I have a DESA gas fireplace that I would like to conert to a remote control. Is there any type of adaptor available that will upgrade my unit? model VS24NVA/CFS2NVA
  • 59 Answers
Go to skyteck they have a stat called 7003p wireless stat fro millivolt systems
Posted on Oct 12, 2010
Testimonial: "thanks"
I have a vermont castings radiance 2600 fireplace, the pilot light is lit but the on switch isn't turning the fireplace on
desa is out gone but maybe pro com have a controller with the same controls as the desa check #on the control and see cross ref in Google search they can be 80.00 and up but can b found
Dec 10, 2013 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Skytech 3301 thermo
Check to make sure your thermostat is set at a temperature that will turn the fireplace "on".
Double-check what your "swing" temp settings are set at, as this may effect how quickly the unit shuts off because it thinks it's too close to the target temperature.
If needed:Skytech's Tech Support number is 1-888-672-8929They are available Monday to Friday, 8am to 5pm EST.
If your remote needs to be replaced, the 3301 is available here:
Skytech 3301 Fireplace Remote
If you are looking to replace it, I would also highly recommend looking at Skytech's new 3301P2 remote. It adds a programmable thermostat, and a much nicer back-lit LCD screen. This unit is available here:
Skytech 3301P2 Fireplace Remote
Dec 15, 2012 | Skytech 3301 Thermostatic Gas Fireplace &...
I have a Desa EFP33PR ventless fireplace. In Auto it works just fine. In Manaul the pilot will light but when I release the gas valve control knob it goes out. Some times, if I rotate the control knob...
It sound like you may need to clean the pilot on the fireplace and then reseat the thermocouple.
Here is a link you may want to look at:
http://www.allpartsinc.com/mmAllParts/Others/Reseating%20Instructions.pdf
Sep 13, 2011 | Desa International Unvented Gas Space...
Looking to find out if my gas fireplace unit has a "milli volt gas valve" to change it to a remote control unit. Model # CGG363OP Is this remote capable and if so can you sell me a remote for...
Marty, I would really like to help you, but the DESA/Comfort Glow Model Number you listed is incorrect. Please check & confirm it and get back to me.
To visually tell if your gas control valve is Millivolt or not. First, look at the pilot assembly. If it has a thermopile attached to the top of the pilot, it's millivolt controlled. If you are currently using a wall switch to turn the burner ON, it's millivolt controlled. If the control valve has 3-electrical terminals on the side of it, it's millivolt controlled.
As far as selling you a remote control kit is concerned, we at FixYa do not sell any products of any type. But, you can buy them from a hearth store in your area or online. I would recommend looking for a SkyTech Remote Control Kit, as they are one of, if not the best on the market. Plus, they come in a a host of models depending on what you want the remote control to do.
Hope this helps you and thanks for choosing FixYa.
Sep 08, 2011 | Desa International Heating & Cooling
Lack of air to fireplace,need diagram to check air flow from bottom of fireplace in mobile home,
To help you, I will need the correct Model Number of your DESA gas fireplace.
Please advise, thanks.
Jun 02, 2011 | Desa International Wall/Window Air...
I cannote get my remote to operate the fireplace. I have installed 3 new batteries and it still does not work.
The remotes are often a problem...I would advise against repairing it....sometimes the sensor for the vent isn't visible enough for the remote...the wires or sensor can be melted....The best/cheapest solution is to run a wire from the same two contacts the remote sensor are hooked up to on the gas valve...and install a switch on the wall....Turn the fireplace on with the flick of a switch....a Thermostat can also be connected to operate the fireplace using the same contacts as the remote
Oct 26, 2009 | Desa International Unvented Gas Space...
I replaced the battery in our HRC200 handheld it still does not work. We can turn the fireplace on with the manual control at the logs. The fireplace was used last season for the first time. Can you help?
The remote works once the right room temperature is
sensed (66F) by the remote, This is a room temperature
triggered remote.However, if the thermostat at the
remote becomes defective, then there is no way that the remote will function. You have to do it manually.
Oct 13, 2009 | Desa International HRC201-4 Remote Control
Need instructions to my transmitter
I have the same problem. The company is out of business DESA Heating. I have been unable to find a solution. FMI bought part of DESA but can't get any help there either. 1-866-328-4537
Jan 18, 2009 | Heating & Cooling
HRC200 remote thermostat for gas fireplace
To turn on the remote you must press the POWER and LOCK buttons together.
Nov 02, 2007 | Desa International HRC201-4 Remote Control
Heating & Cooling Logo
56 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
