Question about Canon PowerShot A540 Digital Camera
My Canon A540 cannon be connected to my PC
It was Ok for downloading photos to my PC. Not sure what happened, starting couple days ago, the camera cannot connect to PC anymore.
    Novelist:
  • 130 Answers
Here are the steps to take.
1. Establish whether or not you have a connection between your camera/computer by going to your start button, control panel, system, hardware tab and device manager. The camera must be powered on and in playback mode (should automatically go to playback mode when connected, camera's screen should go black if there is a connection). Make sure you have a fully or nearly fully charged battery in your camera.
2. Once in device manager, look under Imaging Devices. If your camera is properly connected it should show up as Canon Powershot SD800. If it shows a yellow exclamation point, there is a driver issue, and even if it doesn't show a yellow exclamation point, you may want to update your driver anyway by right clicking and having the system search automatically for driver updates. If download of driver begins, great...once finished, restart camera and your problem may be resolved.
3. If there are any other imaging devices, you may have to temporarily disable them to avoid conflicts.
4. If you have any other imaging software running, exit or close the program in your system tray (down by your clock in the right hand corner of your computer's desktop.
5. Try again to connect.
6. If you are on a desktop, try a rear usb port vs. a front port. You can also try a different port on a laptop. After each change, try restarting camera to establish connection.
7. Go to start/My Computer and look for the icon for your camera...you will be able to download images even without Canon software loaded onto computer so this is not a software issue if you have no hardware connection. If you see the icon, right click on it and choose Get or Import pictures. From there the default Microsoft scanner and camera wizard should launch and you will be able to import your images.
8. If still no connection, try going to Start/Run and type in services.msc here you are looking for 4 services to be running. Check under status of each service and make sure it reads that each of these services are started.
  • Canon Camera Access Library 8 (if Canon software loaded)
  • SSDP discovery service
  • Universal Plug and Play Device Host
  • Windows Image Acquisition
Once all of these services are started on your computer, restart camera once again. If any of the last three services are not on your computer or are not started, connecting will be a problem.
If all of these steps fail, try purchasing an SD card reader from your local electronics store for around $12 and download images from there. Canon also offers lifetime technical support for your Powershot, so give them a call if none of these steps work or if you would like someone to walk you through it.
Best of luck to you!
MrsJGreen
Posted on May 30, 2008
  • 477 Answers
Try z diffrent computer and if that don't work a diffrent cable. If you are still having a issue it is your mainboard and it needs replacement that can cost 70.00 plus check out my page www.digitalcamrepair.com
Posted on May 29, 2008
Window Vista not recognizing my Canon Power Shot A540 to download
I recommend getting a USB card reader for your memory card.
You should make sure that the camera is on for the transfer. If that doesn't work, try another USB input.
Nov 17, 2012 | Canon PowerShot A540 Digital Camera
I just got a new computer and need to download pictures from my powershot A540 digital camera but cannot remember what or how I once downloaded pics on my old computer. I have the usb port and need...
You can download Canon software from
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a540#DriversAndSoftware
You might want to consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Dec 29, 2010 | Canon PowerShot A540 Digital Camera
Cannon Powershot A540 SanDisk SDHC 4 gb I insert the card and receive a memory card error. Can't format
A 4 gb memory card is beyond the capacity of your Cannon A540. It is too large. I would stick with a 1 gb card in that camera.
May 28, 2010 | Canon PowerShot A540 Digital Camera
Cannon powershot a540 won't downlad pic
Please see the following blog article, as it describes the use of a card reader as a much easier, faster, and less error prone way to download your photos. In fact there are several important reasons discussed in the article for using a card reader vice downloading from the camera. USB Card readers are also very inexpensive these day, with cost virtually not an issue: http://camerarepair.blogspot.com/2009/01/how-do-i-download-photos-or-pictures.html
Jun 20, 2009 | Canon Cameras
Asking what to do?
8 GB is more than your A540 can handle. You can check with Canon, but I'm pretty sure that the max that your camera will understand is 2GB. Additionally, your 8GB card is most assuredly an SDHC card and not a standard SD card. Your A540 also does not understand SDHC format. The max card that you should buy for that model camera would be a 2GB standard SD card. These are very inexpensive these days and run about $6, shipping included:
http://www.amazon.com/s/ref=nb_ss_gw?url=search-alias%3Delectronics&field-keywords=2gb+sd+card
Jan 20, 2009 | Canon PowerShot A540 Digital Camera
The focus on my cannon powershot A540
Do you focus and then push the shutter button half way down to lock in that focus? Then all the way to take the picture?
Do you support the camera on a tripod or kneel down and support your arms on one knee or lean against some object to keep the camera steady> You can even press your arms tightly against your body before you focus and shoot. And be sure to press the shutter button very gently when you shoot so the camera will not shake or move.
Do you have the camera on the right mode for the photo you are attempting to take? Such as night/macro/action/ etc. Try taking photos on just the automatic mode to see if you can get focused shots. Make absolutely sure your camera is not in Macro mode ( a picture of a little flower on the screen) unless you are doing extreme closeup shooting.
Go to your menu>then setting> then set your camera back to default settings if you can. Or if you are unsure how the camera is set. If you do not have your manual you can go to the Canon website at www.canon.com and click on support or downloads and find the manual for your camera and download it. That may give you the answer you need as well.
Please get back to me if you do not have any luck and send along more info such as camera age.
Aug 08, 2008 | Canon PowerShot A540 Digital Camera
Canon A95 - Download freeze after several pics
Reset the camera settings back to default.. thats all it will be alright!
Mar 19, 2008 | Canon PowerShot A95 Digital Camera
Cannot download photos
What is ptp utility new to me. I suggest the first thing to do is if you have the software from the disk loaded - you un install it. Restart the computer - plug camera in and set it to upload mode. Windows scanner/Camera Wizard will take you along from there. If it does not change the USB port. Come back with the next move
Sep 03, 2007 | Canon PowerShot A540 Digital Camera
Canon PowerShot A540 Digital Camera Logo
150 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
