Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
The printer won't print out any of the reds in my images, even when the colour cartridge has just been replaced, and prints any red areas in yellow instead.
  • 57 Answers
Hi is this a new printer? If you've just installed a new color ink, it would prompt you to align the cartridge or print some test page.. If the RED doesnt show on the test page, then try to perform maintenance on it.. Like Clean cartridge or clean print head.. it may be clogged.. if it still does this, try changing the color ink.. If you color ink is from a stock, it may have dried up.. if you bought it just days ago, ask for a replacement.. If all has been done, it maybe the printer itself..
Hope this helps.. :D
Posted on Oct 07, 2010
  • mia_wilkes Oct 07, 2010
    i'm thinking it's probably the printer then, cos the red hasn't worked on 2 different cartridges, i've done all the test prints and cleaned the print head, but it still won't print it. one of the test prints came out where it hadn't even attempted to print the red :/ thanks for your help anyway :)
Too much red
I'm assuming that the colour cartridge is a three in one. Blue, Yellow and Magenta.
When printing a colour document, the printer automatically balances colour mixtures from the three primary colours listed above. Should a print out be too red, its probably because its run out of yellow and/blue.
The best way to check is to print out a test page, you should get a block for each of the colours and black. If one's missing, there's your answer.
Apr 29, 2010 | Dell 922 All-In-One InkJet Printer
HP DeskJet 850c will not print colour
It could well be the printer head (the area where the cartridge locks into the printer) has gummed up contacts. Take a soft, lint-free cloth and wipe down gently wipe down the face of the contacts. Keep wiping until all residue is removed. Reinstall a color cartridge and then run the printer's software alignment utility (this is part of the software that comes with the printer).
Aug 27, 2009 | HP DeskJet 850C InkJet Printer
I have a used C60. I have replaced both ink cartridges with Epson cartridges. When printing in color, the colors are not accurate. For example, red comes out yellow. Also, there are lines running through...
Hi there. The reason for your problem is that the colour cartridge contains cyan, magenta and yellow ink, plus a black cartridge of course. All the other myriad colours are produced by mixing these four basic colours. So, if you print red, it requires ink from both the magenta and yellow cartridges. Thus if your red produces a yellow print, it means your magenta is not printing. This can be due to a number of reasons, mainly an empty or faulty magenta cartridge or blocked magenta print nozzles.
If you wish me to help you with sorting out the lack of magenta, please post a new comment to this effect.
Mar 04, 2009 | Epson Stylus C60 InkJet Printer
Colour cartridge does not print in red
Call tech support. I believe your print head is in need of replacement. Usually they will send you out a new on free - in 3-5 days. They are foreigners (tech support) but they are knowledgable and very helpful.
Feb 19, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
The upper 2/3 of the word is either red or yellow
let the cartridge be new but the colours are got mixed with each other so this problem as the canon cartridge has the sponge in the cartridges that sponge material has soaked the colours from each other and this has happened.to solve this problem two things needs to be done 1)the head needs cleaning as the colour will be filled in it now.
2)the cartridges needs to be replaced.
Dec 15, 2008 | Canon BubbleJet i560 InkJet Printer
Printing Yellow instead of Red
The colours in the 3 colour cartridges are cyan, magenta and yellow. If you want to print "red", this requires a mixture of magenta and yellow. Thus if only yellow is printed when you should be printing red, it means the magenta is not printing i.e. faulty/empty magenta cartridge or faulty/blocked magenta nozzles.
Please post a new comment if you wish for further help with this problem.
Jul 17, 2008 | Epson Stylus C86 InkJet Printer
Won't print red
Red is a combination of Magenta and Yellow. Print a nozzle check and observe for Magenta, Yellow and cyan. If the three colours are printed, no problem with the cartridge. Then it must be the problem of seeing colours in your monitor. .
May 02, 2008 | Canon PIXMA iP2000 InkJet Printer
MP360s
Hope this will give you hints. To pin point directly you need to replace printer head. But before replacing please consider suction cartridge caps or nozzle by cleaning and freeing clogged airways by dettaching manually. I understand that the long time being not used has caused the problem. However if you can still use black and other colors then used it than complicating downtime in repairing procedures. Yes, you are right no need to clean deeper more than three times it will consume inks half empty. Have a nice day.
Besr regards,
Rosener Guyano
Nov 22, 2007 | Canon i350 InkJet Printer
Incorrect colour is printed
I would try to replace the printhead and the magenta cartridge at the same time. Lots of people with leaky cartridges have this same symptom only, it is with whatever color is malfunctioning.
Apr 25, 2007 | Canon i850 InkJet Photo Printer
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
458 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
