Question about Kenmore Dryers
Just replaced the ignitor in a kenmore gas dryer model 110.76652500. After reassembly I turned on the dryer and it worked for about 20 minutes then quit. The ignitor still works (it cyles no and off every 5 min or so) but dryer wont fire up.
  • Kenmore Master
  • 2,290 Answers
You have bad gas coils or a bad gas valve but most of the time it's the coils.if you just installed a new ignitor and it's glowing most likely it's the coils
Posted on Oct 07, 2010
  • Sal DeAngelo Oct 07, 2010
    the part number for the coils is 279834,you get both coils instead of getting them single
Ge gas dryer heats but doesnt dry
if the flame is lighting you have lint blocking the air flow either in the dryer or in the vent line,also if you have a flame for the first 10 to 20 minutes and then the flame doesn't light you have bad gas coils located on top of the gas valve,when the coils are bad they can work for the first 10 to 20 minutes until the coils get hot and then they fail and you'll see the ignitor glowing orange but no flame,bad gas coils.then when the coils cool down they can work again.hope this helps.you can try removing the vent line from the back of the dryer and see if the flame stays on,if lint is blocking the air from blowing out the flame won't stay lit long enough to dry the clothes.
Dec 01, 2013 | Kenmore 73952 Gas Dryer
Kenmore gas dryer #41793142300 electronic start doesnt heat up
if you first have heat and then like 10 to 20 minutes later no heat you could have bad gas coils,on most gas dryers there's a plastic cap you can pop off on the front panel so you can look in and see the ignitor,if at first the ignitor glows orange and the flame lights then after a few minutes the ignitor glows orange and the flame doesn't light you have bad gas coils,they are located on the top of the gas valve,easy to change.part number 5303931775 go here and look at part 71
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-41793142300/0582/0151200/R0310102/00005?blt=06&prst=0&shdMod=41793142300
Mar 25, 2013 | Dryers
I have a Kenmore gas dryer Model 74812200. It is no longer heating up. When I turn it on, I hear a clicking sound for about 30 seconds then it goes off. Then about a minute later I hear the clicking sound...
You would not hear the click if the ignitor was bad. It won't click until the flame sensor get heated up by the ignitor. So that tells me the thermal fuse ain't melted. I would say them coils on the gas valve are the problem. themobilian_2943.jpg
Aug 30, 2011 | Kenmore 74812 Gas Dryer
You have answered this question before but does the ignitor stay on during the drying cycle? Kenmore series 80, model 110 72822101 gas, It starts correctly, ignitor glows, gas ignites,run for 5 to 6 min....
yes..
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 07, 2011 | Kenmore 72802 Gas Dryer
I have a Kenmore Dryer, Model # 110.64952300. It will start, heat, and turn for about 20 minutes. Then it blows the fuses in the fuse box, stops heating, but keeps turning. Can you help me figure out if it...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
I would check the heating element...it probably shorts out once it gets hot and then touches metal that shorts it out...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 20, 2010 | Dryers
Kenmore model 110.72702101. The dryer ignites when you first turn it on. When the gas shuts off it does not relight when the ignitor glows. I replaced the ignitor and the radiant sensor and still have the...
if you have already replaced the ignitor and the new one is glowing white hot, not orange, and you have replaced the sensor, then the next logical part to replace would be the gas coils. hope this will help solve the problem.
Oct 24, 2009 | Kenmore Dryers
Kenmore 70 series gas dryer cycles a few times then stops
sounds like the boost and assist coils are overheating and getting week, it may be just the one, but i would replace both at the same time
doubt ignitor is your issure or regulator since thats really just an orrifice
Oct 04, 2009 | Kenmore 74602 Gas Dryer
KENMORE DRYER MODEL # 11072212100. THE DRYER GOES
that dryer has boost coils down by the ignitor. You're probably hearing some clicking down there too.....those coils go bad over time just like a light bulb and they will light the first time and generally don't after that cause they overheat. Part number on those coils is 695540 and they usually come in a set for around $20 to $30
Oct 03, 2009 | Kenmore Dryers
Kenmore gas dryer model 75291. The gas dodes not start
first, check to make sure gas present to unit, and power to the ignitor. if no power, replace timer, if power, check the ignitor for continuity, if open, replace. If ok, check to make sure none of the thermostats are open, if they are, replace. If ok, check gas valve solonoids, they should not appear melted or stuck, if so replace. If still no function, replace gas valve.
Jun 30, 2009 | Dryers
Inglis gas dryer heat loss
It sounds like you have an intermittent gas valve. The ignitor is calling for heat however the gas valve doesnt want to open.
Make sure you turn off the gas and unplug before replacing.
Check for leaks after you reassemble.
Aug 21, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryers Logo
173 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
