Question about Exercise & Fitness
I have a very old powerhouse power booster home with 200 lbs need a manual
When cb shop plugged in to test,turned on off switch, mod lamp light flashed on then off,no power
the modulation lamp is powered by diodes . They may have shorted one out and thats why it doesn't light up. If they broke it they should fix it though.
Apr 24, 2016 | Galaxy Radios 10 Meter 200 Watt Radio...
Impex Powerhouse Manual
how and where to buy li-ion battery from
z.doxio handphone model mini i9500 ???
Nov 11, 2013 | Exercise & Fitness
Powerhouse elite home gym directions
Take a look on amazon Amazon com Powerhouse gym parts
I hope this was helpful. cheeers
Apr 07, 2013 | Elite Exercise & Fitness
Replace brake booster
here you go...
The power brake booster is a tandem vacuum suspended unit. Some models may be equipped with a single or dual function vacuum switch which activates a brake warning light should low booster vacuum be present. Under normal operation, vacuum is present on both sides of the diaphragms. When the brakes are applied, atmospheric air is admitted to one side of the diaphragms to provide power assistance.
REMOVAL & INSTALLATION
1994-97 Models
See Figures 1 and 2
  1. Apply the parking brake and block the drive wheels.
  2. Remove the master cylinder-to-power brake booster nuts, then reposition the master cylinder and combination valve out of the way; if necessary, support the master cylinder on a wire to prevent damaging the brake lines.
When removing the master cylinder from the power brake booster, it is not necessary to disconnect the hydraulic lines, therefore the brake system should not have to be bled.
  1. Disconnect the vacuum hose from the power brake booster.
Fig. Fig 1: Common power brake booster attachment
  1. From under the dash, remove the retainer and washer from the brake pedal on 1994 utility models. On all other models, remove the retainer and brake switch from the brake pedal.
  2. Disconnect the pushrod from the brake pedal.
  3. From under the dash, remove the power brake booster-to-cowl retaining nuts.
  4. Back under the hood, remove the power brake booster and the gasket from the cowl.
To install:
  1. Position the booster to the cowl using a new gasket.
  2. Install the bo oster retaining nuts and tighten to 16 ft. lbs. (22 Nm) 1994 utility models, 24 ft. lbs. (32 Nm) on 1994 pick-up models and 27 ft. lbs. (36 Nm) on all 1995-97 models.
  3. Connect the pedal pushrod and install the washer or switch and the retainer.
  4. Connect the vacuum hose.
Fig. Fig. 2: Checking the piston booster rod using the gauge tool
  1. For all vehicles cover ed in this guide, gauge the booster rod:
    1. Apply 25 in. Hg (85 kPa) of vacuum using a hand held vacuum pump or apply maximum engine vacuum.
    2. Chec k the maximum and minimum rod lengths using J-37839 or an equivalent pushrod height gauge.
    3. If the piston is not within limits, install a service adjustable piston rod and adjust it to the correct length.
  2. Reposition the master cylinder and combination valve bracket to the booster studs, then secure using the retaining nuts. For details, please refer to the master cylinder procedure located earlier in this section.
  3. Start and run the engine, then check for proper booster operation.
Dec 11, 2011 | 1996 GMC Jimmy
Hi, I need a schematic for a Studiomaster Powerhouse 300
For your requirement of the schematic for your model is not available now. But this schematic will help you. Visit http://www.studiomasterarchive.com/6-2-1sc.pdf and download the PDF. It will help you.
Jun 15, 2011 | Audio Players & Recorders
Parts are missing for The Impex Powerhouse
Wore out and the maufacturer cannot replace a tech rod unit for an impex TR-2 home gym.Need complete unit of 2-50lb,2-25lb,4-10lb,2-5lb rods on a plastic base.Can anyone help?
Feb 06, 2010 | Exercise & Fitness
I cannot find a manual for a very old Home Excercise Gym I have. And it has no model number on it! It is a Golds Gym Competitor Series. It has been taken apart and i cannot figure out to get it back...
GO ON TO SEARS REPAIR GOLDS GYM #G4394 YOU WILL GET INFORMATION FOR REPLACEING PARTS THERE IS A PICTURE BROKEN DOWN AND A LIST OF PARTS THIS MIGHT HELP
Jun 13, 2009 | Exercise & Fitness
Exercise & Fitness Logo
881 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
