Question about Carrier 38BRC048 Air Conditioner
Carrier Air Conditioning
I have to pull the disconnect on my AC since I had a blower fan replaced a couple of months ago. I know one has nothing to do with the other, but when the tech was changing the motor he had to remove the mother board to access the motor. I wonder if he could have possibly moved one of the dip switch's. There are no codes and the compressor outside will run continuously even when the furnace is on unless I pull the disconnect. I noticed this about a half hour after the tech left. He would not come back unless he could charge a service call even if it was his fault! It should be something simple, it was working fine before except for some blower motor noise.
  • JPE1 May 30, 2008
    Thanks, I have not had a chance to try anything yet. I'll try as soon as I get home. JPE
    Problem Solver:
  • 5 Answers
Have the tech come back. the problem did not exsist before he pulled the board. He either left his jumper wire connected by misteak or he shorted the wires to get the fan come on so he could check the operation. Either way he created this mess and is responsible. Most service techs would return and fix his problem just out of pride in his work. If this guy will not return then contact the BBB and the licesing board for the state you live in they have an investigative unit just for guys like this. good luck
Posted on Sep 19, 2008
WE HAD A FOUR ZONE CARRIER COMFORT ZONE SYSTEM INSTALLED IN OUR HOME DURING CONSTUCTION IN 1993. DURING A RECENT THUNDERSTORM THE FAN MOTOR BEGAN TO RUN AND A "HF 41" TROUBLE CODE APPEARED ON THE SCREEN. WHAT DOES IT MEAN? THE HIGHEST ERROR CODE IN THE BOOK IS HF 33. THANKS DON
Posted on Jun 26, 2008
    Scholar:
  • 54 Answers
I've never seen a bad control board cause this fault. The condenser is controlled by a relay in the outdoor section which in turn is controlled by a 24v signal from the control board. It's possible the contacts on the relay in the outdoor section are frozen in the closed position- whatever caused the control board failure could have also caused the relay failure but it wouldn't be evident until much later unless the technician looked for that specifically. It's also possible that there was a simple wiring error was made and the relay was connected directly to (C) and (R) on the control board, bypassing the control circuit entirely as foolish a mistake as this would be I think it's at least as likely if not more so than frozen contacts on the relay. I can't imagine any two wires very likely to short and cause this failure other than red and yellow from the control board, possible but I would think unlikely. Simple test- turn power off at the breaker to the indoor section If the out door condenser continues to run Its the compressor relay. If it does not I would investigate the wiring on the control board If the wiring is correct then change out the control board after discovering what caused two control boards to fail.
Posted on May 31, 2008
  • 1,420 Answers
If the outside unit runs continually, check your thermostat and make sure there is no call for A/C. Inspect what thermostat wiring you can find and look for wires that may be touching together. On the outside unit, remove one of the 24 volt thermostat wires from the control and see if the unit stops running. If it does, you either have a short somewhere or a bad control board in your air handler.
Posted on May 30, 2008
Fan doesn't work in heat mode it works on all other functions. Heat does come out but fan doesn't kick in. Outside unit is operating
AC inside fan doesn't come on AUTO - DoItYourself.com Community Forums
www.doityourself.com > ... > Air Conditioning and Cooling Systems
Jul 21, 2004 - The inside FAN doesn't run when in AUTO mode. If I leave ... Is the thermostat not working correctly or something in the AC unit causing it to do this? Thanx ... The unit is electric central air-conditioning(heat and cool). It made ... Carrier A/C condenser fan not working
Jul 27, 2012
Heater Fan Doesn't Work on AUTO
Jan 23, 2006
Blower doesn't work in ON position after repair
Mar 25, 2005
Central AC/Heat, Blower Doesn't work on Auto
Nov 30, 2004
More results from www.doityourself.com
Nov 01, 2015 | Heating & Cooling
Is there a fuse that run the air condition inthe honda odyssey 2006
Hondas all have a fuse and blower relay located in the battery junction block. You can try swapping relays around if the fuse is good. Then verify the blower motor is good by disconnecting it and applying 12v directly to the motor. If this checks good, check for 12v at the blower connector while disconnected, (key on/fan on). Had a CRV in the shop a few days ago with the exact same issue, power to the motor but a weak ground signal. Replaced the blower resistor.
Jun 13, 2014 | 2006 Honda Odyssey
The blower in my Ruud gas furnace won't shut off. It just runs and runs. The thermostat is set to "off" and the fan switch is set to "auto". We haven't used the furnace or AC the past few months since we...
I'm not sure what setup your unit has but the fan relay sound like it is bad. If your blower connects to a circuit board then the board could be bad. Different units use different ways to control the fan. Some use a relay like I mentioned. Some use the circuit board (newer units). Some even use a sequencer. The first step will be finding what yours is using. Since you tried disconnecting the green wire from G already and it didn't cut off I would think your thermostat is not the problem. Let me know what you find.
Aug 15, 2010 | Ruud UAKA037 Air Conditioner
Why does my AC keep freezing (Carrier FB4ANF036). I have replaced the blower motor less than a month ago due to the same problem. Just last night we had a lightening storm and shortly after that the AC...
if your system is a heat pump you can switch to heat and see if coil outside gets cold while indoor blows warm air - then switch back to a/c - both coils should not be cold at the same time - low freon pressure / dirty coil / dirty filter / low air flow causes freezing
Sep 22, 2009 | Carrier Heating & Cooling
Blower will not turn on when a/c compressor comes on - tstat ok fuses ok
You should have a fan relay on your furnace that would control your fan in air conditioning and that sounds like you are needing
May 24, 2009 | Honeywell L4064B2236 Fan/Limit Control...
Ruud central air conditioning and heat system
there is a fan relay in the unit. it is stuck and needs to be replaced
Oct 21, 2008 | Ruud Heating & Cooling
Carrier 38BRC048 Air Conditioner Logo
883 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
