Question about Kirby Generation 3 Bagged Upright Vacuum
Kirby g6- How do you replace the cord? - Kirby Generation 3 Bagged Upright Vacuum
  • 171 Answers
I do believe o6 the cord goes in to the metal housing of the motor .They are usually held in by a rubber grommet and they can with some patience and force be pulled out slowly does it as you don't want the wires to come off or you will have nothing to tell you which wire goes where one you get it open.If you can not get it out and it is just ripping , I would recommend taking it to your local used Vac sales and service store as they all service Kirby . If you do not want to let them fix it they will most likely show you what to do and then you can finish the job. One thing that I would do if I was replacing the power Cord is get one that is 32 feet long as opposed to the 20 foot cord that comes with it.It makes vacuuming much more convenient if you don't have to re plug it in every two minutes. I hope this helps and don't forget to click on the yes button if it did. Thank you for the question.
Posted on Oct 07, 2010
Splicing kirby electric cord
If you are unsure on how to splice the cord back together it may be best to just purchase a new cord. You can find a new G6 cord and it is easily installed into the switch at the base of the Kirby.
Kirby G6 Power Cord
GoodVac.com Technician
www.goodvac.com
1-800-775-6586
May 10, 2014 | Kirby Generation 3 Bagged Upright Vacuum
My kirby G6 2000 no pwer
More than likely you have a short in your power cord. however if you want to know for sure take machine apart until you can put an elec meter on switch where cord is attached. plug machine in and test the end of cord that is attached to switch if you have 120volts at that point its your switch thats bad. if you have no voltage or anything less than 110volts at the switch replace cord
Jan 14, 2013 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G6 - won't power on
Check the cords two wires with an OHM meter for continuity replace if you get a reading showing OL The ground wire you can forget about this test
If any sort of numbers appear in the meters display the cord is good
Replace the switch instead
Jul 10, 2010 | Kirby G6 Bagged Upright Vacuum
Replace power cord on Kirby G6
The Kirby vacuum cord can be found at http://www.totalvac.com/K-192099ES.html
Jun 16, 2010 | Kirby G6 Bagged Upright Vacuum
Our Kirby g6 vacuum cleaner will not turn on and we have checked the safety switches and cord. ANy suggestions?
you probably have a bad switch. let me know if you want me to walk you through replacing it
Oct 04, 2009 | Kirby G6 Bagged Upright Vacuum
I cant find fuse on my kirby sentria. Any suggestions?
there isn/t a fuse if not turning on probably a bad switch or power cord
Jul 18, 2009 | Kirby G6 Bagged Upright Vacuum
Kirby G6 won't turn on.
If the brushead is removed,there is a safety switch which prevent the machine from operating if the brushead is removed or not installed correctly.Either this switch or the main power switch could be the culprit,as well as the cord.
Dec 13, 2008 | Kirby G6 Bagged Upright Vacuum
Kirby G6 Power Switch Test ?
You can look at the wiring diagram and try to figure out how to use a circuit tester to test the switch but I would just suggest just swapping it for a good one (always good to have one good switch for testing) and see if it solves the problem.
Good Luck
Rocky
Oct 27, 2008 | Kirby G6 Bagged Upright Vacuum
Kirby G6 no power
Could be the switch, I would check the cord 1st. It has 2 wires running thru it, one may be open. That power cord goes bad often, if anyone is pulling on the wire rather then the plug, then it would have have stretched and break.
Jan 15, 2008 | Kirby G6 Bagged Upright Vacuum
Cord problem
Here is the contact information off of the Kirby company website. They can advise you regarding the Kirby authorized service center nearest to you. - Contact Us By Phone United States and Canada: 1-800-494-8586 (Between the hours of 8 a.m. ? 5 p.m. (EST) Monday - Friday) United Kingdom: 0800-328-1247 Europe: 00-800-5472-9272 South Africa: 0800-203-222 - Contact Us By Email Complete the online Form to Submit Your Comments or Questions: http://www.kirby.com/Portals/0/contact_us_form.html - Contact Us By Fax United States and Canada: 216-529-6146 - Contact Us By Mail Consumer Relations Department The Kirby Company 1920 West 114th Street Cleveland, OH 44102
Aug 13, 2007 | Kirby G6 Bagged Upright Vacuum
Kirby Generation 3 Bagged Upright Vacuum Logo
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
