Question about Kenmore 23822 Top Load Washer
Kenmore washer overheats and shuts off
Hi, My washer a Kenmore 90 series, purchased in 1999, will fill with water and agitate, but then as the cycle approaches the point where it should drain and spin, it will overheat and stop. It will smell like burning rubber, and I can still hear the motor humming, but it's like it's "stuck" or something.  It will start again hours later and then the same thing happens on the rinse cycle.  Overall, it takes several hours to complete a load of laundry.  Sears recently replaced the motor back in March, and that didn't fix the problem, although they claim that the motor they removed was "burned out" Anyway, after 2 months of it shutting down intermittently, it began to happen more frequently, and Sears came back out and refunded me for the motor replacement. So, the washer has a new motor, but still is shutting down. The model number is 110.2691269. I am wondering if it can be repaired, or should I just get a new washer.
  • 246 Answers
It sounds like you have a bad timer. Your timer is basically a wheel that turn and opens and closes sets of contacts. Once these contacts go bad, they stick together. Your machine will basicall try to do a few things at once and over heat (hence the reason it works after it cools back down). A replacement timer should be availible from both your local appliance parts supplier and from the manufactures web site.
Posted on Jun 16, 2008
Kenmore 700 series top loader washer. I put it on the normal cycle, the washer fills and agitates for a few minutes (maybe 5) then drains only to fill back up and finish the cycle. Is this normal?
no
some cycle the agitator during the fill cycle to get better distribution of the clothes as it is filling and then shut of the water and proceed to the wash cycle
have a technician check out the program board
Jun 15, 2017 | Kenmore Washing Machines
My Kenmore washer (series 90) stopped working in between the rinse and spin cycles. It will not drain (half full as we speak), agitate or spin. It will fill with water but once it reaches the proper water...
Something stuck in Pump. Pump on your model is driven by washer motor, so if Pump can't turn, motor can't work and will hum until it overheats and shuts down.
Sep 28, 2017 | Washing Machines
Kenmore washer 90 series continue to fill w/water. Load size won't stop the fill... had to shut off water source. won't get to agitate phase... just want to stay at fill stage... can drain, spin,...
Sounds like the fill switch needs to be replaced. A good way to test it is to set your machine on low fill and see if it fills past 3/4. If it does, it's the fill switch.
Aug 20, 2011 | Washing Machines
My kenmore 90 series filled with water and went it got to the rinse cycle it quit working and just started making a grindling sound. help please
sounds like the motor coupler broke. it's a plastic piece near the motor and very easy to replace.
here'e a video you can watch to make it easier:
http://www.youtube.com/watch?v=nM4DW2bq7o0
Jan 21, 2010 | Kenmore 22422 Top Load Washer
Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 Series Washer - No Agitator Movement
You need a timer the motor contacts are probably burnt.
Aug 21, 2009 | Kenmore 15864/15862 Top Load Washer
90 Series Kenmore Washer Not going to spin cycle not draining water
I've had the same problem...you can purchase a replacement lid switch at your local appliance parts store for about $35. Fortunatly, the sales person at the appliance store had diagrams and provided instructions to replace the switch. I was able to finish the job and fix the switch in less than 1 hour. Good Luck.
Oct 25, 2008 | Kenmore 15864/15862 Top Load Washer
Agitator not working 90 series model # 11026912691
Hello aksward,
Welcome to Fixya.
Here are some suggestions for any Kenmore washers
Let me know how it goes. I'm still thinking and searching my repair manuals!
Huuum
Please remember to leave a rating!
KENMORE ELITE TOP LOAD
Washer stops, won't fill, rinse or agitate
• Check the following:
Is the power cord plugged into a grounded 3 prong outlet?
Is the indicator on the Cycle Control knob properly lined up
with a cycle? Turn the Cycle Control knob to the right slightly
and pull to start.
Are the water inlet valve screens clogged?
Are both the hot and cold water faucets turned on?
Is the water inlet hose kinked?
• Does the water level seem too low, or does the washer
appear to not fill completely? The top of the agitator is
much higher than the highest water level. This is normal and
necessary for clothes to move freely.
• Has a fuse blown or is the circuit breaker open? If problem
continues, call an electrician.
• Are you using an extension cord? Do not use an extension
cord.
• Is the washer in a normal pause in the cycle? The washer
pauses for about 2 minutes during certain cycles. Allow the
cycle to continue. Some cycles feature periods of agitation
and soak.
• Is the washer overloaded? Wash smaller loads.
• Is the lid open? The lid must be closed during operation.
Washer will not agitate or spin with the lid open.
Oct 06, 2008 | Kenmore 22422 Top Load Washer
Kenmore 90 series that wont agitate or spin
Could be the door switch, do you hear a clicking sound when you close the lid?
Does the motor hum at all in drain/spin?
Mar 12, 2008 | Kenmore 45981 Washer
Kenmore 23822 Top Load Washer Logo
463 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
