Question about Goodman Heating & Cooling
Need wiring diagram for installing new heat element in a Goodman Model A36-15 unit. 4 wires.
  • leta2002 Oct 07, 2010
    Contacted Goodman but they won't sell to non hvac tech. Any other suggestions?
    Top Expert:
  • Goodman Master
  • 80,339 Answers
We do not have any wiring diagrams for this unit, suggest u contact the manufacturer for a service and repair manual
Posted on Oct 07, 2010
  • yadayada
    yadayada Oct 07, 2010
    contact local AC repair shops, they may have the service information u need, we don't have any diagrams so we can't assist u here, sorry, but the site has few repair manuals for this type of product.
I need to know where 3 wires connect on a goodman pc036-1b rev e package unit air condtioner and central heat system.
Contact Goodman directly to request a wiring diagram for model pc036-1b, rev. e. It is important to specify rev. e.
Nov 01, 2017 | Heating & Cooling
I purchased a new Goodman AC/Heat inside and out side units, am getting ready to run the wiring to the sub panel, Not sure what wire to use from the main braker box to the sub box have found different...
http://www.encorewire.com/docs/amp%20voltage.pdf is a diagram of what size wire and type you need for different amperage. As you can see the 10/3 recommendation is good for a maximum of 30 amps in copper and 25 in aluminum.
I haven't found the CKL36AR36 installation guide, so I don't don't know which circuit breaker size you need to install. But it should be listed in your installation guide that you got with your unit. Make sure that you have the correct disconnect within 6 feet of the unit to meet code.
Jul 12, 2011 | Goodman CKL36AR36 Air Conditioner
Blower does not work and heating element heat with
Check for power to the unit. If power exists, check your low voltage. Do you have 24volts to R & C at your thermostat?
Feb 07, 2010 | Goodman GMS90703BXA Heater
Model MES5770AAB Serial 11517659WK The single element, 700 watts came with a wiring kit for a new connections. My range has "Old connection type 1" . the moddification kit (A-30001, Revision 4) shows...
Ten to one the elements will have to be changed also. Call or email Maytag about your dilema. You can simply reject to pay me also on this one
Jan 21, 2010 | Maytag Kitchen Ranges
Units heating elements wont shut off regardless of what mode is selected on goodman units thermostat model no. ar24-1
Hi, you will need to replace this thermostat as the circuitry is faulty and keeping the strips energized. The only way to check would be to pull cover from stat and expose stat wires. Power off first. Disconnect the 24 volt hot wire, red and they should shut right off. If so get a new stat. If you need further help, please contact me. Merry Christmas.
Shastalaker7
Dec 24, 2009 | Goodman CKL24AR24 Air Conditioner
Replacing old 3 wire condensor fan motor with new 4 wire
the new one needs its own capacitor 5 to 7.5 uf hook to the 2 brown wires
May 08, 2009 | Goodman CLQ36AR49 Air Conditioner
CHANGED OUT UNIT NEED HELP NEW WIRE
Is this heat pump? Straight A/C? You should have a wiring diagram with a new unit (installation manual) that will give you what you need depending on your model. They generally have a few different configs so they only have to put one manual in every unit. If it's a straight a/c, its simple. You have two wires coming off the outdoor unit. One goes to the y terminal and the other goes to the c terminal. Y is for cool and C is for common. A heatpump is a lot more difficult and I would recommend hiring a professional to wire it up so you don't burn up the defrost board. Also, you may find a wiring diagram on the inside of the outdoor cover. Hopefully this helps.
Apr 09, 2009 | Goodman CLQ36AR49 Air Conditioner
Newly installed Goodman GPG13 gas/electric package unit installed. Cannot get AC to cycle on. Unit produces heat at all thermostst settings.
new unit and old thermostat/wire? thermostat could be bad or bad thermostat wires. try putting in new of anything old. do this wiring practice with the terminals being the letters.
r- red (24 volts)
w- white ( heat)
y- yellow (cooling)
g- green (fan)
Sep 21, 2008 | Goodman Heating & Cooling
Heating & Cooling Logo
358 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
