Question about Eureka 4700A Maxima Bagless Upright Vacuum
How do you remove a front wheel? I'm a girl ... do i need any special tools? Thank you!
  • 171 Answers
I don't believe any special tools are required to do that . Just unscrew it or un bolt it which ever is required and then put in the new one. you will ba able to access this by removing the bottom panel whick is also held on by screws. The best thing is to have a multi-driver so you can change ends if you need to. There should be 5 or six different bits in the handle of the multi driver and they are kept there for easy accessibility.Just take your time and go slow and just look closely at it as it is not a terribly difficult task.Some are more tricky than others but to my knowledge you have one that is quite straightforward if I am not mistaken. If you run in to problembs just write me back and I will try to guide you through it . Good luck and dont forget to click one the yes if this helped.
Posted on Oct 07, 2010
How can you clean spots off carpet
Office pros cleaning service is expert in carpet cleaning.They categorize our cleaning program depending upon carpet condition. Offer three types of carpet cleaning programs.
Steam clean/ Hot water extraction
Bonnet clean
Very low moisture encapsulation clean.
Office pros cleaning staff expert in spot and stain remove from carpets,use the green certified product for cleaning.So finnally I suggest for Office pros cleaning for remove the spot and stain from carpet.
Commercial Office Carpet Cleaning
Dec 30, 2013 | Vacuums
Change front wheel on x300
The front wheel on a Nilfisk Extreme 300 is changed by removing the 3 screws inside the bag chamber. From memory they are a torx screw driver size 15 or 20. Basically remove the bag and take out the 3 screws in the middle of the chamber - the wheel will fall off once you lift the machine up. If you need to buy a replacement wheel you can find one here.
Nov 10, 2013 | Nilfisk 11730410 Micro Filter Polyester,...
Help! i have a whispertone 300 model 116 28612790. the retractable cord is jammed & i could only get the front part of the canister open that houses the motor, etc. there are only 2 screws to open it...
even if you get it apart chances are it needs a new spring but it requires a special tool to get the rubber molding off that separates the top from bottom and sears repair guys and vacuum shops have them. I would take it to a used vac store and get them to fix it before you try yo remove the rubber seal as it will not go back on well and that will cause the machine to not get aproper seal and lose airflow.
Oct 06, 2010 | Kenmore 23313 Whispertone Bagged Canister...
How replace rear wheel bissell 9400?
Hi There,
Ok, so in order to get the wheel assembly back into the machine, you're going to have to take apart the machine, or at least the housing underneath of the clean/dirty solution tank, as well as the housing that the shampoo solution sits on. I took pictures to help you on this repair.
Here's what you need to do:
Step 1. Remove both the Shampoo tank and the Clean / Dirty Water tank from the machine completely and set them aside. You'll need to now remove the housing that the shampoo container sits in by unscrewing the 5 screws that I've circled in red:
Step 2. After you've removed these 5 screws, lift straight up on the housing that the shampoo tanks sits in. You'll now need to remove the screws that I've circled red to remove the complete lower housing that secures the wheels in place:
Step 3. You'll need to unhook the clear housing in the front that holds the brush cover over the bottom housing. You may just use a flat head screw driver, or something to pry this housing off the bottom plate:
Step 4. Open up the bottom housing by grabbing the raised portion of the motor housing in the back of the machine. Simply re-insert the wheels into the grooves now, and after the wheel is in place, re-secure the lower housing over top of the wheel to keep it from coming out again. The bottom plate is what goes over top of the wheel to keep it in place.
If you have any follow up questions, please just add a comment here on Fixya, and I'll do whatever it takes to make sure that you get your Bissell ProHeat fixed. I'm not just one of these "experts" that just gives you vauge information and really doesn't know or care about getting your problem fixed. My concern first and foremost is to see you get your problem fixed, and I'm happy to answer as many follow up questions as it takes to get that done. I hope this helped!
