Question about HP Bestec ATX-250-12ZD 250w HP Pavillion Zinfandel Power Supply Part 5187-1098 (ATX25012ZD) Power Supply
I have an hp pavilian atx-250-12z and the tower itself will turn on and the mouse to will turn on but the monitor gets no signal and the keyboard will not turn as well..I have unplugged the cpu while holding down the power button to no avail.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 80 Answers
Whom ever told you too: "Unplug the cpu while holding down the power button".
Is telling you something that can "seriously damage" your cpu and computer.
Or did you mean "PSU" if so there is a particular format to do a Power supply check.
For the proper way use this link: http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph06788&lc=en&cc=us&product=405227&dlc=en&lang=en#N207
Also many other things can cause the problems your having. Could be your motherboard too.
If this does not work, post again be sure to include HP Pavillion Model number and Operating System (i.e. XP, 7 or Vista) that way we can help pin point your system needs. Also have you done any internal repairs lately? Recheck all your connections too.
If you find this helpful please vote.
Posted on Oct 08, 2010
Tower turns on but screen says no signal?
Check to be sure your monitor connection needles are seated properly. Is mouse wireless or connected to back of tower?
Jan 02, 2014 | Acer Aspire X3200 PC Desktop
MY HP TOWER TURNS ON AND THE FAN RUNS, BUT DOES NOT SEND A SIGNAL TO THE KEYBOARD OR MONITOR. BOTH THE KEYBOARD AND MONITOR HAVE POWER AND ARE PLUGGED INTO THE TOWER. ON OFF BUTTON IS ILLUMINATED ON THE...
If the keyboard and is USB, you can try another USB port. For the monitor not getting display, I would try either a different monitor or a video card. Otherwise, the motherboard could be the problem.
Oct 02, 2010 | Computers & Internet
Monitor green light comes on then it says no imput
looks like there is problem with ur signal cable check that monitor signal cable is tightly fixed or contact ur product support center.
Mar 31, 2010 | HP Pavilion F1523 15" LCD Monitor
Wirless keyboard and mouse and monitor do not work.
try takeing the ram cards and clock battery out and unplug the tower from the wall wait 1-5 min then plug everything back in this has worked for me several times on several different computers not sure it will help you but its worth a try
Dec 19, 2009 | HP Computers & Internet
Okay im having a probblem with my lcd monitor and when i press the button on the tower to turn everything on and then press the on button on the lcd monitor it says minitor is going to sleeep and ive tried...
Sounds like the monitor is not getting a signal from the tower.
Do you have another monitor/LCD screen that you plug into your tower? That will tell you if the LCD is the issue or the tower.
If it is the tower that is at fault, then you need to try and figure out if your video is separate from your motherboard. Hopefully it is separate, that way you can get that replaced. If not, then it means that your video card is integrated onto your motherboard which is much expensive to get fixed.
Hope this helps.
Dec 08, 2009 | HP W2007 LCD Monitor
Got a used Compaq Pressario SR1303wm and need to set up correctly
Monitor into Small Blue connector at back.
If Mouse and keyboard are Round and not Rectangular in shape then that's a PS/2 Mouse and keyboard. Purple goes into Keyboard slot at back. Green goes into Mouse at back. Watch for the design as the pins inside each one need to be inserted accordingly.
If they ARE rectangular then that is a USB connection. On the back connect the keyborad and mouse to the top two. Again, only going to insert one ways.
Jun 26, 2009 | HP Compaq Presario SR1303wm PC Desktop
My tower wont turn off and monitor says no input signal and keyboard doesnt work
Do you have two video outputs on your PC ie. one on the motherboard adn a separately installed card maybe? If you do you need to set the BIOS so that it uses the AGP/PCIE video card and not the 'onboard'. Try the onbopard vodeo card first to see if you get a signal there.
If you do NOT have two video outputs, and you can not see a signal then you may have a prblem wiht your monitor itself. Is this a known working monitor to start with?
May 12, 2009 | HP Pavilion a1610n PC Desktop
No mouse,no keyboard, and no monitor?
try to connect it with other keyboard,mouse and monitor....if they will run, the keyboard,mouse and monitor may be defective or damaged..but if they did not run properly,,
maybe somethings wrong wit your unit...
try to connect it first and see whats the result...
please tell me what are the results...
you may post it here...
chaw
Jun 17, 2008 | Computers & Internet
HP Bestec ATX-250-12ZD 250w HP Pavillion Zinfandel Power Supply Part 5187-1098 (ATX25012ZD) Power Supply Logo
192 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
