabra bulbs. The bulb receptacles have 110 VAC on them. Once bulbs are installed, the voltage to bulbs drop out.
There are two ways that ceiling fans are wired.
1. you turn on the wall switch and then you have one pull for the light (on and off), one pull for direction (clockwise, anti-clockwise) and one pull for three speeds and off.
2. you turn the wall switch on and the light comes on. There are two pull switches one pull for direction and one pull for three speeds and off.
Check your wiring from the installation instructions, the wiring in the ceiling.
Sep 29, 2015 | Dryers
How to replace fan 3 speed switch in hampton bay ceiling light
Remove the switch housing from the fan with a Phillips screwdriver. Depending on the model, there are either two attaching screws on the base of the switch housing, or three screws around the upper rim of the housing. Once the screws have been removed, unscrew the brass finial surrounding the chain on the outside of the switch housing and pull the chain through to detach the housing from the fan.
Insert a thin flat headed screwdriver into the slot next to each wire; twist the screwdriver and pull the soldered ends of the wires out. If the wires are connected to the terminals with screws, undo the screw a few turns and pull the terminals out from under the screw heads. Undo the two screws holding the switch to the fan and remove it.
  • Take the old switch to the nearest electrical or home improvement outlet and buy an identical replacement part. If there are two similar switches and you're not sure which is the right one, describe the fan to a sales assistant and tell him how many operating speeds it's equipped with.
  • ceiling light
  • May 27, 2012 | Hampton Bay 52 In.Carriage House II in...
    I REPLACE SWITCH 77075 now IT HAS ONE SPEED IDID ONE WIRE AT TIME WHAT IS THE PROBLEM
    I don't know your specific fan or switch.
    Following link is TYPICAL illustration of 3-wire fan switch wiring:
    http://waterheatertimer.org/images/Fan-motor-1-500.jpg
    Three way switch is designed to match TYPICAL fan motor windings.
    Motor windings are insulated copper wire wrapped around metal fan housing, similar to electromagnet you can make by wrapping wire around a nail.
    Inside the fan motor are two windings.
    Winding 1 for low speed.
    Winding 2 for medium speed.
    And when both windings are combined, that makes high speed.
    You have to test your switch.
    Usually the hot lead connects to red. So the red connects to each of the other wires.
    Then pull the chain and use continuity tester between red wire and other wires to see how the switch is set up.
    Jun 27, 2011 | Westinghouse Electric Westinghouse...
    Hampton bay fan pull chain broke. The electrician took the light kit down and all four wires had come out of the pull switch he could not install replacement switch without knowing which wires went to...
    1. Open the switch housing of the fan. This is usually achieved either by removing two screws on the bottom cap of the switch housing, or three screws on the side. Remove the pullchain assembly by unscrewing the brass finial on the outside of the switch housing.
    2. Make careful note of which wires attach where to the pullchain. The chain itself will be marked L-1-2-3 or A-B-C-D or similar, the wires will customarily be of different colors, but if not, mark both the wires and pullchain if necessary. MAKE CAREFUL NOTE OF WHICH WIRES ATTACH WHERE. Every fan is different and if you do not make note there will likely be a complicated guessing game. I cannot stress this step enough. Make careful note of which wires attach where to the pullchain. For example:
    Black - L, Grey - 1, Brown - 2, Purple - 3.
    Some fans may use only two or three wires, some may have a pullchain with two layers and five or more wires. Regardless, make careful note of which wires attach where.
    3. Remove the wires from the pullchain. In some cases they may be attached via wire nuts, in which case, remove the wire nuts. However in most fans the wires are inserted directly into the pullchain. Don't make the mistake of cutting them, they can be removed completely by inserting a very small flathead screwdriver into the slot next to each wire. You will notice the ends of the wires are soldered, this is so they will attach to the pullchain.