Thank you,
Chris Jones
GoVacuum.com
Jul 21, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Dyson dc11 replacing motor
DYSON DC-11 MOTOR REPLACEMENT
1. Remove dirt cylinders as normal
2. Using large flat screwdriver, remove airway splitter and hose
3. Undo 6 Torx screws from top and one at the back under tool holder
(Note that 2 front screws are shorter)
4. Make sure the screws are completely withdrawn
5. From the back, withdraw tool holder section
6. Unhook and withdraw hose holder section
7. Place large flat screwdriver behind the wheels and forcefully snap them off
8. Remove 2 more screws under each wheel
9. Cover now lifts off
10. Motor pod is now visible. Remove its 4 screws and lift its lid
11. Motor can now be lifted out. Disconnect its 2 wires
12. Remove the rubber base and transfer to the new motor
13. Connect wires, Red to Brown (Live) and Black to Blue (Neutral)
14. Make sure motor is correctly fits on its alignment studs in the pod and replace its cover and 4 screws
15. Replace top cover of machine, and the 4 screws under the wheels, but no other screws yet
16. Turn machine on its side and hammer each wheel back on - take care that no fingers are under wheels while doing this
17. Stretch and snap hose holder back into position
18. Slide tool holder forward into position
19. Replace the 6 screws into top section, and one into tool holder section
20. Replace filters, airway splitter and dirt cylinders, and the job is complete :D
May 22, 2010 | Dyson DC11 All Floors Bagless Canister...
The power button quit working
Please click here to see the part diagram for the Hoover Windtunnel Self Propelled model U6446-900
Greetings from GoVacuum,
For replacing the switch, you need to remove the 2 screws that are in the back of the vacuum where the handle connects to the vacuum bag housing, Part # 50 on the first page of the diagram. After the screws have been removed, you may simply slide out the handle from the rest of the vacuum cleaner. You can then at this point view the outside of the switch, however as you'll find you can't replace it from this side. You'll then need to go into the where the tool caddy is in the front top part of the vacuum cleaner. Remove the attachments from the tool caddy, and then you'll need to remove the screws that hold the tool casing in place. Remove screws pictured # 35 on page 1, and the tool caddy is item # 17.
Once the screws and the tool caddy are removed, you may then see the rest of the switch, and the leads that connect to it. The easiest way to remove the screw is to use a flat head screwdriver and pry the switch out from the back of the vacuum cleaner after removing the leads from the switch. The new switch that you'll need to purchase is Hoover part number 28161067 which can be found online here: Hoover Windtunnel Main On / Off Switch Part Number 28161067.
I hope that this helps you replace the faulty switch in yours (and your parents) vacuum cleaners. If you need to place an order for the switch, please give us a call at 1-866-468-2288.
Thank you,
Chris Jones
GoVacuum.com
Mar 18, 2010 | Hoover U6446-900 WindTunnel Bagged Upright...
How do you remove the roller brush from a dyson vacuum cleaner
you will need a special bet tool. you can buy one from ebey. search for "dyson special bet tool" it is about $15. don't use your hands as the belt is very tight and you will hurt your fingers.
Oct 12, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My brush is no longer working on my bissell healthy home vac. when i try to turn it on it makes a high pitched squealing sound. I'm pretty sure it needs a new belt but my husband is having trouble getting...
According to Bissel, they should be standard phillips screws. Nowever - things change.
This is a general guide from Bissel for belt change -
BELT CHANGE _ CLICK HERE
Check your model number on that site for exact details.
If the screws are Torx (star) or other security screws, tool bits are available from Screwfix -
SECURITY SCREW BITS
That fit standard loose-bit screwdrivers.
Hope that solves your problem.
Thank you.
Sep 22, 2009 | Bissell Healthy Home HEPA Bagless Upright...
I have a DC14 with a bad belt to the roller.How do I remove the clutch that operates the belt to turn the roller. I am holding the assembly that houses the clutch and all screws are out, it appears the red...
You need a special tool to remove the clutch. Contact the Dyson Helpline so that they can refer you to an authorized Dyson dealer in your area who would have such a tool and who can fix it for you. The alternative is to purchase a tool and visit YouTube for instructions on removing it yourself...Google it, you should find the tool available for purchase.
Jul 13, 2009 | Dyson DC14 Bagless Upright Cyclonic Vacuum
How to remove bottom plate
you will need either a t15 or a t20 torx bit. you should find these at any hardware store.
Aug 24, 2008 | Bissell 5770 Healthy Home Bagless Upright...
Eureka 4700A Maxima Bagless Upright Vacuum Logo
62 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
