Digital Cameras
Problem for Digital Cameras
Generic problem for all Digital Cameras
Installing cd for camera
By jeancaff on May 29, 2008
i have got a new computer but cant find the old disc to install to get my canon ixus v3 up and running on my pc.as my old computer completely broke i couldnt transfer any of my old stuff to my new comp and now i am stuck with a camera that i cant see photos on my computer with.any help would be much appreciated,.
Comments:
May 30, 2008
- hi,i still havent solved my problem for the camera yet but have been given advice on it,i was told i need to buy a disk though i wouldnt know where to get one,i thought i might just be able to down load one for free on the net,i am new to computers and so therfore dont know what i am doing most of the time.i think i need the installation disk to put into my computer so that it can accknowledge the camera,i did have the disk but i downloaded it to my old comp wich completely broke and i lost everything on it.i have searched in vain for the disk to download again on this comp(windows xp)but cant find it.isnt there a site that i can just go to where i can just download the disk,or am i being silly.thanx jean.
Same Problem
Feb 16, 2009
-   barbie mattel digital camera item no. dca68-08-   Guest
Best Solution
posted on May 30, 2008
Helpful)
MrsJGreen
Rank: Guru
Rating: 89%, 101 votes
I don't think you need the disk, this is a hardware connection issue, not a sofware issue so we can take some troubleshooting steps to try to get your images downloaded. I will just need a bit more information from you.
Comments:
Jun 02, 2008
- I just really wanted to know which operating system you were using, but these steps below should help you. If they don't, feel free to ask me for help again, I may have some more steps for you to take. Here are the steps to take.
1. Establish whether or not you have a connection between your camera/computer by going to your start button, control panel, system, hardware tab and device manager. The camera must be powered on and in playback mode (should automatically go to playback mode when connected, camera's screen should go black if there is a connection). Make sure you have a fully or nearly fully charged battery in your camera.
2. Once in device manager, look under Imaging Devices. If your camera is properly connected it should show up as Canon Powershot SD800. If it shows a yellow exclamation point, there is a driver issue, and even if it doesn't show a yellow exclamation point, you may want to update your driver anyway by right clicking and having the system search automatically for driver updates. If download of driver begins, great...once finished, restart camera and your problem may be resolved.
3. If there are any other imaging devices, you may have to temporarily disable them to avoid conflicts.
4. If you have any other imaging software running, exit or close the program in your system tray (down by your clock in the right hand corner of your computer's desktop.
5. Try again to connect.
6. If you are on a desktop, try a rear usb port vs. a front port. You can also try a different port on a laptop. After each change, try restarting camera to establish connection.
7. Go to start/My Computer and look for the icon for your camera...you will be able to download images even without Canon software loaded onto computer so this is not a software issue if you have no hardware connection. If you see the icon, right click on it and choose Get or Import pictures. From there the default Microsoft scanner and camera wizard should launch and you will be able to import your images.
8. If still no connection, try going to Start/Run and type in services.msc here you are looking for 4 services to be running. Check under status of each service and make sure it reads that each of these services are started.
  • Canon Camera Access Library 8 (if Canon software loaded)
  • SSDP discovery service
  • Universal Plug and Play Device Host
  • Windows Image Acquisition
Once all of these services are started on your computer, restart camera once again. If any of the last three services are not on your computer or are not started, connecting will be a problem.
If all of these steps fail, try purchasing an SD card reader from your local electronics store for around $12 and download images from there. Canon also offers lifetime technical support for your Powershot, so give them a call if none of these steps work or if you would like someone to walk you through it.
Best of luck to you!
MrsJGreen
Was this helpful?
Yes
No
Popular Solutions for Digital Cameras
Questions and Unsolved Problems for Digital Cameras
Answer
best for close up pictures for ebay
Answer
sony digital camera charger
Answer
When I turn my Canon PowerShot A540 on, on the Portrait setting, I can take a picture, but can't see... (More)
Answer
i took some photos andwheni connected to laptop they wern't there why?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Digital Cameras:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 400
Experience: I have run a camera store for 25 years & three websites TripodQuickRelease.Com BogenTripodParts.com
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
