Question about Gateway MT6705 Notebook
My Gateway MT6705 seems to power on because the blue light will come on and I will here the cd rom spin for a second and sometimes the fan but the screen never lights up and it seems like the laptop is dead except the light remains on
    President:
  • 1,768 Answers
1. Your pc have a bad LCD and will have to serviced
2. If the blue light is the indication of proper "on" status then you have a malfunction
in the video/LCD
I am not sure of the repair cost but a qualified tech can determine this.
3. Check if you have inadvertently turn your brightness down or put the laptop in sleep
mode.
IF you have dropped the laptop you could have disconnected the video cable that go to
the LCD screen
Posted on Oct 07, 2010
Won't turn on. Bought a new charger - it's light is green, but the laptop blue charging light does not come on. It was left plugged in and no power has been restored. What should I check? What are the...
Sometimes the same plug in the laptop gets lose.
Take it to a technician to fix it. (solder)
The other option is that the motherboard could be damaged.
In that case, is not worth it fixing it because its going to be as expensve as getting a new one.
Don't forget to rate this answer if it helps
Jan 27, 2011 | Gateway MT6705 Notebook
Have a HP m7470n. The green power light in the back is constantly on. The power button flashes blue and orange (~3 seconds each). The computer wont turn on. When I unplug the cord and plug it back in, the...
In my case it turned out to be a weak power supply. It would work sometimes and not others. If stone cold, it would not boot. If I unplugged 1 thing, like the hard drive or the CD Roms, it would boot. Tested the old power suppy and it seemed to pass. But once I connected a new power supply, the computer has worked fine ever since.
Jan 08, 2011 | HP Pavilion m7470n (ER883AA) PC Desktop
My Gateway Gt 5220 will not turn on. Technicaly it does turn on ex: hard drive spin processor click couple time power brick and processor fan spins hard drive light flickers couples time and cd drive will...
sounds like your system is booting up and running due to the hold power shutdown procedure. you might try replacing the video card or adding one if your video is integrated.
Dec 23, 2010 | Gateway GT5220 PC Desktop
GATEWAY mt3422 WILL NOT BOOT UP. Power light is
if your harddisk is ok than , u open your notebook motherboard and clean processor fan properly,,than again fitting your laptop than boot from cd rom (make sure that your cd rom is ok )
Apr 14, 2010 | Gateway MT3422 RTL Notebook
Gateway 450ROG, will not start. Red DVD/CD ROM
I have the very same problem, the Drive light turns red, the screen is "black" and the battery charging light indicator on the front is off. No differance if I'm traying to power up on battery or AC-adapter.
Before this problem appeared I had problems where the laptop was powering off, with no warning, and I had to restart it. This happened several times and was going on for about a week before it died totally. Can it be the CMOS battery on the mother board? Anyone having clue what the problem could be?
Mar 31, 2010 | Gateway 450ROG Notebook
When my gateway MT6705 tries to boot, blue screen
Many times this error occurs when I have swapped a hard drive and used the wrong IDE cable to connect it. If your computer uses an Ultra Direct Memory Access (UDMA) hard disk controller, and you use a standard 40-wire connector cable to connect the UDMA drive, you may experience this error. Make sure you are using the correct IDE cable.
Also, if your BIOS settings are configured to force the faster UDMA modes, this error may occur. In this situation, restart your computer and enter the BIOS and load the "fail-safe" default settings and reboot.
If neither of these issues are the cause for the Unmountable Boot Volume, then the issue most likely is caused by a damaged BOOT.INI file in the root directory of the boot drive or file system corruption.
Follow the steps below to correct these file system issues:
1) Start your computer with your Windows XP CD-ROM, or with Windows XP boot disks
2) When the Welcome to Setup screen appears, press R to Repair the installation using the Recovery Console
3) If you have a dual-boot or multiple-boot computer, select the Windows installation you want to access
4) Type the administrator password when you are prompted, if no administrator password is set then just press Enter
5) At the command prompt, type CHKDSK /R and then press Enter
6) Once CHKDSK has finished checking and repairing the hard drive, type EXIT and press Enter to restart your computer
Oct 18, 2009 | Gateway MT6705 Notebook
Gateway MT6705 Hinge
call gate way or check with best buy
Feb 06, 2009 | Gateway 450ROG Notebook
BLACK SCREEN NO BOOT ON HARD DRIVE OR O.S.
US has 110volt power outlet while other countries like Philippines have different power outlet outlet voltage of 220v. You cant use the same power adaptor that you use in the US but if you use a power regulator like a UPS device it wont have a problem
Jul 26, 2008 | Gateway MT6705 Notebook
ZD7000 Lights, no fans, power switch not working.............
Dismantled notebook thinking compressed air removed component or connection. Nothing. Reassembled most of notebook. Left battery and power disconnected for 6.5 hours, I later plugged only AC power into unit. Fans started spinning. Completed assemble of notebook and installed the battery. Blue lights returned. Problem seems to be the battery. Shorts out something and needs about 6 hours drain out. Works great now without battery, using AC power only. Ordered new battery.....
Feb 06, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
Gateway MT6705 Notebook Logo
121 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
