Question about Toshiba Satellite M115-S3094 Notebook
Your Question My Toshiba Satellite m115 will boot up but the monitor wont light up, you can see the images in the back round but the screen is dark. if i connect to external monitor the external monitor works fine. i installed a new screen on the laptop but that didn't fix the problem
  • 2,567 Answers
Diagnosis:
1. Test using an external monitor. If it works, then either the screen bulb or the inverter board might be defective.
2. Test the inverter. Easiest way to do it if you have a good screen with a good bulb. Connect the good screen to the inverter board & test it. If it lights up, then the inverter board is good. If it did not, then the inverter board is bad & needs to be replaced.
3. If the inverter board is good, then we are left with the possibility that the screen bulb is bad. To fix this, we will need to replace the LCD screen.
Posted on Oct 07, 2010
  • rhgillespie0 Oct 07, 2010
    OK it works fine with an exterior monitor and I installed a brand new screen
    same problem. where do i find the inverter board?
  • Mohamed Omran Oct 07, 2010
    Usually you could find the inverter board either under the LCD screen front cover, just below the screen, or under the front hinge cover (the panel which has the power button). It is a slim printed circuit board with a cable attaching it to the LCD screen (the LCD screen cable).
    Please refer to the following link to get an idea of how the inverter board looks like:http://www.laptopparts101.com/screen-inv...
Wont go past boot menu
your dvd rom or your disc might not working properly. there can be one more problem that you RAM is creating problem just pull out RAM and clean it then insert it and do the process again.
Feb 07, 2014 | Toshiba Satellite M115-S3094 Notebook
How to fix lcd screen , colors and image are broken.. pls help
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Mar 21, 2011 | Toshiba Satellite M115-S3094 Notebook
I can barely see the screen, its very dark. Its a toshiba satellite m115 s1061
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Sep 05, 2010 | Toshiba Satellite M115-S1061 Notebook
My dads toshiba A20-S207 has a dark monitor. Can very faintly see the windows xp logo at the beginning of boot up, so it looks like it is booting up, but the monitor stays dark. Can u help?
common LCD dark.dim screen problem, u can google keywords get more information.
either LCD inverter failure or CCFL backlight lamp failure, ask for a pro get it fixed.
by using a flashlight could you see the image on the LCD?
Dec 06, 2009 | Toshiba Satellite A20-S207 Notebook
Broken screen on laptop wont stay on external monitor when its on laptop monitor it still shows parcial screen of the desktop
Using Fn + F8 should go through 3 different positions: Laptop screen, Both screens, Ext Screen --- and back to Laptop screen, etc. This is set up in the computer's internal operating parameters and can not be changed.
Oct 01, 2009 | Toshiba Satellite M115-S3094 Notebook
Toshiba lap top screen goes blank
My laptop got problem with the interface the screen appear like gray.
Dec 15, 2008 | Toshiba Satellite M115-S1061 Notebook
Screen goes dark
Either the backlight lamp or the invertor for it is failing. I suspect the colors and contrast isn't as it once was either.
Won't boot up
A bit more info would be good. Did it shut down normal. can you enter bois. any messages???
Dec 06, 2007 | Toshiba Satellite M115-S1061 Notebook
Toshiba Satellite M115-S3094 Notebook Logo
185 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
