Model KV-27S40; no picture/no sound
Timer light flashes 4 times, stops for second or two and keeps repeating. Unplugged for 5 - 10 minutes but did not resolve.
  • Ed98765 May 30, 2008
    Thanks a lot. I'll try to find one and pop it in and see what happens.
  • 8,617 Answers
Most likely IC 541 is faulty on the A board. The IC number is TDA8172
Posted on May 30, 2008
I have a sony tv model kv-27v42 i have sound but no pictture and stand by light blinks what is the problem
How many times do this standby light blinks at a time of switch on? These blinks are fault indications. From the number of these blinks, you can get an idea about the faulty circuit section inside it. Count it. If you wish to get more details about the blinking codes to Sony TVs, check this link.
Feb 24, 2013 | Televison & Video
Thinking of getting the TI150 3-in-1 Timer - Can it set to repeat a countdown over and over?
Review at Amazon seems to say the timer can repeat the same countdown each time button is pushed and countdown is activated.
Amazon review says:
http://www.amazon.com/General-Tools-TI150-Visually-Impaired/product-reviews/B001TOJG7Y/ref=dp_db_cm_cr_acr_txt?ie=UTF8&showViewpoints=1
The timer is easy to set. You just set the time, then hit the big "start/stop" button and the little "H" and "M" on either side of the timer display flashes.
To clear the timer, just hit both the "h" and the "m" buttons simultaneously. (so time has to be cleared)
To stop the alarm or to turn off the timer before the alarm sounds just hit the "start/stop" button.
On the back of the timer, there are 4 different on/off switches: flashing light alarm, sound alarm, vibrating alarm, and one for hours/minutes or minutes/seconds.
When I set the timer on my desk, it moved around when the alarm went off but when I turned off the vibrating function, the timer didn't move around.
If you need to turn off both the sound and vibrating alarms and use only the flashing light alarm, the light is quite noticeable by itself if placed nearby in your line of sight (within a foot or so). This would be very handy if you're near a sleeping baby! :) But if you clip it on a breast pocket, I would use both the flashing light and vibrating alarms. The vibrating alarm does make a sound, but it's not as loud as the ringing alarm.
Dec 27, 2010 | General Tools Hardware & Accessories
NO PICTURE/RED LIGHT KEEPS FLASHING/SOMETIMES PICTURE COMES ON AFTER NOT PLUGGED IN TO POWER
My KV34HS510 Led flashed 4 times then stops for a few seconds and repeats. Is this the D Board MCZ3001D IC problem?
Feb 02, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
SONY TV MODEL kv-27s40 BLINKING RED LIGHT 2 BLINKS
The 2 blinks usually mea an over current problem. Perhaps the most common cause of this is a shortde Horizontal Output Transistor (HOT). If you can solder, you should be able to repair this yourself. Realize that there are potentially dangerous high voltages present inside the set even when unplugged. Look for a 3-legged ransistor attached to a heatsink close to the flyback (part with large red wire coming out the top). The part will be marked C5438 or something similar. Post that marking here nad I'll confirm the entire part number.
Keep us posted.
Dan
Feb 23, 2009 | Sony KV-27V42 27" TV
Power on-off
hi it could be from moving it, you have disrupted the refresh rate, every time ur tv has to change the image it needs to refresh!t is a internal problem that needs to be repaired.
Feb 05, 2009 | Sony KV-27S40 27" TV
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
SONY WEGA TRINTRON MODEL KV36FV15 RED LITE FLASHING
The model number is KV-36FV15 and blinking is constant no pause
Aug 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron Color TV KV-35V65 - No Picture, red light stand/by timer flashing
A reset won't fix this. The standby light should be blinking a repeated count with a 3 second pause inbetween. Post that count here. That will indicate the circuit/condition that is preventing the set from turning on.
Thanks,
Dan
Jul 18, 2008 | Sony KV-35V65 TV
Please Help
Is the red light flashing a code ? exaple 4 blinks pause 4 blinks ?
Apr 07, 2007 | Sony KV-27FV16 TV
Televison & Video Logo
110 people viewed this question
Top Televison & Video Experts
Electro Med Services...
