Question about JVC RX-D302 7.1 Channels Receiver
My JVC RXD302 has started issuing a very loud hum at power up. It tends to diminish over time but the time it takes to diminish seems to be getting longer. Any ideas where I should start to look? My initial thought was power supply capacitors, but I haven't been inside the unit yet.
3 Suggested Answers
mcmonte
  • 8 Answers
SOURCE: JVC drains battery when OFF, puzzling
The problem is actually the wiring. Check the installation manual, I guarantee the "pro" installer took a shortcut.
There are two power wires (yellow & red +) and a ground wire (black -).
Now, black goes to chassis grounding point. Easy.
Yellow goes to a live terminal in the fuse block for constant 12V.
This retains the settings and clock etc.
Red goes to an ACCESSORY terminal in the fuse block (so key must be turned to at least ACC to allow it to be switched on).
But in the case of my car, the idiot who installed it ran the red wire directly to the + battery terminal. That's wrong, and will drain the battery.
Google for an installation manual, I'm certain your JVC head units will be the same procedure.
Posted on Mar 03, 2013
gopakumarg43
  • 75311 Answers
SOURCE: My jvc 47 inch flat screen will not go past the initial jvc start screen. Any ideas? I have already tried to reboot by turning on and off several times.
Corrupted firmware. A firmware update is necessary. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Firmware update procedure to many popular brand electronic devices are given.
Posted on Jun 09, 2015
There is a loud rumbliing sound that seems to be coming from the motor (haier hlp140e) it's ability to heat also seems diminished. The rumbling used to happen on and off, but now it happens all the...
sounds like bearing noise and drum hitting on inside of outer body - naturally the drying process will be somewhat diminished and eventually the whole drum will compromised and collapse . Advice is to purchase a new dryer .
Jul 25, 2011 | Haier HLP140E Electric Portable Dryer
Loud humm when the drive channel is on
I suspect the power supply has an issue. Most likely bad filter capacitors. This could cause "motorboating" where power is drawn and supply voltage collapses and then recovers repeatedly.
Time for the repair shop. The parts cost should be nominal... labor... well...
Mar 15, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Dishwasher was making a loud hum. I turned it off and started it this morning. Seemed to be working fine, but after about 5 minutes it started making the same loud hum. The first time it seemed to be...
The loud humming noise can be due to the pump sticking if a piece of debris gets trapped in it or an intermittent fault on the pump capacitor or starter relay.
Check out these links below to get tutorials and advice on how to clean the pump or change the capacitor or relay which is cheap and simple job. How to replace Dishwasher pump Bosch Siemens etc Dishwasher Repair Manual Table of Contents http://www.ukwhitegoods.co.uk/help/fault-codes/dishwasher-fault-codes.html?start=25
I hope this helps
Feb 05, 2018 | Jenn-Air 24 in. JDB1100AWS Built-in...
Humming
Chances are it's the tires rather than the engine.
Does the hum diminish if you back off the accelerator? If yes, then look at rear axle pinion bearing. If no, then feel across the tires. They should be smooth across. If they're rough, they will make a loud howling noise.
Aug 16, 2009 | 1996 GMC Jimmy
Loud humming noise coming from 360
The loud humming noise is usually the DVD drive. It is very fast but is very loud. If you have the NXE dashboard you can download games to you Xbox 360 to run them from the hard drive (you will still need to put in the disk for copy protection issues). The Xbox should make less noise then. Try to mount the Xbox 360 on a hard surface which is in contact with a soft floor to reduce the noise travelling through your home.
If it is making a loud noise while there is no disk in the drive then take the console to a Microsoft dealer whenever you can to have them take a look at it.
Feb 13, 2009 | Microsoft Xbox 360 Console
Question about JVC Ipod adapter
Hi Deano,
My query was about a device that transmits the walkman to the car radio; the device produced a loud rumble - I think the power was too high; when I, with the use of a rubber band hold the start button down, the light stays on and I get no rumble or hum. Hope that helps.
Roger Montgomery, Chelmsford, England
Nov 26, 2008 | Car Audio & Video
Lots of hum from both speakers
Well folks I solved my problem and the amp has never sounded better. It had always hummed and now it close to stone quiet. The secret was it really never a problem with the amp. The problem was the result of either the pre-amp, interconnect cables, or the combinations of them. The solution came when I added a "drain wire" or ground to the cable I was using. There must have been a ground loop or some in-balance that required a wire to be connected to the earth (-) side at the source on the interconnect and then left unconnected at the other or receiving end of the interconnect. Anyway, no more hum, and the solution took some spare wire and solder.
Nov 17, 2008 | Adcom GFA-5503 3-Channel Amplifier
Sunfire Mk II hum (different from greekboy post)
I had this issue a few years ago and the power cable from one of the inner terminals had come loose. It was still touching but whenever the sub would really pound it would jump off the connection and then reconnect causing it to hum. It was the most annoying thing ever so I finally pulled off the amp plate (super easy) and you could clearly see the loose wire. I had to use a good soldering iron to put it back on since it's a pretty fat wire. If you're not under warranty anymore then pop the back off and see if that's the issue.
-Dylan
Aug 17, 2008 | Sunfire True Sub MK II Subwoofer
No output from d110
Hi Chadwik
The fact that you do get hum when you partially remove one of the RCA's would tend to say that the output stages are working ok. Is the hum "solid" and bassy, or distorted?
There are a few issues that these subs have had, mostly to do with capacitors in the power supply failing. If you are up to it, I can talk you through repairs to it.
regards
robotek
Jun 16, 2008 | JBL PSW-D110 Speaker
Philips CDR775
Bad earth / failed capacitor on the PSU board. I sell replacements via ebay or can email a service manual for you to get fixed locally. Fluffcat1
Oct 24, 2007 | Teac CD-RW880 CD Player / Recorder
JVC RX-D302 7.1 Channels Receiver Logo
43 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
