Question about Dryers
Fan is not working, dampers are adjusting but the fan does not seem to operate off of local switch or remote switches.
  • luke_ricky Oct 07, 2010
    The unit is a vanee 190h with bronze control.
    The fan is free to turn (not seized), but does not operate. Is the motor the likely source or could it be the circuit board?
    President:
  • 2,777 Answers
Need to know the make / model of the unit and I can help!
Thanks
Tim
Posted on Oct 07, 2010
  • Tim Grayson
    Tim Grayson Oct 07, 2010
    So is this fan working at all or no? You say it doesnt work off a local or remote switch... so that to me would mean it doesn't work at all, correct? Sounds like the motor of the fan has failed for sure. Most of the time it is much easier and even less expensive to just replace the fan.
    Thanks
    Tim
  • Tim Grayson
    Ah ok you are correct, if the motor is not seized up, should have had you check that, then it is the circuit board of the fan. Sorry about the confusion there, was reading multiple things at once and thought for some reason you had checked the motor.
    Thanks, definitely the board in your case, please accept my apologies.
    Tim
I have a 52 inch Hampton bay fan with remote control that will not work. model AC55200 SN002469B remote #G9P2BTAUC7052T. have put new batt in remote. will work light sometimes .No fan operation
This could be a defective receiver but if you are mixing wall switch operation with pull chain operation it may be getting confused. My local "big box" retailer sells complete Hampton Bay replacements for both remote control and receiver so ultimately that may be what's needed.
Dec 12, 2017 | Hampton Bay Dryers
Remote control not working
Dear Sir/madam,
Check these steps........
1. Adjusting the dip switches:
Each fan/remote combination is set to work on a specific frequency, much like tuning in a specifc radio station. Some fans allow you to set this frequency by means of a set of small switches called "dip switches". There is one set located inside the remote, and the other set would be position on the fan, with the remote receiver electronics. This would be either on top of the motor, or inside the switch housing or ceiling canopy. These switches "tune" the remote and fan (received) to the same "station" and therefore must be set to the same setting. If a fan is not responding to the remote you can check to make sure that the switches are set to the same setting in both locations, and/or try a different setting. They are also useful if you have two remote fans, you will want to be sure each fan is set different so the remotes do not interfere. Lastly, if some other wireless device is interfering with the fan (causing it to turn on and off seemingly at random) such as a garage door opener or cordless phone, you can try a different setting on the dip switches.
2. Universal remotes:
If your fan remote is lost or broken, many suppliers, including this web site, offer a universal remote designed to work with the majority of different remote operated ceiling fans. Many are also universal for operating televions etc so you can control all your leisure and comfort devices from one unit.
3. Replacement parts:
Unfortunately, outside of Universal remotes, general replacement parts are not available for remote control systems. Your best bet is to contact the manufacturer.
3a. Repair:
Also unforunately, most problems with remote controls cannot be repaired outside of what is suggested above. If you have problems, contact the manufacturer, perhaps the fan is under warranty, or parts are available. Otherwise chances are the fan will stay broken.
4. Converting to 3 speed:
One common question: My fan's remote is broken, can I just convert it to a 3 speed pullchain like other fans? Again unfortunately, if you have to ask the question, then chances are the answer is no. It can be done but there are no universal directions, it varies drastically from fan motor to fan motor, and requires a fair amount of technical and electronic skill. A few exceptions: If the fan has a "remote bypass" switch you can select it and then use a wall control (or pullchain if there is one attached to the fan). Or . . .
5. Add-on remote kits
Some fan remote systems are not built into the fan, they were an option added by the installer at an additional cost. Usually they consist of a remote receiver wired to the fan inside the ceiling canopy, and the fan will still have a pullchain that is not used. If this is the case then the receiver can be removed and replaced with another remote/receiver kit, or the fan can be operated as standard with the 3 speed pullchain.
thanks
good luck
Aug 07, 2008 | Hampton Bay 52 In. San Lorenzo, Rustic...
Where is damper door in a kenmore refrigerator model #9510681 side by side
If you can't see the damper door, it is most probably shut, possibly frozen or not working. Top of middle section, allows airflow from freezer to fridge part. Switch thermostat off, wait 20 mins, switch back on. If damper doesn't open, check stat and damper motor.
May 30, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
Hampton Bay 52-ANT
If you have a ceiling fan, they often suffer remote operation failure as a result of a power interruption. Try disconnecting the power source. Leave the local switches and chains alone. After a brief pause, apply source power again and try remote operation
Jun 28, 2013 | Hampton Bay Dryers
Changing frequency on a remotely operated Hampton Bay Celing fan
Remove battery from remote and you should see 4 small switches. Write down the pattern they are in now. Then move them to a new pattern. Then take the bezel off of the fan (where the fan connects to the ceiling). Turn the bezel counterclockwise if you don't see any screws holding it on. Now look for a set of switches that look the same as the switches in the remote. Write down their current pattern. Now Set the switches to a similar pattern as you set on the remote. If the remote doesn't work after adjusting, set them back to original positions from the notes you kept. Good luck
Jul 18, 2011 | Vacuums
Defrosted freezer and turned back on. freezer seems to work but not fridge. back wall of fridge feels warm
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Mar 22, 2011 | Zanussi Refrigerators
We have a Dometic 2310 - freezer works well, fridge seems inconsistent. Top of fridge gets very warm. Is it helpful to add a cooling fan?
Sep 24, 2009 | Dometic RM2652 Refrigerator
Refrigerator compartment cools correctly for a few days then no longer receives cold air from freezer. The freezer continues to operate and gets much colder than it should.
does your fan blow? freezers have a fan that pushes cold air to the fridge side if fan is bad freezer will run extremely cold and fridge won't cool down and since frige won't cool down thermostat in fridge doesn't tell compressor to stop
Feb 26, 2009 | Refrigerators
Dip switch settings
I've had the same problem w/ light turning on/off. Called customer support and 3x waited 6 minutes to leave message and get no call back. Finally got a human and she told me to change code in receiver and transmitter. This was no easy task as the fan is very high up and the stupid thing needs to come down to adjust the receiver. Changed the setting and it worked for two days until it started back with the lights turning on at all hours. I noticed there's a toggle switch in the remote that is not explained in the manual. It says CFL on one side and INC on the other. The light will NOT dim if it's in CFL and tonight is the first time I've switched it to that setting. I'm hoping this is some kind of lockout for random signals going out of the remote...It would be nice to have a proper explanation in the manual. I should have gone with another Casablanca fan--Hunter products are lame.
Feb 03, 2008 | Hunter 27185 Remote Control
Ceiling Fan
the start switch is bad.if you open up the fan you may see a little black looking box thats the switch.if not the switch is on the motor itself.an electric supply warehouse may have the part.
Aug 31, 2007 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Open Questions:
Dryers Logo
61 people viewed this question
Top Dryers Experts
