Question about Frigidaire Dishwashers
The door on my dishwasher doesn't click shut properly. can you help
  • Frigidaire Master
  • 3,247 Answers
I will try and find out the reasons but will need the actual model no. of the dishwasher.
Some of the reasons could be
- door seal / gasket is not sitting properly
- door latch is not aligning properly
- the door springs are not having correct tension etc..
- the dishwasher is not levelled correctly under the counter.
I will need to understand how your model is built before being certain.
Posted on Oct 08, 2010
I have replaced door latch because door was not clicking shut. It now clicks shut but dishwasher does not work. It does work however when door is closed but not clicked. Also works when door is open!...
I appreciate your post, Lorraine McGowan!
Based off the information you have provided you have provided your Electrolux dishwasher is not working properly when the door has been shut and clicked. From what you have described it sounds like your door latch, wiring harness, or control panel could be the problem. I would highly recommend contacting a professional technician for proper diagnosis and repair. This will help you to avoid any unnecessary part purchases. Hope this is helpful. -Matt
Feb 21, 2015 | Electrolux Dishwashers
Whirlpool dishwasher door will not click shut to allow washing cycle to start
Check to be sure the gasket that is between the unit and the door is in its proper palce, it may be knocked out of its normal spot and keeping the door form closing all the way where the latch would engage.
Apr 22, 2013 | Dishwashers
Haier ESD300 -many concerns -- no answers -WHY NOT?
Sounds like your control board is in need of replacement. For the time being instead of shutting off the breaker just close the door to the unit but don't latch it. To start the unit the handle needs to be locked unless there is something that I am missing. Good luck...
May 11, 2017 | Haier ESD300 / ESD301 Built-in Dishwasher
I have a Bosch SHU9955US/14 (Integra) dishwasher. There is currently a 0 with and asterisk showing on the display and the unit will not run.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 29, 2012 | Bosch Dishwashers
My Beko MW5104 is frozen and does not respond to any settings. It is permanently on at spin/end with the green light on. I can switch it on and off. I have unplugged it from the mains and switched it off...
Sep 28, 2012 | Dishwashers
Jenn air. Quiet seriesii won't start. Lights on panel flashing. Tried turning off power for fifteen minutes at breaker.
My dishwasher door wont shut
see this causes, and use the common sense. God bless you
When your dishwasher door has a problem, check these: Latch Springs Hinges Door seal Latch The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem. If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch. Springs Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs. Hinges The hinges are important to the door closing properly. If they're bent or deformed, you probably need to replace them. Once bent, only rarely can they be straightened well enough. Door seal If your dishwasher is new--or if you have just replaced a door seal--the door may be difficult to latch for a week or two. If the tightness persists, though, try adjusting the latch, if it's adjustable. If it's not adjustable, there's probably nothing you can do immediately. But try running the dishwasher on the highest heat cycle to help the seal conform to the door. Otherwise, the seal should compress over time.
Sep 19, 2012 | Hotpoint 24 in. FDW60 Free-standing...
Bosch dishwasher makes noise but doesn't start
When you start a wash cycle on your Bosch dishwasher and it does not work, stay calm. It could be something simple, especially if you just installed it. Make sure the power cord is connected properly and a circuit breaker did not trip. How to Troubleshoot Bosch Dishwasher That Doesn Fill With Water
Sep 25, 2017 | Bosch Dishwashers
Idesit dishwasher
it sounds like the element isnt working properly.locate the element connections by removing the lower kick panel and turn the unit on to the drying cycle.use a volt meter and check the voltage.if you have voltage there than turn the circuit breaker off remove the wires to the element and check with the meter for continuity,let me know.
Nov 10, 2007 | Indesit 24 in. D63 Free-standing...
Dishwashers Logo
46 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
