Question about Acer Aspire 3610 Notebook
Acer Aspire 3610
I'm having an intermittent problem. When I power up and get into applications the laptop goes in and out of battery mode. It sometimes will not keep charge. I can wiggle the rear power connection and I can see it flicker back to AC power. I have replaced power cord and think about replacing battery. Any suggestion or Ideas?
  • Anonymous Dec 23, 2008
    I have the same problem with an Acer Aspire One.
  • 4,234 Answers
The problem is that the power inlet jack has a bad connection on the motherboard. The way to resolve this is to remove the motherboard from the laptop and resolder the jack. This is not a repair I would suggest for the novice. If this is not repaired soon, further damage can be done to the motherboard that may not be easily fixable. Please have this repaired soon.
Dan
Posted on May 29, 2008
Acer aspire 3610 power lead transformer green light is on before plugging into laptop then goes out when plugged in.acer has nothing working, totaly dead any ideas?
If the power LED is lit before connecting to your laptop and then goes out as soon as you connect to your laptop, then you either have a short circuit in the power supply module of your laptop, or you battery is causing the fault.
Remove the battery and try again. If it powers up the battery needs replacing. If the problem is still the same then you need someone to look at the power supply module in the laptop
Mar 09, 2010 | Acer Aspire 3610 Notebook
Acer aspire 3610 graphic or battery problem?
It sounds like your backlight is damaged. On some units this can be replaced on its own. On others, it requires the entire LCD to be replaced. I'll see if I can find out which this is, in your case, and find you a part number.
Sep 01, 2007 | Acer Aspire 3610 Notebook
The screen on my acer aspire one goes blank. How do i fix?
Go to power management and increase the time or disable the stand by mode will resolve your problem.
Revert back for more assistance.
Jan 26, 2010 | Acer Aspire 3610 Notebook
I have an Acer Aspire 3610 notebook. It wont charge
How old is your battery? When you use your laptop, do you run it on just the battery or do you use your a/c adapter and battery? If you're going to use your laptop for an extended period of time, it's recommended to remove the battery and run off of a/c power alone. This helps to extend the life of your battery. Over time, using both a/c and battery will cause your battery to charge/discharge, which dramatically shortens the life of the battery.
You may simply have a dead battery.
Another alternative is that you have a bad power unit, which is what the a/c adapter plugs into on your laptop. My guess is that you most likely have a dead battery.
Oct 07, 2009 | Acer Aspire 3610 Notebook
Acer Aspire 3610 stuck in sleep mode
When you turn on your laptop do you see the P.O.S.T screen or it just remains blank? and also while booting up do you get any beep sound?
Try to boot your computer in Safe Mode by Tapping F2 (or Del in few laptops) key after pushing Power Button.
let me know what happens.
Askari :)
Mar 27, 2009 | Acer Aspire 3610 Notebook
Acer Aspire 3610 plugged in closes down
I would suggest you just plug it in and do not power on the laptop for a few hours. Then try. If it persists reboot into safe mode and disable hibernation then reboot
Dec 06, 2008 | Acer Aspire 3610 Notebook
Boot problems with Acer Aspire 3610
do you have power ? if no, check your power outlet and ac adapter first, if both of them are ok, it could be your motherboard.
if you have power but no display, this is called no post.
reseat your memory. if still not working, use 1 memory and try to put it in different ram slot. and if this is still not working, your motherboard is bad
Jul 26, 2008 | Acer Aspire 3610 Notebook
Acer Aspire 1360 + Shut down frequently
is it hot when your laptop shut off ?
if it is, try to clean you cpu fan and heatsink
Apr 23, 2008 | Acer Aspire 3610 Notebook
Aspire 3610
Your Batterys Dying/Dead/Surrendered/Knackered/ et,c.
Use your Laptop On A/C Mains power. buy a new battery.
*******FIXYA********
Thanks mike @ compurepair.
Feb 28, 2008 | Acer Aspire 3610 Notebook
Acer Aspire 3610 Notebook Logo
105 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
