I have DELL Precision M6300 Laptop and now giving me black screen after bios check saying "The AC power adapter type cannot be determined. The system can only boot with a 130 W power or greater. Strike the F1 key to shutdown. Please connect a Dell 130W AC adapter or greater for best system performance. To resolve this issue, try to reseat the power adapter." Knowing that I have connected a brand new genuine PA-13 family adapter.
  • 2,229 Answers
You should probably do as it says and check your power adapter which apparently has gone bad.
Posted on Oct 07, 2010
Dell precision m4300 screen black
Hi
you have to be sure if the laptop is running the alert LEDs, the sound of the fan in fucionamento, use an external monitor to be certain. and finally replace the LCD and its. cable
Apr 06, 2014 | Dell Precision M4300 Laptop AC Power...
Reset bios password
Each Dell has a master password which will clear the BIOS password. You can get this number by calling Dell Technical Supporticon1.png at (800) 624-9896.
Dell Technical Support will request the Service Tag and Express Service Code from the bottom of your Precision.
Jan 22, 2014 | Dell Precision M6300 Mobile Notebook
Dell precision m6300 battery won't charge.
You say it's a new battery. Is the battery the same EXACT spec? Some aftermarket batteries don't work well with your laptop. The pin-out/connections may be incompatible. That said, in your BIOS is there a "Battery Learning" section.
Jan 04, 2013 | Dell Precision M6300 Mobile Notebook
WHY WILL THE M6300 NOT POWER UP WITHOUT THE BATTERY CONNECTED
my M6300 does power up with out battery but with mains adapter connected
Aug 09, 2011 | Dell Precision M6300 Mobile Notebook
M6300, When I push the power botton, the green power light lights up, and for a second the next light lights up ( i think the hard drive light) then goes out to stay out. screen stays black no boot up...
Try taking the battery out of the machine and leave it hooked to the AC power and try it again. It may be that your battery is bad and that is stopping it from booting up.
Apr 21, 2011 | Dell Precision M6300 Mobile Notebook
Why is my m6300 not booting up? I installed a new cover and HDD and the screen is blank when I power up. There is a beep and nothing. I removed the BIOS battery and placed it in the new cover before...
Screw you laptop check the RAM remove it and clean with a eraser use another slot of the RAM. Put back the RAM. If the same things happen and no beep.
The cable for the back light inverter board may have come off on the mother board side or on the screen side.
2) Failed inverter board.
3) Failed lamp.
Mar 26, 2010 | Dell Precision M6300 Mobile Notebook
My battery won't charge on my laptop. It gives me a message that says: The AC power adapter type cannot be determined. But I have my AC adapter plugged in and the little blue light does come on. I can't...
There at least three possible reasons for your problem.
1) You are using the wrong charger, or
2) Your battery may be defective, or
2) If you are using the original charger that came with your laptop, it may be defective, or
3) Your laptop charging port may need to be replaced.
You need to take your laptop to a local computer repair shop to have the problem correctly diagnosed.
Feb 04, 2010 | Dell Inspiron 1318 Laptop Computer PC...
Dell precision m50 will not boot power light just flashes when I push the power on button. I have reseated all of the connection in the laptop. I have tried different batteries and different power...
remove external peripherals. remove battery. use ac adapter alone. check if ac adapter has sufficient power or check if ac adapter led is solid green or blue. if not then ac adapter might not giving laptop enough power to power up.
if ac adapter led stays on but some problem check the ac adapter - laptop pin socket if loose or damage. if not then replace mobo.
Dec 07, 2009 | Dell Precision M50 Notebook
My Dell precision M90 will not turn on all the way it acts like its going to boot up and then comes to a screen that either says the battery can not support the system press F1 to shutdown (when it is not...
Seems that either the battery or the power adapter is defective. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective.
Oct 27, 2009 | Dell Precision M90 Notebook
Computers & Internet Logo
659 people viewed this question
David Payne
David Payne
