Question about Nintendo Wii Console
No colour - Nintendo Wii Console
  • 358 Answers
Hi, Definitely a TV issue for me. Changed Wii to another input on TV and resolved situation. Need now to check how to get my TV to recognize colour on AV2 & 3 because I prefer to keep DVD input as AV1!
I had to use the (RCA) video inputs and not the component inputs. These are the ones made for video games. If you want to use the component input (Component cables are Red,White Red, Green, Blue). If you don't have any, you should be able to purchase them at your local electronics store like Radio Shack or Best Buy. Hope this helps, read below:
TV (This is your cable connection or TV; coax)
Component 1 (Must use component cables for this input/output; Red and White for audio, Red, Blue, Green for Video)
Component 2 (Must use component cables for this input/output; Red and White for audio, Red, Blue, Green for Video)
HDMI 1 (HDMI Cable)
HDMI 2 (HDMI Cable)
Video 1 (Must Use RCA cables, or RCA jacks; Red and White for Audio, Yellow for Video)
Video 2 (Must Use RCA cables, or RCA jacks; Red and White for Audio, Yellow for Video)
Sample of Component Cables:
http://www.tigerdirect.com/include/AddCartfromGallery.asp?EdpNo=245214&csid=ITD&Sku=C184-27083&imgcart=1
Posted on Oct 07, 2010
RED COLOUR MIX IN EVERY COLOUR
Provide brand and model number and a photo of what screen looks like.
Dec 03, 2012 | Televison & Video
How to scan in color
Need a colour scanner, If you have a colour printer with scanner, then install the printer scanner, go to My computer and double click on the Scanner Icon Put a Colour paper in Scanner and go to preview then click on next colour picture next and finish. Your colour scanner scanes a colour page
Nov 21, 2012 | Computers & Internet
Colors not matching computer
It is possible your colour cartridge has cross contaminated the ink reservoirs. To check this take the colour cartridge out and turn it over to see the coloured pads. They should look red, dark blue, and orange ( the colours are actually Magenta, Cyan, and Yellow, but are concentrated). If any of the pads are pale or particularly green - change the cartridge.
If the colours look alright, your issue is probably that your monitor makes colour by emitting light frequencies so is bright, printed images make colour by absorbing light frequencies so will always be darker. There is always the issue of course that your monitor also has a colour "temperature" bias. Photo pros calibrate their monitors and printers to match.
Mar 25, 2012 | Canon PIXMA iP90v Printer
My cyan colour is finished, i have to print a black colour documents, printer is not allowing to print, please help
switch to black and white on the printer settings.make sure ignore colour warnings are turned off
if that doesnt work youll need to replace the cyan,get it refilled for less or order online to reduce cost
Mar 07, 2011 | Epson Office Equipment & Supplies
Black is colour..white is also colour...but bl...
Not sure I am colour blind.
May 20, 2010 | Ovens
The printer does not print colour. The colour
The nozzle may be blocked. So take out the colour cartridge and place its nozzle in a bit of water for about 10 mins. Bring it out and dab the nozzle with folded paper. If the tissue is blotted with the three colour it means you have unblocked the nozzle. Try now to print after returning the colour cartridge. You may need to repeat to get good results..
Thank you!!
May 18, 2010 | Lexmark X1290 All-In-One InkJet Printer
Printed colours doesn't match with monitor colours
Here is a list of reasons why colours on electronic designs might differ from printed designs:
  • Monitors work in the RGB (Red,Green,Blue) colour space while printers use the CMYK (Cyan, Magenta, Yellow and Black) colour space.
    Designs look fine on a monitor if they are designed in RGB to begin with. Converting them to CMYK might make them look odd on screen, but they will print correctly, to a certain measure. It is difficult to sign of an image file that is currently in CMYK mode while viewing with an RGB monitor.
  • Monitor settings differ.
    The designer was sitting in a darkish room when choosing the blue and his blue looks vibrant. The client was viewing the same design in a well-lit room, making the blue seem lighter. The designer uses an LCD display and the client uses a CRT monitor and the vibrancy differs. The contrast and saturation settings on each monitor might differ as well, rendering the blue with different values.
  • Each printer in the world prints colour slightly different.
    Sometimes it is really obvious and sometimes it is almost impossible to see the difference. Normal desktop printers are definitely not something to do colour proofing with. If you print the design out on your desktop printer then a slight shortage on any of the colours will make the colour come out wrong. There are a lot of factors that can influence even the most expensive printing equipment. These include altitude, humidity, the current heat of the printer, age of the printer, quality of ink, the paper that is being used, special coatings on the paper etc. Even viewing the same printed material in different lighting conditions may make the colour seem different.
Tips on getting the most accurate colour
Go to your nearest printer company and ask to see their Pantone colour matching system. Each colour in the Pantone chart has a matching number. Most design applications have the same Pantone charts built in so that colour matching is easy. Read up on Pantone at Wikipedia. Make sure that the file is converted to CMYK (If not designed in it originally) before sending it to print. Some printer companies might ask for colour separation prints which the leading design packages can produce. It is also important for the designer to choose the correct colour management profile in the design package.
Dec 05, 2009 | HP OfficeJet 6110 All-In-One InkJet...
I cant get my printer to print in colour
please use the colour printer ? and you have a colour printer
then your printer job is colour ? your printer cartries is colour & w&w ?
if colour ? then fristime you aply a print and so the print page is ok and so the previue the page in colour job if yes is ok and other no then
print page and in prperty selectand cleck and go immage in colour select the colour and aply the ok and give a print is ok
Sep 24, 2009 | Lexmark X1270 All-In-One InkJet Printer
Problem with a colour display on Hisense tv
If your picures are all purple it means that the green colour is missing. TV colour is made up by mixing Red, Green & Blue. Removing Green leaving Red & Blue makes purple. Study the green colour circuit for a fault and confirm that the green gun inside the tube is working.
Aug 31, 2009 | Hitachi 60SBX78B 60" Rear Projection...
My i550 Canon Printer will not print colour, black only. Colour cart. are full. Computer checked out OK. Driver is OK. All 3 colours stopped printing at the same timeannabellamt
My i550 Canon Printer will not print colour, black only. Colour cart. are full. Computer checked out OK. Driver is OK. All 3 colours stopped printing at the same time. linda gal16
Jul 06, 2009 | Canon BubbleJet i550 InkJet Printer
Nintendo Wii Console Logo
272 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
