Question about Sony VAIO VGN-NS110E/W Notebook
My Sony Vaio VGN-NS110D Laptop computer won’t boot up, it cycles through to a black screen with the mouse pointer there which I can move. Apparently this is called the ‘black screen of death’! I can’t do anything from here except manually shut down. I Can’t press Ctrl-Alt-Del and try and put in explorer.exe into a new task (one of the apparent solutions). I’ve pressed F8 and gone through all the options on there and nothing seems to work. I can’t restore the laptop to an earlier point as it says that none have been created. I made some recovery CD’s when I first got the laptop, but they don’t work. I don’t have a windows CD as it was bought with Windows already installed on it. Please help!
Sony vaio vgn-nr285E battery won't hold a charge
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Dec 03, 2011 | Sony VAIO VGN-NR285E/T Laptop
My Sony Vaio VGN NW225F laptop won't start up.
First thinkg I'd do is to connect an external monitor to the laptop to see if you can get an image, any image, during booting. If you can't see anything, either using the laptop's screen or external monitor, then you have a hardware failure in the laptop that's probably beyond the abilities of a novice to repair. Get somebody who knows about how to clear the CMOS of the laptop.
Nov 08, 2017 | Sony Computers & Internet
Hi, machine boot up but I can't go to desktop. I can see a mouse pointer and it moves. But the screen is just black. My anti virus is active.
My guess is it's more than likely a windows 7 machine?
Turn on the computer and hold down the F8 key to access a DOS menu.
Enter the laptop through Safe mode.
Once Windows safe mode starts, go to accessories in the start menu, then system tool, then system restore and attempt to restore your system to a date listed before when this began.
Windows 7 seems to be a good operating system for restores.
Chances are it IS a virus/Spyware and unless you know which to use these days, the big names will always fool you.
Mar 02, 2011 | Sony VAIO VGN-CR220E/P Notebook
My Sony Vaio VGN-NS110D Laptop computer won’t boot up, it cycles through to a black screen with the mouse pointer there which I can move. Apparently this is called the ‘black screen of death’! I can’t do...
Try these 1) Shut down the system 2) Remove the battery 3) Hold down the power button for say 2 minutes 4)Put the battery back 5) Boot the system
If you still hit the black screen with a cursor: 1) Wait for 2 mins at the black screen 2) Just type in your windows password (if you don't have one hit enter) and press enter 3) Wait for another 2-3 mins 4) Hit Alt Ctrl Delete and go to task manager (this time it should take you to the task manager) - fingers crossed LOL 5) Now do new task - explorer.exe
Hopefully you should be back in action.
Note, this is a work around and for a permanent fix either try and clean your system (check for viruses) or reinstall the system. Hope this helps.
Oct 07, 2010 | Sony Computers & Internet
When i power up my vaio and enter my password, theres a black screen with no icons but i can see the mouse and i could move the mouse... please help?
Hi, try booting in safe mode by pressing the ESC key during boot up, you will have the option of resetting your operating system to a time before the problem started. Or you can insert your CD which came with the PC and restore windows from there. Both of these options should not effect any saved work on your PC. Hope this helps, come back to me if you need more help.
Jul 15, 2010 | Sony VAIO VGN-NS110E/W Notebook
VAIO VGN-FZ210C/E 15.4" Widescreen Laptop Computer PC Notebook: hello in my laptop i.e.sony vaio vgn-fz210c full o...
It is better to perform the Recovery...
The Computer is having the Recovery Partition in it..
to access it and perform the Recovery..
Restart the Computer, tap the F10 Key...
Then at the "Edit Boot Options" screen, press the Enter Key..
Then, select the VAIO Recovery Center....
further instructions are here..
May 18, 2010 | Sony VAIO VGN-FZ210C/E Notebook
Sony vaio vgn nr490e no boot only humming / spinning sound and black screen with faint vaio on it
sounds like the backlite for your monitor needs to be replaced. (like the lightbulb went bad) These can be replaced usually, for under 100 dollars.
Apr 07, 2010 | Sony VAIO VGN-NR490E/L 15.4" Laptop
Scrolling/cursor problmem on Sony Vaio VGN-C140G laptop
Im having a similar problem , have you got it fixed yet? I really need some help the scrolling feature on my Vaio VGN - FZ31S does not work at all and I have tried everything.
Feb 20, 2010 | Sony VAIO Notebook
The mouse is frozen in my Sony Vaio VGN-NR180E . It won't move .It also looks like the screen is locked.It feels like my mouse is locked. Thanks so much for your help!
Restart the computer-
Plug up a USB mouse to see if that doesn't work
Your touch pad software may not be installed. Goto Sony's device driver support page and download the mouse drivers for your model. Sony has good software support. You'll find the touchpad program easy. Reload and see where that puts you.
Nov 11, 2009 | Sony VAIO VGN-NR180EW Notebook
Sony Vaio Laptop boots but no display except mouse pointer
It could be the hard drive going bad but it also could be a virus. I would formatt & do a clean OS install.
Dec 31, 2008 | Sony VAIO VGN-FS690P Notebook
Sony VAIO VGN-NS110E/W Notebook Logo
387 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
