Question about Insignia IS-LCDTV32 32 in. Television
32" Insignia TV (functions don't work)
All the functions on the TV don't work except the power button. The remote is the same. The only switch that works is the power button both on the remote and on the TV. What do I do? I had a problem awhile ago with two of the capacitors that went bad and had them replaced, but now I have all the functions not working. What do I do?
    Problem Solver:
  • 6 Answers
New power board at partstore.com or andrewselectronics.com mfg. advent part# 667-L32K5-20C $68.00 works great!!
Posted on Jun 05, 2008
  • butterbean Jun 05, 2008
    cause i just repaired one and it had the famous capacitors leaking and burnt a hole thru the board
Remote control code for dish network controler.sat.box vip211k
It would be our pleasure to help you with getting your DISH Network remote to control your Insignia TV. We're going to start by pressing and holding the TV button located on the top of your remote until all mode button back lights come on, and then release. Use the number buttons to enter the codes for your TV; here are some of the codes we currently have: 834, 538, 720, 000, 834, and 697. Press the pound (#) button. To check that the code works try several different functions on the remote to make sure it will properly operate the TV. Remember that some codes may not be compatible with your equipment. If this is the case, try the other codes listed for your Insignia TV until you find one that is compatible with it.
We hope this helps and thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Feb 13, 2010 | Insignia IS-LCDTV32 32 in. Television
Can't program my DirectTV remote to control my Insignia TV (no Insignia remote code on DirectTV's remote programming menu)
I have an insignia TV 32" and I used common code 10463 to program my direct tv remote. hope it works for you.
May 05, 2009 | Insignia IS-LCDTV32 32 in. Television
No response to any button on remote or tv except power button
Press the 'Favorite' button on the remote. You may have accidentally pressed it. It locks the channel. Pressing again unlocks.
Apr 22, 2009 | iLO 3200 32 in. LCD Television
Remote Control
From GUEST: I found this solution in the manual and will perform this task again to see if I can get the tv will be re-recognized again. Give this a try, too.
Remote will not turn on or shut off the TV.
• You must program the converter box remote in order to control your TV power button.
• To program the remote control:
    1. Determine if the TV is a model that can be controlled by the remote control. See "Controllable TV brands" on page 17 in the manual.
    2. Turn on the TV.
    3. While you press and hold TV POWER on the remote control, press CH ^ or CH v one or more times until the TV turns off. Each time you press one of these buttons, the remote control sends a manufacturer code (between 1 and 45) to the TV.
Sep 01, 2008 | Insignia Digital-to-Analog Converter for...
Remote Control-reset to factory settings
hi,,., i saw your concern... i worked for a big company whose supporting tv remote and universal remote... we reset remote by removing the batteries and by pressing all of the buttons twice (take not each and every button) by doing this it will discharged the power consume in the battery. and also check if there is a jammed or stucked button, or check if there will be a Function button... hope this may help
Jan 23, 2008 | Insignia IS-LCDTV32 32 in. Television
Remote control code needed for this TV
Need to program my Insignia TV to my Direct TV remote. Need code
Nov 07, 2007 | Insignia IS 20" TV040919 TV
Insignia 32 inch LCD TV: Can not change Channel or Volume !
I have one in my shop with the same problem. Power is the only function that works. I repaired the power supply six monts ago. Now it looks like a bad digital processor board which is non-repairable. I can't believe what's happened to the tv business. Absolutely disgusting!
Oct 12, 2007 | Insignia IS-LCDTV32 32 in. Television
Insignia IS-LCDTV32 32 in. Television Logo
122 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
