Question about Emerson Heating & Cooling
It glows red but will not lit and there is kerosene in the heater
  • 59 Answers
You have a bad gas valve or a bad sensor in the furnace. its not allowing the 24 volts to flow to the gas valve turning it on.
Posted on Oct 08, 2010
Propane torpedo lights but doesnt stay lit
I'm confused. First you listed this as a propane torpedo heater. Second, it's a problem with and All Pro PK115 T Forced Air Kerosene Space Heater. And finally, you say "propane torpedo lights but doesn't stay lit."
Which is it? To really help you, I'll need the correct manufacturer's name & model number. And whether it's propane or kerosene fired?
Thanks.
Mar 02, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
Is the front of the fuel powered heater supposed to glow red?
Hi, and the answer is yes. All fuel powered type heaters will glow red, or bright orange. Example, a space heater that runs on #2 fuel oil, natural gas, gas, kerosene, ect. will glow this way, so do not be alarmed. This is normal.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Jan 04, 2011 | Dayton Heating & Cooling
No start i cant see ignitor get brite red dont seem like im getting fuel
If the ignitor isn't glowing it isn't a fuel problem. It may be a pressure switch or bad ignitor.
Oct 04, 2009 | Desa International Reddy Heater R40 40,000...
Will not fire
this unit operates with a small air compressor at rear of motor. Remove the solid 1/8 inch plastic plug. install a low pressure gage. you should read around 5 psi
Feb 28, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
200T would burn
During start up, a hot surface ignitor glows brightley to ignite kerosene, check to see if it is broken
Nov 08, 2008 | All-Pro Kerosene Garage Shop Heaters - All...
R155 and unburnt Kerosene
Check plug gap and depth of the tip. The spark may be to far into the fuel spray flooding it out. DESA says use a standard spark plug washer or two for shims if needed.
Jan 30, 2008 | Reddy R155D Utility Heater
Kerosene heater will not wick up fuel from tank properly
Have you checked the length of wick. May not be long enough to get down into fuel. RON
Jan 26, 2008 | Northern Tool 10,600 BTU Radiant Kerosene...
Heating & Cooling Logo
Top Emerson Heating & Cooling Experts
jdthefixer
Tim Whalen
Are you an Emerson Heating and Cooling Expert? Answer questions, earn points and help others
