Question about Garden
Model # 5316A, does not shut off, lights staying on 24/7 for the last week
    Scholar:
  • 150 Answers
Sounds like the ignition switch (key) is bad. You can check this with ohm meter or simply disconnect wires from back of switch and see if that cures it.
Posted on Oct 07, 2010
I have a Vizio 42 in LCD, model VO420E. The TV makes a loud screeching noise, the screen goes crazy and then shuts off and starts again. There sometimes is a pop. Other times the TV just makes the POP...
Hi well what's happening is that the "Protection circuitry" in the SMPSU has/is detecting a potentially catastrophic fault, and to stop a fire AND EXPLOSION OR INDEED BOTH, IS ATTEMPTING TO SHUT THE SET DOWN FOR SAFETY REASONS, HOWEVER AFTER IT SHUTS DOWN, THE "FAULT" APPEARS TO "GO" AND THEN THE SMPSU STARTS UP AGAIN , ONLY TO DETECT THE FAULT AND SO ON... USUALLY ENDLESSLY OR UNTIL COMPLETE FAILURE OCCURS.
What to do, well in all reality DIY is NOT feasible unless one has LOTS of experience, test gear, tools, isolation transformer, and a service manual. So, contact the local or head office from VIZO, ask them for a referral to an authorised service center, hopefully a local one? in any event, make face to face contact here and ONLY ask first for a "Quote" as to prospective costings and go from there, this way at least you can make up your mind as to repair or replace?
Sep 25, 2011 | Vizio VO420E 42 in. LCD TV
Will Not Turn On
First you need to do a self test diagnosis and then if it comes up with:
SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB
Do self test by pressing Input/Device and Menu at the same time for 5 sec. the set will show a 2 digit seq. first blinks followed by a short pause then the second.
Dec 29, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Tip
I had blinking "clean light" on my Whirlpool KUDUO3FTSS1 for the whole last...
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models dishwashers. The problem is usually attributed to water supply temperatures being too low when filling. Apparently, there are some issues with the temperature sensing circuits in some dishwashers that causes an error code to be generated if a certain water temperature is not achieved in a specified time interval (this time may differ between models). There is a reset sequence that you can try to clear the fault. Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button. This will clear any existing faults and should return the dishwasher to normal operation.
To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot BEFORE you start the dishwasher. This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line). The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits. If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is. The flashing light will be a series of flashes, followed by a pause. If you indeed have a component problem, it will depend on the number of flashing lights in the sequence. Refer to the tech sheet to determine WHAT component is affected and how to troubleshoot.
on Dec 19, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
My parents bought a Haier HBF655TEME washing machine last year december. Last week it stopped working. The door light stays on continuously when clothes are put in and the door is shut and it doesn't...
It is possible that the door switch has failed as the bulb is ON even when the door is shut . This indicates that the SWITCH is not cutt off and so the program controller will not allow the module to go forward or work. It is needed that you start from this point to use a multimeter to check the switch/ poles contact to confirm.
Jul 01, 2011 | Washing Machines
Same Problem
It is likely the battery that will need replacement. You can buy them almost anywhere on the internet.
Jul 07, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Need instructionsmotion detector #5316A.
you can download instructions just type detector # on google and type manual. that should get it.
Jun 07, 2009 | Kitchen Appliances - Others
Light timer not in sync
Try Googling (brand)(5316A)(manual) without parens.
May 16, 2017 | Hardware & Accessories
Voyager tail lights stay on
brake light switch or a headlight switch
Nov 11, 2008 | 1995 Plymouth Voyager
Hamilton Beach 87330 water cooler
Hello! About 2 weeks ago, the same problem began on my Hamilton Beach water dispenser.
Last week, I called the HB service support, and they told me to do the following reset procedure:
1. Dispense 3 cups from the HOT water side, and also, 3 cups from the COLD water side.
2. Turn BOTH back switches OFF (the ones on the back of the water dispenser).
3. Unplug the dispenser, and LEAVE it unplugged for 24 hours.
4. After 24 hours, turn the back switches ON and plug it in.
5. Leave it on for 4 hours WITHOUT dispensing any water.
...it's been about 12 hours since I've dispensed water again for the first time, and so far, SO GOOD! I'll update if the problems reappear.
Sep 28, 2008 | Hamilton Beach Water Cooler with Storage...
Garden Logo
108 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
