Question about RCA Audio Players & Recorders
The unit shuts down after about 2 seconds after I turn it on. I have poked at the reset button on the back to no avail.
  • 55 Answers
You have a blown Power Amplifier and need to take it to a Audio Repair Shop
Posted on Oct 07, 2010
How do i format wimax modem bm328
Typically, you "format" a hard disk. Your modem doesn't have a hard disk.
Most likely, you want to "return to factory setting". Turn it off first. there should be a reset button on the back, it may be hidden or even be just a hole you poke a paper clip wire in.
Hold the reset button down and turn power on. Keep holding the reset button 10 seconds. That should reset it to original.
May 25, 2015 | Computers & Internet
Where is the reset button on the kindle fire?
According to eHow.com: " E-Reader Soft Reset
  • 1 Open your Kindle's Menu while on the Home screen. Do so by pressing the Menu button, or the onscreen Menu icon for Kindle Paperwhite owners. Select the "Settings" option.
  • 2 Choose "Menu" again from within the Settings menu. This displays a different menu than before.
  • Sponsored Links
  • 3 Choose the "Restart" option. Wait while your Kindle powers off and on again.
E-Reader Hard Reset
  • 1 Charge your Kindle e-reader before performing a hard reset. Charging helps ensure your problem isn't related to the device having a low battery.
  • 2 Hold down the Power button for 20 seconds. The screen will change after a few seconds, but continue holding the power button for the full 20 seconds before releasing.
  • 3 Wait while your Kindle restarts.
E-Reader Factory Reset
  • 1 Press your Kindle's Menu button. Select "Settings" from the menu.
  • 2 Open the menu once more from within the Settings window. Select "Reset to Factory Defaults," or "Reset Device" if you're using a Paperwhite.
  • 3 Select "Yes" in the confirmation window after reading the warning. Wait while your Kindle restarts and restores.
Fire Soft Reset
  • 1 Hold the Power button down for three to five seconds. A Shutdown window appears.
  • 2 Tap the "Power Off" button in the Shutdown window. Wait for the Fire to shut down completely.
  • 3 Press the Power button to turn the device on again.
Fire Hard Reset
  • 1 Plug your Kindle Fire in and give it time to charge before performing a hard reset. This helps ensure your issues aren't related to having a low battery.
  • 2 Hold down the Power button for 20 seconds. The Kindle Fire will shut down.
  • 3 Press the Power button to turn the Kindle Fire back on.
Fire Factory Reset
  • 1 Swipe your finger down from the top of your Kindle Fire's screen, presenting the Quick Settings menu.
  • 2 Tap the "Settings" option and select "Device."
  • 3 Select "Reset to Factory Defaults," then tap the "Reset" button. Wait while your Kindle Fire restarts and restores.
Read more : http://www.ehow.com/how_6122863_reset-kindle.html
May 10, 2015 | Tablets & eReaders
Nespresso pixie c60 only brews for a few seconds on full cup mode
Would love more info, like how long did you have this item and did it go from 10 seconds to 3 seconds with less water over a period of time or just over night?
if this has been giving you less and less water and taking / shorting the amount of time you might have Calcium build up inside the unit that is not that easy to clean out, Seen it happen on a mr coffee unit it would make a 1/2 pot of coffee because of the build up from the hard water in the area.. Needed a new coffee maker.
Dec 09, 2014 | Nespresso Pixie C60 Espresso Maker...
Elinchrom fx 200 ri. How can I reset?
To reset your strobe, follow these steps:
1. Switch the unit "off"
2. While still off, with one hand, press and hold both the flash-power up & flash-power down buttons (#10 in the picture).
3. Keep holding the buttons pressed and turn the unit back on with your other hand.
4. The Digital LED will flash in fast mode for a few seconds. Release the buttons. The unit is now reset.
Support for Elinchrom products is available at the link, below, including downloadable manuals.
ELINCHROM
Oct 16, 2013 | Elinchrom Cameras
Mitsubishi 73" DLP powers on, through welcome
If you are getting at turn on source and back ground is all blue the set will shut down rather quickly;
I have a suggestion, if it works fine, and if not it will not hurt anything.
with original Mitsubishi remote turn set on and then Menu, 1,2,3, enter.
This is the soft reset that most of these sets have (cannot be sure since Model number above is correct?)
The reset button on the front (if it has it) just shuts the set down and reboots the DM unit inside.
Most of these sets when it is pressed the green light will blink for about 70 seconds and go out; that is the DM unit rebooting and the soft restart is something else.
Let me know what you find before you rate this information.
SD TECH
Oct 05, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
I forgot my password how do i reset it?
there's a reset button - you need to press it for 10 seconds while the power is on. I use a paperclip to poke the button. I think your reset is in the back of the unit.
Sep 17, 2011 | Zyxel (91-004-361002) Wireless Router
I have a new computer and new to install linksys ...it is asking for my security number. i have typed in all the numbers/letters i have but to no avail. where do i find the security infor?
    1. when the unit is powered on, hold down its reset button for 30 seconds
    2. while still holding down the reset button, unplug the router from power and hold for an additional 30 seconds
    3. still holding down the reset button, turn on power to the router again and hold for 30 more seconds
Reset button is located on the back of the router. This will reset the IP to 192.168.1.1 and you can connect your computer to it and go to http://192.168.1.1
Login with admin, password is admin or linksys
Aug 29, 2011 | Linksys Wireless-G WRT54G Router
Forgot my password on my wireless router TP-Link
Step 2 Turn off the router (pull the power out of the unit). Step 2 Press and hold the reset button on the rear panel with a pin, while holding down the reset button turn on the router (plug the power back into the unit). It is important that you continue to hold down the reset button for approximately 15 seconds. Step 3 Release the reset button and wait for the device to reboot.
Oct 24, 2010 | Computers & Internet
Every light is solid except the wireless and security buttons...how can i get the wireless back working?
Try the following:
After this process (a total of 90 seconds) is complete, your router should be restored to its factory default state.
Aug 24, 2009 | Computers & Internet
My creative zen v plus is stuck in shutting down
i think i have a different version of zen but hopefully it'll work for you. i held down the power button and pokes the reset button with a pen tip for about 5 seconds and it finially turnned off! i've had alot of problems with the zen and it sorta happens alot and most times you need to do different things but the same problem usually doesnt come bk. good luck
Mar 12, 2009 | Creative Labs ZEN V Plus MP3 Player
49 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
