Question about Linksys WUSB54GSC Compact Wireless-G USB Network Adapter w/ SpeedBooster [WUSB54GSC] (LS-SB54GSC)
Not working windows repair says USB hardware or software problem. I notice it is Hot to the touch. Is it screwed?
  • 33 Answers
Check from Device Manager if u can repair or Reinstall Driers
or Try to Uninstall & Reinstall the adapter Setup Driver again( from CD )
All the BEST.........
Posted on Oct 07, 2010
How do i get my computer to see my 1350 garmin nuvi?
The problem could be the computer's USB port or the cable. Make sure that you aren't connecting to a USB hub or a dock. Try a different USB A to mini-USB cable (match the number of pins and shape of the mini USB connector). Try installing the Garmin Agent software manually from http://www.garmin.com/agent .
Make sure that the Nuvi 1350 is fully charged. Disconnect the USB cable from the computer and turn off the Nuvi. Then turn it back on. Reconnect the cable to the computer at a different USB port. (If you are using a front port, try one of the back ports. Do not just switch to a top or bottom port since every pair of ports share a controller.) If you are using Windows, check if the Nuvi is listed as a mass storage device (press the Windows key + E or double-left click on the My Computer (Computer) icon). Recent security changes prevent USB devices from triggering the Auto-play feature on Windows. (You can change this from the Control Panel in the Hardware section for AutoPlay.)
Next try using a different computer if you can. If the Garmin Nuvi correctly communicates with the second machine, you may want to check the USB controller. Go to the Device Manager (from the Control Panel under Hardware) and expand the Universal Serial Bus controllers. You can remove the driver or check for updates. (Check for updates manually from the computer manufacturer as well.) Reboot the computer and check if the ports work. Check if other USB devices work on those ports. USB ports can fail. Sometimes, you might notice a device getting hot while connected to a failing port. Other times, the port just isn't getting enough power. Check if the power supply is sufficient for the number of devices both inside (hard drives, video card, etc.) and externally connected to the computer.
I hope this helps.
Oct 17, 2014 | Garmin nuvi 1350 Car GPS Receiver
Do not find my datatraveler when plug into computor?
By DataTraveler you mean a Kingston USB memory stick, correct?
Try plugging it into a different USB port.
If it doesn't, try plugging it into a different computer. Does it work there? If not, then your USB stick has probably failed.
If it works on another computer but not on the first, it probably means that the USB Storage driver software is not loading properly on the first computer. First, restart the computer. Does it work now?
If not, then you probably have to repair or reload the USB storage driver.
copied from Toms Hardware forum
"Go to start menu > Control Panel > Hardware and Sound > Device Manager.
If it's not already expanded, meaning showing the items listed under it, click the arrow next to "Disk drives" and see if it lists a Memory USB Device or something similar. Right click the Memory USB Device, or whatever your memory stick is called, and click "Update driver Software" then click Search Automatically for updated driver software. If that finds something then good, problem might be fixed, if it says "The best driver software for your device is already installed," close that window and right click the drive again and click uninstall then press OK. Then at the top of the window you'll see an icon that looks like a computer with a magnifying glass on it, if you hover over it it will say "Scan for hardware changes" click that and it'll reinstall the drivers."
Jun 25, 2014 | Computers & Internet
IPhone gets hot, wont turn on after that.
there is a hardware issue. Apple should give you a replacement. If you're out warranty, you can try to open it and replace the logic board. You can get the part at iPad Repair and there is a guide that shows you how to open a kindle and install parts at iPad Repair Guide.
Feb 22, 2010 | Apple iPhone Smartphone
HP Deskjet Printer; D2460 USB connectivity problem.
Go to Control Panel > System > Hardware Tab > Device Manage > Universal Serial Bus Controllers > Delete or uninstall any usb root hubs. You may notice your mouse may stop working after this. Try a reboot and then windows should redetect usb devices. You may have to delete some other usb root hubs again if this does not work the first time.
Jun 29, 2009 | Dell Inspiron 9100 XPS Latitude D400...
SYNC TO COMPUTER
As far as hardware goes, all you should need is the USB cable that comes with it. If you mean software, I assume there's software that comes with it as well, or you can just use Windows Media Player (since it comes with all Windows PCs).
Mar 29, 2009 | Creative Labs Zen Touch MP3 Player
Iomega external HDD not recognized as usb 2.0 (high-speed). PC thinks it's usb 1.1. Worked fine for more than a year.
Hello John7788,
Well this is either....
1. Software
2. Hardware (computer)
3. Hardware (HDD)
If its 1 then just simply re-install the drivers part for windows.
If its 2 then you would be better moving it to another usb socket as it may be just a fault on the single socket. If you don't have another socket then im sorry to tell you it means a trip to the repair shop or getting a new usb card to slot in to the motherboard.
If its 3...well...try the manufacturer for a repair.
Hope that helps you a little.
Sep 16, 2008 | Computers & Internet
I recently bought a HNC model CTGJD2028 3D Optical USB Plug and Play Mouse for my Compac Deskpro EN running XP Pro. Plugged mouse into usb port. Get a Popup Bubble – Found New Hardware – Mouse. Message...
UPDATE YOUR WINDOWS SOFTWARE FROM MICROSOFT OR YOUR VENDORS SITE, THERE MAY BE MORE SOFTWARE PATCHES FROM THE VENDOR TO FIX THAT TYPE OF PROBLEM
Aug 11, 2008 | Computers & Internet
Motorola V3i Modem driver for windows vista
http://direct.motorola.com/hellomoto/in/support/driversNplugins.asp?country=aus&language=ena
hey guys try this link to download the usb drivers.. it might work on vista cuz this is the latest possible version
Dec 06, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Linksys WUSB54GSC Compact Wireless-G USB Network Adapter w/ SpeedBooster [WUSB54GSC] (LS-SB54GSC) Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
