Question about Toro Garden
Z380 zero turn. The blades kept disengaging and now the mower wont start at all?
ccrozier_agr
  • 36 Answers
SOURCE: I have a riding mower
Check the wiring around the deck, as all ride on mowers have a cutout system wired to the deck, seat, & also on the rear basket.
One of these wires must be getting earthed to ground causing the engine to shut down.
In most cases I see a lot of mowers coming in with these wires removed . This is not good practice as you could get your toenails trimmed when getting off the mower. So we always replace them !
Posted on Nov 27, 2008
  • 57 Answers
SOURCE: Craftsman 42" mower deck won't disengage
Try pulling on the cable coming down to deck. This cable might be your problem. Also check that the spring on the end of this cable is present and functional.
Posted on May 19, 2009
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
SOURCE: My cub cadet zero turn mower won't engage the
My cub cadet ZTR M60, under the mower in the rear is 2 wires going to the electric clutch my wire fell and the belt cut one of them. I spliced it and it was good to go. Signed:Acorn tractor
Posted on Jun 05, 2009
  • 8 Answers
SOURCE: have a cub zero turn 52 inch cut the blades wont
sounds like one of three possible problems ....one - there are safety switches that prevent engagement of the blades,,,,,two - the electric switch which engages the electric clutch blade pulley is bad....or three - the electric clutch blade pulley assembly is bad.....first.....make sure all ur connections are tight to the safety switches and electric clutchblade pulley.....then, if your able to read and follow a wiring diagram, get the wiring diagram for your tractor and a 12 volt probe light (with probe point end) with a ground lead....first, ground the clamp end to the frame and probe at the electric pulley clutch plug to see if power is getting there...if not...follow the wiring diagram to the next switch location the power lead comes from....if one side of the swtich shows power and the other side doesn't with the switch in the correct run position....then the switch or connection is bad.....if it probes okay...go to the next switch....follow this logic from both sides of the from the electric pulley blade clutch plug until you isolate the switch or plug problem....if everythin tested is good....then it's the electric clutch pulley assembly that need replacing.....hope this helps.....
Posted on Jun 07, 2009
Is there any way to bypass the switch that engages the blades on my Husqvarna RZ4219 zero turn mower so that it will start?
get a test light, this will make troubleshooting alot easier. check seat switch,stick,neutral,guard and the power in and out of the key. 6 12V Circuit Tester with 5 ft Lead
Sep 04, 2015 | Husqvarna RZ4219 42" 19.5HP Zero Turn Lawn...
Toro zero turn starts fine and stalls as soon as I disengage brake
Sounds like the seat switch is not reading you are in the seat. Without a wiring diagram, it is difficult to say exactly.
May 30, 2015 | Toro TimeCutter Zero Turn Lawn Mower...
Mower was running shut off now does nothing when i turn key
If electric start check for low battery or loose battery cables. Could be a bad starter.
Jun 21, 2014 | Toro 52" 27hp Z Master Zero Turn Lawn...
Clutch won't disengage on my Riding Mower
WITH THE ENGINE TURNED OFF, open the hood and watch the engagement cable. engage mower lever and then disengage the switch sounds happy, possibly the cable is starting to seize up
Apr 19, 2014 | Husqvarna Garden
Blades won't turn on my simplicity zero turn, I have replaced the pto switch already.
IF i'm not mistaken, this model has a safety on it, when your mowing and back up, the blades temporarily disengage until no longer going in revesre and then start back up. These are famous for getting out of adjustment, if it is out of adjustment the sensor is registering as if you are backing up. I hope this helps you
If you need further help, I’m available over the phone at https://www.6ya.com/expert/steve_f5a6ca85b5d1ffc9
Oct 03, 2013 | Simplicity Citation 61" 28HP Zero Turn...
When trying to start my husquavarna 4824 zero turn mower it does nothing starter does not engage and battery is ok
Check your blade ingage switch. Sometimes they stick. You can jump start it by jumping across the solenoid switch beside the engine. I sometimes have to engage and disengage my blade switch and it starts. Hope this helps.
Sep 30, 2013 | Husqvarna Garden
Mower running but when blades are engaged they stop and start back up
More than likely the issue lies somewhere in the safety switch for the reverse. On most of those mowers when you back up the blades will disengage and then reengage one no longer backing up, it probably just needs adjusted, sounds as if it is out of adjustment and over sensitive. Hope this helps
Oct 01, 2013 | Husqvarna Rz4623 46" Ztr Lawn Mower Zero...
Bracket clutch anti-rotation
Without the anti-rotation arm installed when you engaged the PTO the clutch spun and probably ripped out the wires connecting it to the harness. This can be repaired but is tricky. If you have a Husqvarna dealer close by, it will save you several hours of labor to have them correct the problem.
Mar 07, 2017 | Husqvarna Garden
After replacing the belt, new pulleys, and bolts, my mower wont disengage the blades when i disengage the lever. when i start the mower, the blades are off, but once i engage the lever, they start, but...
sounds like the linkage to your blades, check your lever, to make sure its working right may need some grease, it may be sticking and not fully engaging, or doing its job when its supposed to
Oct 17, 2009 | Craftsman Garden
Garden Logo
57 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
