Computer won't boot beeps every 10 seconds - Computers & Internet
  • 6,831 Answers
Hello
OK, you will need to be a little more specific on this matter. What Bios are you using? Also, let me know on the specific beep code you are experiencing.
Let me know, i will gladly help.
Kind regards
Andrea
Posted on Oct 07, 2010
Alienware Area-51 Desktop won't boot up long beep
The fan to the left of your RAM slots needs to spin, it may be the reason for your problem. If this is the CPU fan then you may have a dead CPU.
Contact a computer technician for repair or claim warranty support.
Take care!
damnor01
Sep 21, 2012 | Alienware PC Systems Alienware Area-51®...
Dell PowerEdge 2300 Server won't boot
To power off using the power button, press and hold in for more than four seconds.
However this is not solving your problem of not booting, needs some more information. Such as Beeping noises, number and length of beeps. Or any LED.s flashing?
Aug 16, 2012 | Dell PowerEdge 2300 Server
PCV R44G, won't boot, no fans, won' turn on.
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 22, 2012 | Sony Computers & Internet
Acer computer won't boot has long buzzing noise
The long buzzing sound indicate the nature of the problem. Depending on the manufacture of your bios will determine the problem. With only one long beep you may have memory problem. The computer cannot initiate the boot sequence. Did you add any devices to the computer prior to your problem. if you did undo what you did. Make sure the computer is on, if nothing happens ( no lights, no sound, no fans etc.) the computer has a power failure. Make sure you listen to the beep if it is a numerous beep sequence note it down and check the web for computer beep during boot up.
Mar 25, 2012 | Computers & Internet
Toshiba satellitep205d-s7438 won't boot up
You need to be more specific and tell what happens when you plug in the power cord and press the power button. There are a number of reason why a computer will not boot, but if you tell what's going on someone can help you.
Computers don't boot for basically the following reasons, 1) the power supply is bad. That means when you plug it in you don't see any lights, and when you press the power button nothing happens, you hear no fans, no beeps, no blinking lights, no hard drive spinning, no cd drive clicking and nothing appears on the lcd screen.
2) A motherboard issue, usually when this happens you will either see blinking lights or hear beeps. Those blinking lights and beeps are codes that tell the technician what is really going on.
3) Static Buildup - try removing the battery and the power cord then Press and Hold the Power Button for 30 seconds. After 30 seconds put the power cord back in (leave the battery out) and Press the Power Button. If it boots up you had static buildup and can replace the battery, count your blessings and Thank The Lord cuz a dishonest repairman would have told you he had to replace the motherboard for $300
Mar 20, 2012 | Toshiba Satellite P205D-S7438 Notebook
I have a HP a6300f computer. It won't boot. Once I turn it on, it beeps for 17 seconds, is silent for 10 seconds, and follows by another beep for 17 seconds. I'm not sure what the problem is.
The duration and time of the beep codes is going to tell you what the problem is..
Here is the hp page that has the beep code information.
HP Beep Codes
The specific beep code info is towards the bottom.
Hope this helps
Aug 29, 2011 | Computers & Internet
Computer won't boot and beeps: BEEP pause BEEP BEEP BEEP
In case you have AMI BIOS, it is a computer RAM (memory) related issue.You can remove added memory, reseat memory, swap memory location or try memory from other computer
Jul 05, 2011 | Computers & Internet
System not booting
Try power cycling the laptop by taking the battery out and pressing the power button 10 times. On the 10th time, hold it down for 10 seconds. Put the battery back in and attempt to boot the laptop.
If that doesn't work, listen for a cooling fan when you attempt to boot the laptop. If you don't hear the fan, it's likely that the motherboard is malfunctioning somewhere.
Do you hear any beep codes when you try to turn it on? Here is a list of beep codes for reference:
No Beeps: Short, No power, Bad CPU/MB, Loose Peripherals
One Beep: Everything is normal and Computer POSTed fine
Two Beeps: POST/CMOS Error
One Long Beep, One Short Beep: Motherboard Problem
One Long Beep, Two Short Beeps: Video Problem
One Long Beep, Three Short Beeps: Video Problem
Three Long Beeps: Keyboard Error
Repeated Long Beeps: Memory Error
Continuous Hi-Lo Beeps: CPU Overheating
Hope this helps! Good luck!
Aug 10, 2009 | HP Compaq nc6000 Notebook
Laptop won't boot up
That shouldn't affect the laptop booting, hold down the power button for 10 seconds, it shoul boot up., if not then remove the battery and replace it. then try it again, good luck, Gym
Dec 18, 2008 | HP Compaq nc6000 Notebook
Computers & Internet Logo
89 people viewed this question
David Payne
David Payne
