Question about Daewoo High Energy Efficiency Air Conditioner
I have a DAEWOO Energy Star air conditioner (I believe it is a 5,350 BTU capacity) on which one of the side accordion-like extenders - which slide out to fill the window slot -has broken. I can repair it myself but where do I find the part?
    Problem Solver:
  • 8 Answers
At an HVAC store.or just look under the title air condotion supplies and parts in the yellow pages of your phone book.i would try the second suggestion i wrote first.
Posted on Oct 08, 2010
What is m6x06f2a btu output?
Features
  • Cooling Capacity (BTU) : 6,000 BTU
  • Maximum Cooling Amps : 5.6 Amps
  • Maximum Cooling Watts : 618 Watts
  • Heating Capacity (BTU) : 0 BTU
  • Maximum Heating Amps : 0 Amps
  • Energy Efficiency Rating : 9.7
  • PTAC : No
  • Window Type :Standard
Aug 04, 2015 | Maytag M6Q10F2A Air Conditioner
NEED HELP TO REPLACE WIRES ON CAPACITOR ON GE ROOM AIR CONDITIONER 8000 BTU
with capacitors it doesn't matter which wire goes on which terminal
if it has just 2 terminals then a wire on each
if it has 4 terminals then one wire on one set and the other wire on the other set
A set is two terminals side by side
However if you are still undecided , get an electrician to fit the wires.
May 09, 2015 | General Electric GE AEM08LQ 8000 BTU...
How doest it drain on air conditioner 25379081
most window units use the condensation to help cool the condensor. some days little to any drainage. a slinger ring on outsde blade side throws water on coil and evaporates.
Jun 29, 2014 | Kenmore 8,000 Btu Room Air Conditioner...
I need to know what the voltage for this unit
Model: REG-123H
  • UPC: 855326002968
  • Product Type: 12,000 BTU Window Air Conditioner & Heater
  • Product Dimensions: L: 24.00" x W: 24.00" x H: 16.00"
  • Product Weight: 88.00 lbs.
  • Product Color: White
  • Application: Used to cool individual rooms
  • Type: Window Air Conditioner
  • Warranty: 1 year; 5 years sealed system
  • Coverage Area: 550 square feet
  • Voltage: 230 volts
  • Heater: Yes
  • Air Flow: 266 CFM
  • Amps: 5.5 amps
  • Heating Capacity: 11000 BTUs
  • Frequency: 60 Hz
  • Cooling Capacity: 12000 BTUs
  • Dehumidifying Capacity: 3.6 pints
  • EER: 9.8
  • Heat Pump: No
  • Number of Fan Speeds: 3
  • Programmable Timer: Yes
  • Timer Length: 24 hour
  • Refrigerant Type: R-410A
  • Air Conditioner Type: Cool/Heat
  • Energy Star Rated: No
  • Air Filter: Yes
  • Built-In Air Purification System: No
  • Display Type: Digital
  • Remote Control: Yes
  • Adjustable Louvers: Yes
  • Adjustable Side Panels: Yes
  • Compatible Window Size: Min. Window
  • May 31, 2014 | Comfort-Aire RED-123 Air Conditioner
    How many BTU is Model#580.74085 580.74124
    8000 BTU. I have one. I'm looking for the EER rating, although I see an energy star label on the front.
    Jun 19, 2011 | Kenmore 75135 Thru-Wall/Window Air...
    I have a Daewoo Air Conditioners dwc 055rl can i plug it into a regular wall outlet
    features Cooling Capacity 5,340 BTU/h 10 Energy Efficient Rating Cooling Area (sq. ft.) 100 to 150 Low Noise Operation Washable Air Purifying Filter Effective Dehumidifying Operation Indoor Temperature Sensing Thermostat Window Kit for Easy Installation Power Supply (V/Hz): AC 115V/ 60Hz Power Consumption: 525 W
    Answer = yes regular 115 vac outlet
    Aug 21, 2010 | Daewoo DWC-056CL Air Conditioner
    I have a Haier 5,200 btu air conditioner that
    E-1. Indoor room temp sensor defective. replace it.
    Jul 23, 2010 | Haier Energy Star ESA3183 Air Conditioner
    How can we caculate the energy needed by an air conditioner?
    It depends on the (EER) Energy Efficiency Ratio,which is capacity divided by watts.
    Example 35000 btus / 2500 watts = 14 EER
    If you know the capacity,btus and EER you can calculate the watts, capacity / EER
    Example 35000 btus / 14 EER = 2500 watts.
    EER is determine by testing the air conditioner at Department of Energy Guidelines, which are
    80° drybulb 67° wetbulb indoor and 95° and 82° drybulb outdoor.
    May 14, 2009 | LG LS-K2430HL Heat Cool Mini Split Air...
    Daewoo High Energy Efficiency Air Conditioner Logo
    138 people viewed this question
    Top Daewoo Heating & Cooling Experts
    Tim Whalen
    Craig Hill
    Steve
    Are you a Daewoo Heating and Cooling Expert? Answer questions, earn points and help others
