Question about Tasco Red Dot 1 x 30mm Rifle Scope 5 MOA Dot Reticle
HOW TO ADJUST THE SIGHTING FOR THE TASCO PRO-POINT PLUS
SOURCE: Ihave a tasco pro point,pdp2t-3, need to know the
2032
Posted on Feb 19, 2011
  • 117 Answers
SOURCE: I have a tasco pro point plus (red dot Scope) and
The PDP3CMP uses the CR2032 batteries.I had one and gave it to my son who uses it on a huge pistol.I gace him several spare batteries with it.You always need a spare for those things.Good Luck
Posted on Mar 25, 2009
  • 56 Answers
SOURCE: i lost the batt to my pro point tasco is it the
Not from what I'm seeing on Google. It's CR2032. It's like the CR2025 but more powerful and about twice as thick from what I remember.
Also I'm seeing reports of tasco pro points using 2xCR2032.
Here's an approximate guide:
CR2025 1.5mm thick
CR2032 3mm thick.
Obvioulsly the spring is in the way so the space looks smaller, so to get a better idea, push the spring in so you can see how much space there is in there.
Try googling "tasco pro point cr" and see if you can find the one that looks like yours.
Posted on Dec 02, 2009
Thermo King
  • 593 Answers
SOURCE: I came up on
Duracell = DL2032, Here is a manual if you need one.. Tasco Red Dot Manual
Posted on Apr 02, 2011
  • 5 Answers
SOURCE: I have a tasco pro point red dot PDP2 -how do you put batteries in.
there should be a slot under neith the scope with a screw. unscrew it.
Posted on Nov 16, 2011
I need the mounts on the bottom of my Tasco Pro Point.
They don't appear to be available which is vert odd. Contact Tasco direct
tasco pro point mounts Google Search
Feb 25, 2018 | Tasco Optics
My cross hairs do not move when i adjust my sights. i bought a laser bore sighter and the laser points in the same exact spot no matter how far i turn my adjustments nor do my cross hairs move.
This happens a lot during bore sighting, - no shock to the scope to jar the cross hairs. So take your screwdriver and use the handle - rap the scope or better just tap it. Not hard enough to bend/dent it but jar it so things can move if need to.
Jan 04, 2011 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
At an estate sale i bought a tasco accudot-30mm 7 dente rheostat--this sight was still in the orignal box unused -the marking on the box acdist 1993 tasco sales-box contains ring mounts the main body and...
Does it look kinda like this? narseman_0.jpg This is a 1x 30mm Used for hand guns and shot guns. No zoom to speak of, just rapid target sighting..
You seem to have an older model.. Still worth over $50..
try www.tasco.com
Dec 22, 2010 | Sport & Outdoor - Others
How do i sight this scope in, say for 100 yds what are all the sighting knobs for...?
You sight it in by firing at a target. Place the target at 100 yds distance if that is where you want it set for. Then you use the knobs to adjust the aiming point so the bullets strike where you place the crosshairs. This can involve a lot of shooting, and it is best to use a bench so you don't get confused by inaccurate handheld shots. Once sighted in, there may be other knobs to adjust for different distances or windage. These should be set to a central or neutral position while doing the initial siting, or maybe set to the distance you are siting in. My sights don't have such luxuries, so I am not sure how they work.
Oct 20, 2010 | Barska Optics BARSKA 156X42 IR Huntmaster...
I lost the batt to my pro point tasco is it the cr 2025?
CR2025 1.5mm thick
CR2032 3mm thick.
Dec 01, 2009 | Tasco ProPoint Red Dot Matte Red/Green Dot...
I have a tasco pro point plus (red dot Scope) and I need to know the battery size for that scope. The scope is a PDP3CMP Thanks for any help.
Mar 05, 2009 | Tasco ProPoint Red Dot Matte Red/Green Dot...
Zeroing scope adjustment
First, adjust wind-age and elevation to center or zero position. Remove your scope from the gun and make sure that the scope mounts are aligned, this is critical. Purchase an alignment tool is necessary. Then remount the scope. The scope should seat in the mounts without binding. If it does bind, the mounts are not aligned.
Start sighting in at close range,10 to 30 yards, then move out to 100 yards.
Jan 03, 2009 | Tasco 3-9x40 World Class Riflescope 30/30...
Tasco Red Dot 1 x 30mm Rifle Scope 5 MOA Dot Reticle Logo
370 people viewed this question
Top Tasco Optics Experts
Lyle Siemens
Lyle Siemens
Are you a Tasco Optic Expert? Answer questions, earn points and help others
