Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Is there a reset button for 52in rca hd ready rear projection tv?
When we moved our tv it wouldnt work when it got to the new house. does it need to be reset?? when you push the power button, the light comes on and you can hear the tv try to click on and after 3 attempts the light goes off on the power button. there is no sound or picture at any time since we have moved it. help!!
  • ptway May 29, 2008
    just got an rca hd 52'' from a friend but the sound does not work. all connnections seem to be fine. picture is good but still no sound. solutions?
  • 4,234 Answers
Most likely there was one or more marginal connections on the main board and moving the set has completely opened those connections. If you can solder, try resoldering any connections on the boards that appear to be grainy or have rings. Update this with the results. That may resolve the problem. If not, we'll look further into the set for component failures.
Dan
Posted on May 29, 2008
What the best HD connection for D52W20 52in
HDMI is the way to go if your TV supports it: it delivers audio and video via one wire. Otherwise, you could go with component PB/Y/PR, which will offer the same definition, but you will have more wire clutter.
Dec 18, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hello, I have a 52in RCA projection tv, model D52W20BYX1. It used to work fine but now whenever i try to turn it on it the power button light turns on and the tv makes a short whistle sound, this happens...
Not sure why chat got closed/ disconnected.
There is big transistor TL010 attached with heat sink near flyback transformer, this is horizontal output transistor, check it and replace if found shorted.
Thanks.
Apr 08, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a RCA 52in TV & the picture is arched. Model # is D52W15.
Problem description indicates a convergence alignment issue. Convergence circuirty needs to me replaced.
Jan 19, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a RCA D52W19 52in Rear Projection HDTV and the light flick
Deflection board , its bottom board to the left has FBT flyback transfomer CK capacitors cp 150 2200uf 16v use 25v and two more cp114 cp120 220uf 35v if cp 150 is puffed up on top it is bad replace All 3 capacitors for parts call Mats Electronics 1-800-628-1118, also For Deflection replacement board Call Encompass Electronics Parts 1-800-638-3328
Nov 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Got tv from friend want come on
Its over heating I have the same problem! the quickest fix is
to find away to get cold air blowing to back of TV. also move away
from any heat.
good luck
Apr 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
LG 52in rear projection HD TV
it will be the polarized filters in the optical engine which you cant get anymore you will have to get a new optical engine fitted, take it down to ure local service agent for a quote
Jan 20, 2009 | LG RU-52SZ51D 52" Rear Projection...
TV LOCKED AND NEED TO UNLOCK 52IN
Press and hold Vol-Down and Chan-Down for 8 seconds.
Oct 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52in Rear Projection TV/ Picture
Sounds like someone has put a magnet near it or picture projection from rear may have moved is the picture fine other than tinting?
Jul 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Reset lamp timer
Hold the menu button on the TV and menu button on the remote for 5 seconds.The service menu should appear.Select the lamp option and reset lamp hours.
Dec 15, 2007 | LG RU-52SZ51D 52" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
322 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
