Question about IBM ThinkPad T43p Notebook
Takes too long to start the windows, when it starts the mouse freezes up and all the keys are disabled
    Problem Solver:
  • 10 Answers
Possible corrupted hard drive, take to professional
Posted on Oct 07, 2010
Jumping cursor in windows 8
Background running programs must be the reason for that you must use some start up manager or background application manager to avoid such type of problems, The one well known and reliable program is Reginout to manage everything on your PC.
Nov 04, 2013 | Computers & Internet
Windows XP Professional, can't log in, try to type
Which model of laptop ?
Nearly every device in your computer system can be turned off and on by accessing the Windows Device Manager with a few clicks of the mouse. It gives you plenty of flexibility and allows you to customize your computer on a whim. The Device Manager will allow you to enable your factory keyboard and mouse and disable your current ones, effectively resetting them to the default settings
Make sure that your default mouse and keyboard are plugged into your computer. Click on the Windows "Start" button in the lower right corner of your desktop. Type "Device Manager" in the "Start Search" box. Click "Device Manager" under "Programs." Click "Continue" if the Windows permission window pops up. Click the "+" next to "Mice and other pointing devices." Right-click the default mouse and click "Enable." Switch to your default mouse then right-click your other mouse and click "Disable." Click "Yes" in the warning popup window. Unplug the other mouse. Press the "+" next to "Keyboards." Right-click your default keyboard and click "Properties." Click the "Driver" tab then click "Enable." Click "OK." Right-click your other keyboard and select "Properties." Click the driver tab then click "Disable." Click "Yes" in the permission window then click "OK." Your computer is reset to the default keyboard and mouse.
Jan 30, 2013 | Computers & Internet
THe mouse on my lap top is locked .how can i unlock it
The TouchPad is enabled by default. To change the enable/
disable TouchPad setting by using the Fn + F9 keys, see
“Disabling or enabling the TouchPad” on page 234.
You may also change the enable/disable setting as follows:
1 Click Start, Control Panel.
The Control Panel window appears.
2 Click Printers and Other Hardware.
3 Click Mouse.
The Mouse Properties window appears.
4 Click the TouchPAD ON/OFF tab.
The TouchPAD ON/OFF tab view window appears.
5 Select Disable or Enable, whichever is appropriate.
6 Click Apply.
7 Click OK.
The Mouse Properties window closes.
8 Close the Printers and Other Hardware window.
9 Close the Control Panel window.
Or you can get the manual on the link below. Just type in the # code and click on download now. Page 61 tells you how to unlock the mouse pad.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Good Luck and please rate 4 thumbs up for the free answer
Sep 02, 2010 | Toshiba Satellite A15-S157 Notebook
G5 laser mouse freezing
Download the latest mouse driver from it's manufacturer's support website.
Jun 09, 2010 | Logitech G5 Laser Mouse Mice
Freezes up during start up. Mouse does not respond, beep and then nothing. What can be done?
click on start menu> click on run (winXp) or start search (winvista or win7) > type in msconfig> click ok
a new pop window
click on startup> on the bottom part click on disable all> click apply and then ok> restart pc
Apr 01, 2010 | Acer Aspire One AOD250-1924 Netbook
How do I disable touchpad when mouse is used DELL 1525 vista home
Follow these steps to change the touchpad settings on your laptop:
1. From the Start menu, click Control Panel. With Control Panel in Category View, click Printers and Other Hardware.
2. In the Printers and Other Hardware window, click the Mouse icon.
3. In the Mouse Properties dialog box, click the Device Settings tab, and then click Settings.
4. There is a setting calleed "Disable Touch Pad when USB Pointing Device is present"
Jan 28, 2010 | Dell F3534 Touchpad
Acer 3000 Loads properly then the mouse and keys freeze
Goto Start>Run and type msconfig then press enter..In that window goto startup tab & disable the programs you dont required to be loaded at startup...
Nov 29, 2008 | Acer Aspire 3000 Notebook
Computer freezes on boot up
make sure the mouse and keyboard are in right connections...if you look closely youll see icons next to ports.
try without mouse at first start up ,load windows and use key with windows logo on it to access start and scroll to shutdown tab and restart...plug in the mouse before restart.
if logo tab isnt assigned press ctrl + esc to access start menu.
Oct 23, 2008 | Acer Aspire 5670 Notebook
Disabling touchpad
dmusick,
  • Goto Start -> Control Panel then double click on Mouse
  • There you will find the to make disable your touch pad.
  • Also there might be a key (button) near touch pad this key toggle your touch pad on/off.
Thanks
May 18, 2008 | Computers & Internet
Inspiron B130
Well start a bit slower then.
go into the bios at startup F2, and navigate around does it freeze there. if no then
start windows in safe mode F8 when windows logo shows.
freezing ?
If its not freezing then turn off the startup programs.
Start/run/msconfig and then uncheck load startup items
and start normally, click the dont show me this again /ok
any freezing.
If its freezing you may have a hardware issue.
if you have 2 sticks of memory remove on and or /reseat them
boot the dell diagnostics cd and check the cpu and memory.
report back
Jan 30, 2008 | Dell Inspiron B130 Notebook
IBM ThinkPad T43p Notebook Logo
54 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