    4. Determine the correct replacement pullchain. This is the tricky part. Many pullchains look alike but in fact switch differently. There are a few factors, first of all, how many speeds does the fan have as controlled by the pullchain? Second of all, how many wires are used to connect the pullchain? These will determine maybe 75% of replacement pullchains. Here are some examples:
    - If the fan has three speeds and the pullchain has four wires, it is most commonly a L-1-2-3 pullchain. This is a single pole triple throw switch with an off position. It connects the power from L to 1, 2, or 3 respectively, one for each speed.
    - If the fan has three speeds and the pullchain has three wires, it is an L-1-2-1+2 pullchain. This is a single pole double throw switch with an off position and a "both" position. That is to say, in connects power from L to 1 or 2 respectively, and on the third position connects to both. This is the same switch used in many lamps to switch on one bulb (or set of bulbs), the other, or both.
    - If the fan has two speeds and the pullchain has three wires, it is most commonly a L-1-2 pullchain. This is a single pole double throw switch with an off position. It connects the power from L to 1 or 2 respectively.
    - If the fan has three speeds and the pullchain has more than four wires, there are a handful of different pullchain possibilities however most hardware stores stock the most common replacement. This would customarily be a double pole switch with two layers of wires attaching.
    The replacements mentioned above are the most common examples . . . but as I said, there are other switches that may appear identical (for example three speed fan, four wires, but it's NOT the first switch I mentioned). In most cases I would first try the replacement mentioned above. These are the switches that your local hardware store should stock. If the fan does not work with the likely replacement, does not work on all speeds, spins too fast, too slow, etc . . . and you are sure you properly noted which wire connected where on the old pullchain and wired the replacement correctly . . . then it appears your fan is in the 25% that uses a non-standard switch. There are three ways to determine the correct replacement switch:
    - Contact the manufacturer. If they are still in business they can theoretically send you the correct replacement switch. If they are no longer in business, contact someone on our forums or other ceiling fan experts, we/they may be aware of the correct replacement for your particular model
    - If you can still switch speeds on the old pullchain, use an ohm-meter to check for continuity between the various wires on the various positions. In most cases the important relationships are between L and the various other positions, for example a three speed four wire switch might be L-1-2+3-3. This means in the first position L connects to 1, in the second position L to 2 and 3, in the third position L to 3, fourth position off.
    - If you can not operate the switch, you can open up it's plastic casing, either to operate the switch by hand, or to observe the metal bands inside. Some websites that sell replacement switches offer diagrams of the metal bands, by matching your switch up to the diagram you can determine the correct replacement.
    5. Ok, you've determined and obtained the correct replacement switch.Seeing as you made careful note of which wires connect to where on the old switch, reconnect the wires in the same manner to the replacement switch. If your old switch did not require the tips of the wires be soldered you may need to do so in order to properly attach them to the pullchain.
    6. Reattach the pullchain to the switch housing and replace the finial. Replace the switch housing cap with the two or three screws.
    Additional Notes:
    I. Fan lights where the pullchain is simply on/off use a two wire pullchain. This pullchain is a very standard on/off switch and it is simply connected to the two wires to which the old pullchain was connected. The wires can be reversed and it will still work. Lights where you can select one bulb, the other bulb, or both use the pullchain mentioned with that example above.
    II. Some fans do not use the pullchain to control speeds, but instead have a dial or other control on the fan for speed selection. The pullchain is used to turn the fan off and on, and in some cases also to reverse the fan, select between the high speed and the various low speeds derived from the speed control, or also control the light. In these various examples:
    - When the pullchain only switches the fan on and off, it most likely has only two wires and is equivalent to the light kit pullchain mentioned above. It is a basic on/off switch
    - When the pullchain reverses the fan or switches the speed control in and out of the circuit, it is most likely the three wire two speed pullchain mentioned above. It is a L-1-2 switch. There are some exceptions such as certain model Fasco fans.
    - When the pullchain controls both the fan and light, it is the three wire three speed pullchain mentioned above. It is a L-1-2-1+2 switch.
