Question about Marshall Health & Beauty
When you are pumping up machine at what number do you stop. I am using the Marshall 85 TM
  • 490 Answers
180 max unless you have chronic high pressures, then 200
Posted on Oct 08, 2010
My Marshall 250dfx has stopped working, there is power but nothing is coming out. No crackiling before, one min it was fine, the next it stopped.. Help!!
try another speaker or test the speakers on another amp. if the speakers are working then it's your amp . check out the output ic's. they maybe blown.
Dec 03, 2013 | Marshall Amplification Marshall MG30FX...
I have a marshall mb150 and sometimes it used to stop emitting sounds for a while but now in the sounds gets deemer and louder every now and then
A common issue with Marshall Amps are generally speaking a low resistor value cracked leg inside the power module, just open up the amp and with the amp unplugged from mains check by a little finger movement the big 2/3W resistors and possibly you will find that one or other will have a broken leg, also cold solder joints do this kind of issue, hope this helps...
Oct 09, 2013 | Marshall Amplifiers Marshall MB150 150W...
What output IC is used tda7294 or93
I found where one individual had replaced his TDA7293 in his Marshall... His was still not working but he probably did read the numbers from the original sticks. The 7293 is a higher voltage capabilty than the 7294...
Read that as the 7294 is a grade out of the chips that did not quite meet the 7293 spec.
USE the TDA7293 in your Marshall and DO use thermal compound !!!!
Feb 17, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Marshall MG100HDFX 100-Watt Amplifier Head. The head phone jack works but speaker output is dead. Hooked it to speakers with another amp input and after word it stopped working. Can't see any overheated...
You'll have to take it in to get it repaired. From what you described it sounds like you blew the output stage out. You can't run from your speaker output jack into the input jack of another amp. You should go out of the recording out, line out, effects out or in the least case your headphone out. What happens usually is your output transformer short circuits due to a mismatch of impedances. It sounds like you still have a transformer though so you might have gotten lucky. You will need to take it in though. Sorry.
Nov 26, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
I bought a Marshall 85, but did not get instructions on how to take my blood pressure. I don't know how long to keep pumping. What should the pulse reading be for normal?
There are several books and resources avilable from you local library and online. here is a link to the Cleveland Clinic web site that will provide you with some helpful information http://www.cchs.net/health/health-info/docs/0900/0984.asp?index=5508 it is however not intended to replace the medical advice of your doctor or health care provider. Be sure to consult your health care provider to get personalized advice
Aug 14, 2009 | Health & Beauty
Have lost instructions for Marshll 85 Oscillometric Sphygmomanometer Electronic Digital Blood Pressure and Pulse Monitor...... is this available? #'s on box are 705203 and M 453952
I suggest you contact Omron with your requests for Marshall 80-series blood pressure monitors. Omron seem to have bought / acquired / become otherwise responsible for the Marshall brand.
That is how I got the manual for model 80 here
Owners Manual User Guide for Marshall Professional Aneroid Sphygmomanometer...
To request a manual from them send a message to them with your exct and detailed request using the webpage
Contact OMRON OMRON Global
I hope this helps
24.February.2015
Jul 10, 2009 | Marshall Health & Beauty
Need instruction manual for Marshall 85 monitor.
You can check out and see if Fixya has the manual you are looking for: http://www.fixya.com/manuals
Jun 06, 2009 | Marshall Health & Beauty
Marshall MG100DFX noisy
Before you bring this into a shop, try spraying out all of the controls. Use an electronics switch cleaner that contains a lubricant. Spray into the control and work the control back and forth a number of times to loosen up any dirt inside. Then spray it again.
Let me know if that resolves the problem.
Thanks,
Dan
Feb 14, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Access to Bosch dishwasher pump
To access the pump, first bail and sponge out any water in the machine's tub. Then tip the machine over on its front, using a heavy blanket or pad to protect the dishwasher's finish. Remove the back service panel. The pump is usually located along the bottom. Good luck!
Aug 25, 2007 | Bosch 24 in. SGS43C12 Classixx...
Health & Beauty Logo
234 people viewed this question
Top Marshall Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Marshall Health and Beauty Expert? Answer questions, earn points and help others
