Question about HP Pavilion dv4000 Notebook
Most of the programs erased , computer not functioning normaly
  • yechielschon Oct 11, 2010
    my friend wanted to deleate some files, instead what happened he erased most programs and the browser is gone.
    when you start up the laptop soon afterwords a data execution prevention from msft appers and then a svchost.exe. application error appers and also a Dr watson postmortum debugger pops up, and the system bell rings constantly. please help me. thank you
  • 6,831 Answers
Hello
OK, in order for me to give you the best possible advice, you will need to explain to me your exact problem. Just leave a comment, i will get back to you as soon as possible.
Kind regards
Andrea
Posted on Oct 07, 2010
Sony vaio e series laptop model pcg-71211w is showing some hard disc problem and not starting normaly. It starts after pressing F1....
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
May 20, 2013 | Computers & Internet
I can't find a "Print
It might be erased due to usage.
Use Function key + F11 to use printscreen option.
Please let me know if this resolve the issue, if not I can assist you further.
Thanks,
Satheesh
Jan 19, 2011 | Dell Vostro 2510 Laptop
How do I delete all the info backed up on my irocks external hard drive?
Usually hard drive disks are erasable so long as was an an empty space. However, the type of setting chosen during data encription causes the situation of erasability. For example, using an external harddrive disk as back up media storage media has specific requirements. The computer provides an integral means of least being compromised where data permanent encription may have been the options available during backup copying. The compoter provides the procedures of recording data into any connected external devices. Once the external device is reconnected to the computer, the options of requesting the user to either erase what has already been copied becomes one of the several displayable promps. Also, backup disks usually on connection to the computer assumes a necessity to restore to functioning mode. However, a least malfunctioning computer would simply display prompts asking the computer user to perform the most recent backup, or disregard because of least disfunction recognised from the system. Attempting is erase what has already been recorded becomes appropiate whenever the computer recognises any curroption of the files. A prompt is display asking to fix errors soon after connection. The computer user simple chooses to restore to default functionality the external hardrive. Amongs the options usually provided of the program prompt are format, delete, restore, or backup computer files once connection is recognised. keep in mind that, an external hard disk may be default rrecordable proving no options of erasing. Refer to the hard disk drive user guide as reference to achieve the process. Also, the user guide would have specified if the device is capable of alternations or not.
Jan 14, 2011 | i-rocks External Hard Drive Enclosure -...
Scan to email function will not work?
use the disk thad came withe lexmark and reinstal the software or you can download software on lexmark site for free also manual
or the email program you use are not compitable with the lexmark machine normaly the email client wil start up like outlook expres or outlook from the office or live mail or other email program
figiure it out or read manual
luck !!!!
Mar 23, 2010 | Lexmark X7170 All-In-One InkJet Printer
Trouble codes po340,po605.and po325 car will normaly idle and if you push the gas peddle to much it will bog out and die what could be the problem? I have put a new fuel pump in.
po325 knock sensor 1 malfunction po340 camshaft position sensor malfunction po605 internal control modular (rom) read only memory error check the wiring to the computer for proper connection and damage the computer (pcm) may be damaged or its program erased this happens sometimes when the connector is unplugged and the battery is hooked up the other two can be related (pcm) failure or could be a wiring problem po325 check knock sensor wiring and sensor and same for po340 crank sensor wiring and sensor good luck
Nov 15, 2009 | 1997 Infiniti.5 J30
Desk computer overheat
hi there,
the thermal over heating is functioning, press F4 to resume on normal function then once the windows appear go to all program,
accesories and system restore click restore point, select a date that your pc run normaly
it will restore your pc on normal function you ca experience restarting and that the point it will restore your system.If still syntom persist
reinstall your windows system.have a niceday
regards
Jul 10, 2009 | Linare Desktop, AMD Sempron 2200,40 GB HDD...
My fuji finpix s700 will not download pictures
down loading from a camera can be problimatic,
the easyest and cheepest and functional way to solve it is to get an external card reader and use that to transfer images
no to work on your sulution:
The basic thing to start with
remove batteries from your camera for a while
and reset your computer
test or replace the cable you are using and see how you go.
May 05, 2009 | Fuji FinePix S700 Digital Camera
Erasing the memory card;
All pictures in the internal memory and/or on the memory card can be erased at once. This is accomplished through either formatting or the "all-frame erase" function. I copied the following instructions from the advanced manual, which can be downloaded here: http://www.olympusamerica.com/files/d545zadvman.pdf. Adobe reader should open that file with no problem. If it doesn't, that's another issue altogether.
1. Enter playback mode by pressing the play button.
2. Press the OK MENU button.
3. Press the right arrow button (next to the lightning bolt) to access [MODE MENU]
4. Then, press the down arrow to access the [MEMORY(CARD)] tab.
5. Select the [ALL ERASE] function.
6. Select Yes and press OK MENU.
(You'll need to use the arrow buttons to navigate the menus. Please see pg 16 of the manual for instructions on how to do so.)
Note: when the memory card is in the camera, it will erase the pictures off the card. When the card is removed, the function above will erase the internal memory.
Apr 22, 2009 | Olympus D-545 Zoom Digital Camera
Card error
As long as the xD card was not formatted it is possible to recover the images that were accidently erased or unable to be downloaded to computer. You can go to the following website link and download an image recovery software program that is free of charge.
http://www.z-a-recovery.com/
You want to download a program called Zero Assumption Recovery. It is a very simple program to use and people have had much success in recovering images.
Feb 12, 2009 | Olympus FE-170 Digital Camera
HP Pavilion dv4000 Notebook Logo
13 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