    III. If for whatever reason you do not know which wires connect to which locations on the pullchain, you may yet have some options. For starters, black is almost always L. Some other common color combinations:
    For many four wire pullchains:
    L - Black, 1 - Grey, 2 - Brown, 3 - Purple
    L - Orange, 1 - Black, 2 - Yellow, 3 - Purple
    L - Black, 1 - Grey, 2 - Brown, 3 - Green
    L - Grey, 1 - Yellow, 2 - Purple, 3 - Black
    L - White, 1- Black, 2 - Blue, 3 - Yellow
    For many three wire pullchains:
    L - Black, 1 - Blue, 2 - Red
    May 02, 2011 | Vacuums
    I have a Casablanca New orleans fan that I just had fixed by an approved Casablanca repair place. The fan is and always has been connected to a dimmer switch. After a repair of a simple flywheel, the fan...
    Hi, is this fan an older fan with the dimmer type control on the fan itself, (and you have a wall speed control in addition to) or is it the later fan with a three speed pull chain control? If the latter, the service rep may have accidentally placed the fan on Medium speed which due to additional capacitance from the speed control board in the switch housing, could cause the symptoms you describe.
    Thanks, Brian
    P.S. That's an $$$$ fan, glad to see you had it repaired instead of replaced.
    Aug 29, 2010 | Dryers
    I have a hampton bay ceiling fan which will only run on the fast speed. I have changed switches but still only the fast speed. I have touched each wire to the load wire to see if it was the swith but no...
    Hello Brother,
    Installation:
    Hang your ceiling fan on the Quick Connect fan bracket and wire the ceiling fan according to the manufacturer's instructions. The three wires coming from your ceiling should match the three wires coming from your ceiling fan: black (positive or hot), white (neutral or negative) and green (ground wire).
    Use the high, medium and low keys on the remote to adjust the Hampton Bay fan speed, then use the light key to dim the light and the off key to turn off the fan.
    For REMOTE CONTROL FANS you cannot use with any variable speed or slide wall switches. The remote control function must be used with on & off switch outlets only.
    Speed Controls Click here Capacitors Link
    I hope This Helped you,Thanks for Contacting FixYa...
    Apr 22, 2010 | Hampton Bay Heating & Cooling
    Need a replacement capacitor
    Voltage rating doesn't matter. 250v or 330v will work.
    If this is really a 2 speed original, with the 2.5Amp motor... it will NOT have a capacitor as the motor is a shaded pole unit. The three speed electrically reversible fans, have a capacitor, which can either be in the switch housing/ oil reservoir, or the top of the motor housing, depending on year of manufacture.
    Oct 24, 2009 | Hunter 23852 Classic Original Ceiling Fan
    Want to install Fan and light control from one switch.
    'define control'
    anyway, that all the lights work together makes it simpler
    most fanlights, updated by homeowners replace a lamp only unit, with on/off provided at the switch, and cable pulls on the unit to change speed direction of the fan
    my favorite is paired dimmer switches, giving control separately of light and fan speed, fan direction still changes on the pull switch, requires 3 wires in the switch box, (power and 2 switched lines), to the lamp connector and fan motor connector, any sparky can pull the extra line with fishtape along the existing cable run. easy peasey.
    Really good electricians pull three wire to light circuits, when the house is built or reno-ed. but you know how oftern that is gonna happen, 3 wire costs 3c more per foot, if there is 3 wire in the switch box -your home and hosed
    or just for speed/dimmer control a dimmer switch can replace the existing single switch. but you still have to pull the cords to start the fans
    its easy, with the caveat that you may kill yourself, or someone else, or burn the house down, if you dont do it right
    Sep 26, 2008 | AMS Lutron SFSQ-LF Skylark Slide-to-Off...
    Holmes Products Holmes Patton High-Velocity Fan - Gray Logo
    245 people viewed this question
    Top Holmes Products Dryers Experts
    Darial Jr Lasaria
    Darial Jr Lasaria
    Jay Finke
    Jay Finke
    James Coghill
    Are you a Holmes Products Dryer Expert? Answer questions, earn points and help others
