Question about GE Refrigerators
Refrig is clicking and not cooling when it clicks the lights go on and off. This will happen for awhile and then the refrig starts to work again for awhile. I think this is a starer relay
  • GE Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 08, 2010
I have a Whirlpool mod. ED5LHEXD00 refrig. I left home for 3 weeks in Dec. with the house temp. set to 50 deg. F. I got home and discovered that the refrig./freezer was at room temp and all the food had...
If Fridge working fine now, the problem may be is Hydro Grid.
When the fridge just start, the compressor is running with high pressure of Freon. If Hydro power has voltage surge or power Off/On ( suddenly ), the compressor should be stuck, the overheat protection switch will actived, than fridge will stop working.
The noice of "click" - properly is overheat switch auto-reset.
May 28, 2017 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Not cooling clicking sound refrig compresso and
IT'S MOST LIKELY THE START RELAY/OVERLOAD PROTECTOR ON THE SIDE OF THE COMPRESSOR. UNPLUG UNIT AND PULL START RELAY OFF AND SHAKE. IF SOUNDS LIKE IT'S FULL OF GRAVEL IT'S BAD, OR GET VOLT /OHM METER AND CHECK CONTINUITY BETWEEN THE START AND RUN TERMINALS ON BACK SIDE OF RELAY, WHILE YOUR THERE CHECK CONTINUITY BETWEEN THE BACK SIDE OF OVERLOAD AND WHERE L1 WIRE COMES IN FROM THE HARNESS. IF ALL THAT CHECKS OUT THE COMPRESSOR MIGHT BE BAD OR DRAWING TOO MUCH CURRNET FOR THE FACTORY START DEVICE. YOU DIDN'T NOTE A SERIAL #, SOME OF THOSE MODELS WERE UNDER RECALL FOR THE RELAY/OVERLOAD PROBLEM.
Oct 06, 2010 | Maytag MSD2756G Side by Side Refrigerator
Refrig was clicking on and off now nothing not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 02, 2010 | Frigidaire FRS26H7CS Side by Side...
Refrig & freezer not cooling properly
I believe the start relay and start capacitor with the overload will need replaced. That is easy and should solve your problem, Sea Breeze
Aug 26, 2009 | GE Profile Stainless Bottom-Freezer...
Freezer and refrig not cooling
it might be a cooling gas problem
you first check it by caling l service men
also please give me ratings on this........
Aug 25, 2009 | Whirlpool ED2FHEXN Side by Side...
Bulb does not light on refrig side. When it happened it popped out the two control knobs. Reset control knobs and replaced bulb but the bulb will not light. After resetting the knobs the refrigerator...
i would alssume(knowing about this refrig) that the leectronic control board hasgone bad. the board is located behind the unit next to the compressor, inside a white housing, if you rmeove this board yull probably see a "burn" on one or more ofthe resistors, this is what controls the lighting in refrig sect, not affecting the cooling but only lights
Mar 04, 2009 | Refrigerators
Refrigerators Logo
53 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
