Question about Kenmore 62802 Electric Dryer
My Kenmore 90 Series Dryer stops running mid cycle. On both the Auto Dry and Timed dry settings. It just shuts down and won't restart when I push the start button. If left alone it suddenly springs back on. Then repeats this cycle over and over. On-Off...etc...
  • 1073 Answers
SOURCE: Electric Dryer Starts, runs, warms, stops (Kenmore series 90)
you have a bad motor that needs to be replaced
Posted on May 06, 2008
docjohn174
  • 943 Answers
SOURCE: Autodry cycle never stops
hi thanks for the question ther is a thermostat on the air duct at the back of the dryer it has 2 wires at ends and 2 wires in the middle smaller ones this thermostat opens to turn off heat and the small wires on this thermostat when the heats shuts off then power goes to the timer and not before if it shuts off on timed dry timer is ok i would vacuum the dryer make sure all the vent right to the outside is clean as air flow restriction can cause this problem thanks the appliance doc
Posted on Sep 15, 2008
agitateme
  • 88 Answers
SOURCE: dryer runs but wont auto shut off
On auto dry cycles, the cycle is controlled by moisture sensing bars located on either the rear or front bulkhead, ( visible inside dryer ) if the moisture sensor bars are shorted together (normally by wet clothing) the dryer will continue to run. If the dryer continues to run when the clothes are plenty dry, check and see if there is anything stuck between the sensor bars, (sometimes a metal sequin will cause this) or see if they are damaged. If not, you may have a problem with a timer contact, if the timer advances and stops moving at the same spot each time, I would suspect the timer. If this is an EvenHeat dryer, examine the control board located to the right of the timer in the control panel, for any burned components. Hope this helps.
  • 4 Answers
SOURCE: maytag atlantis dryer model # mde6400ayw
sounds like the timer is not completing the cycle in this mode will the dryer shut off if you manuelly advance timer in that mode
Posted on Nov 01, 2008
danromarris
  • 101 Answers
SOURCE: Maytag Atlantis MDE6200AYW will run, but no heat
Check to make sure that you have the proper voltage running to the dryer first. Next you may have a problem with your heating element or with your thermal fuse. Get your dryer opened up so you can see your heating element. Run the dryer and if you see the heating element come on and then turn right back off again then you have a bad thermal fuse. If it doesn't come on at all though then the heating element is bad. Both parts can be picked up at your local appliance repair shop. Just make sure to unplug the dryer before replacing the part. If you have any other questions let me know and let me know if this was helpful for you. Good luck.
Posted on Jan 22, 2009
GE spacemaker electric dryer PCKS443EBWW. Dryer shuts off mid cycle on timed dry setting. Wait till cool down and will start again. Venting is clear, I vacuumed inside and around motor. Any ideas?!
Mark, Could be limit /over heat/thermal fuse/switch, check or have checked by a good repair Tech., diagnosed and estimate repair. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
What to Check when your Dryer Shuts Off Mid Cycle
Whirlpool Maytag Dryer Diagnostic Shuts off mid cycle not heating...
Kenmore Whirlpool Clothes Dryer Repair The Most Common Problem
GE electric dryer overheating shutting down
Jul 10, 2016 | GE Dryers
The drum light is out in a GLER104FSS
first, unplug machine. open the dryer door, Remove light protector cap. (pry with flat screwdriver), unscrew bulb and replace a new one
tadamm!! :-)
Mar 30, 2014 | Frigidaire GLER104FSS Gallery Series 27...
Kenmore 110.60812990 will not stop
if it's not advacing in time dry you have a bad timer,that timer should count down no matter what the dryer is doing,if you have it in auto then it could be no heat,when it's in auto or more or less cycle the heat comes on and the timer won't move until the heat shuts down,when the heat is off timer advances,when the heat starts the timer stops,it will do this until the clothes are dry and then timer will shut off but in timed cycle,timer isn't counting down get a new timer.
Apr 05, 2013 | Washing Machines
Drier not hot enough when i set temperature to high position
Replace the high limit thermostat located on the top of the heating element housing. Here is the part to order.
Nov 18, 2012 | Frigidaire GLER104FSS Gallery Series 27...
Dryer will not shut off in any 'auto' mode. Time display ticks down, then jumps up again and keeps running. Dryer does works properly when 'timed dry' is selected. Checked and cleaned exhaust vent. ...
How long is the vent from the dryer to the outside? Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dry-ability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
Jul 14, 2010 | Samsung DV337 Electric Dryer
Electric dryer timer
the auto temp sensor is bad / Larry
Nov 01, 2008 | Kenmore 62602 Electric Dryer
Sep 15, 2008 | Dryers
Kenmore C11084 7029 0 dryer will not start
replace the main motor you have bad motor
Nov 12, 2007 | Dryers
Kenmore 62802 Electric Dryer Logo
311 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
